ASUS P4S333 + GeForce 3
The only issues the DDR Zone had using the board was installing a GF3. The drivers would not install after 3 complete installs. The card is regularly used in testing so we could not fault it. Adding a Kyro2 and running some tests then replacing it with the GF3 and 22.83 det drivers. (Note: same ones we had tried to use unsuccessfully before).
Kan iemand dit bevestigen????
  • Oscar the Grouch
  • Laatst online: 11:57
Oscar the Grouch
Ex-Admin
Question everything
I will nog move this topic to VB, maybe there will be someone who can answer this :P
 I don't know half of you half as well as I should like; and I like less than half of you half as well as you deserve
Op donderdag 21 maart 2002 14:56 schreef Oscar the Grouch het volgende:
Je engels is ook niet 100% :D
Welle, weet iemand too then ze antweurt???
