Formulier via ASP naar XML
  • Epitome
  • Laatst online: 27-08 08:05
Ik heb een formulier gemaakt in HTML (ASP) dat ik door middel van post naar een XML document wil schrijven.
Ik maak gebruik van een script dat hier te vinden is.
Met de action verwijs ik naar het volgende ASP bestand:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
'The "ConvertFormtoXML" Function accepts to parameters.
'strXMLFilePath - The physical path where the XML file will be saved.
'strFileName - The name of the XML file that will be saved.
Function ConvertFormtoXML(strXMLFilePath, strFileName)
 'Declare local variables.
 Dim objDom
 Dim objRoot
 Dim objField
 Dim objFieldValue
 Dim objattID
 Dim objattTabOrder
 Dim objPI
 Dim x
 'Instantiate the Microsoft XMLDOM.
 Set objDom = server.CreateObject("Microsoft.XMLDOM")
 objDom.preserveWhiteSpace = True
 'Create your root element and append it to the XML document.
 Set objRoot = objDom.createElement("contact")
 objDom.appendChild objRoot
 'Iterate through the Form Collection of the Request Object.
 For x = 1 To Request.Form.Count
  'Check to see if "btn" is in the name of the form element.
  'If it is, then it is a button and we do not want to add it
  'to the XML document.
  If instr(1,Request.Form.Key(x),"btn") = 0 Then
   'Create an element, "field".
   Set objField = objDom.createElement("field")
   'Create an attribute, "id".
   Set objattID = objDom.createAttribute("id")
   'Set the value of the id attribute equal the the name of
   'the current form field.
   objattID.Text = Request.Form.Key(x)
   'The setAttributeNode method will append the id attribute
   'to the field element.
   objField.setAttributeNode objattID
   'Create another attribute, "taborder". This just orders the
   'elements.
   Set objattTabOrder = objDom.createAttribute("taborder")
   'Set the value of the taborder attribute.
   objattTabOrder.Text = x
   'Append the taborder attribute to the field element.
   objField.setAttributeNode objattTabOrder
   'Create a new element, "field_value".
   Set objFieldValue = objDom.createElement("field_value")
   'Set the value of the field_value element equal to
   'the value of the current field in the Form Collection.
   objFieldValue.Text = Request.Form(x)
   'Append the field element as a child of the root element.
   objRoot.appendChild objField
   'Append the field_value element as a child of the field elemnt.
   objField.appendChild objFieldValue
  End If
 Next
 'Create the xml processing instruction.
 Set objPI = objDom.createProcessingInstruction("xml", "version='1.0'")
 'Append the processing instruction to the XML document.
 objDom.insertBefore objPI, objDom.childNodes(0)
 'Save the XML document.
 objDom.save strXMLFilePath & "\" & strFileName
 'Release all of your object references.
 Set objDom = Nothing
 Set objRoot = Nothing
 Set objField = Nothing
 Set objFieldValue = Nothing
 Set objattID = Nothing
 Set objattTabOrder = Nothing
 Set objPI = Nothing
End Function
'Do not break on an error.
On Error Resume Next
'Call the ConvertFormtoXML function, passing in the physical path to
'save the file to and the name that you wish to use for the file.
ConvertFormtoXML "c:","recept.xml"
'Test to see if an error occurred, if so, let the user know.
'Otherwise, tell the user that the operation was successful.
If err.number <> 0 then
 Response.write("Errors occurred while saving your form submission.")
Else
 Response.write("Your form submission has been saved.")
End If
Nu gaat het goed ("Your form submission has been saved."), maar kan ik niet het XML bestand terugvinden. :?
Hoe maak ik het script zo dat het gegenereerde XML document gewoon in dezelfde folder staat als de site?
Misschien strXMLFilePath een waarde geven?
  • OMX2000
  • Laatst online: 07:25
OMX2000
By any means necessary...
Dat doet ie al in de aanroep... Hij staat dus niet op c: vaag...
Server.MapPath("/") geeft de fysieke locatie van de root van de website
Mischien een heel domme vraag hoor, maar staan je rechten wel ok? Ik bedoel mag je script wel eeen file aanmaken op je server?
/excuse mode
Zomaar ff een gedachte die ik met je wou delen.....:)
iig veel succes en ik ga deze thread zeker ff volgen interesting
