Op woensdag 20 maart 2002 21:09 schreef blaadaap het volgende:
nou ik wil dus outlook opstarten krijg ik deze foutmelding:
MSIMN heeft een fout met betrekking tot een ongeldige pagina veroorzaakt in
module WAB32.DLL
Windows
Adress
book is (misschien)
corrupt
ff de search op technet gebruikt !
All Products | Support | Search | Microsoft.com Guide
Home Search FAQs Downloads Newsgroups Customer Service Contact Us
Send
Print
Help
OLEXP: Error Message: MSIMN Caused an Invalid Page Fault in Module Wab32.dll (Q247706)
The information in this article applies to:
Microsoft Internet Explorer versions 5.01 , 5.5 , for Windows 98 Second Edition
Microsoft Internet Explorer versions 5.01 , 5.5 , for Windows 95
Microsoft Outlook Express versions 5.01 , 5.5 , for Windows 98 Second Edition
Microsoft Outlook Express versions 5.01 , 5.5 , for Windows 95
For information about differences between Microsoft Outlook Express and Microsoft Outlook e-mail clients, click the article number below to view the article in the Microsoft Knowledge Base:
Q257824 OL2000: Differences Between Outlook and Outlook Express
SYMPTOMS
After you download Internet Explorer, you may be unable to start Outlook Express or open the address book in Outlook Express. You may also receive the following error message:
This program has performed an illegal operation and will be shut down. If the problem persists, contact the program vendor.
If you click Details , the following error message may be displayed:
MSIMN caused an invalid page fault in module WAB32.dll.
CAUSE
This behavior may occur if the Wab32.dll file is damaged or corrupted.
RESOLUTION
To resolve this issue, rename the address book name. Do not rename the extension.
NOTE : The address book file name is usually your logon name.
If the file extension is not visible, you may disable hiding of the File Extensions. To do so, follow these steps:
Disable the Hiding of File Extensions
Double-click My Computer , and then click Options (or Folder Options ) on the View menu.
Click the View tab, and then clear the check box Hide file extensions for known file types (or Hide MS-DOS file extensions for file types that are registered ).
Click OK , and then close My Computer .
Renaming the Address Book
Click Start , point to Find , and then click Files or Folders .
In the Named box, type *.wab . By default, the file should be located in the Windows\Application Data\Microsoft\Address Book folder.
Right-click the Name .wab file, and then click Rename . Do not change the .wab file extension.
Type a new name for the file, and then press ENTER.
Start Outlook Express and then open the address book. This action creates a new address book.
Import the messages from the first renamed *.wab file into the new address book.
STATUS
Microsoft has confirmed this to be a problem in the Microsoft products that are listed at the beginning of this article.
MORE INFORMATION
This behavior may also occur if the Outlook Express folder is named Outloo~1. If the the Outlook Express folder is named Outlook~1, rename the folder to Outlook Express.
For information about how to rename a folder:
Click Start , and then click Help .
On the Index tab, type renaming , and then double-click the Renaming folders topic.
