wie helpt mij?
  • 45 views sinds 30-01-2008
Jorrit van der Laan
Blaat [4] Designs
1500-4030-1192-0385-6539-4366*
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 5-5-99 22:22:00
Nero Version: 5.5.7.2
Recorder: <ATAPI CD-R/RW 12X8X32> Version: 9.BC - HA 0 TA 1 - 5.5.7.2
Adapter driver: <ESDI_506> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI
CD-ROM: <ATAPI CD-R/RW 12X8X32>Version: 9.BC - HA 0 TA 1 - 5.5.7.2
ATAPI CD-R/RW 12X8X32 (Target 1, I:): Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 48234496 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 383MB (392680kB)
Free physical memory: 236MB (242332kB)
Memory in use : 28 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: Off
CD-ROM (ISO)
19.3.2002
16:29:55#1 Phase 87 File dlgbrnst.cpp, Line 1436
Seamless Link activated
16:29:55#2 Text 0 File Reader.cpp, Line 117
Reader running
16:29:55#3 Text 0 File Writer.cpp, Line 127
Writer ATAPI CD-R/RW 12X8X32 running
16:29:55#4 ISO9660GEN -11 File geniso.cpp, Line 4307
First writeable address = 0 (0x00000000)
16:29:56#5 Text 0 File ThreadedTransferInterface.cpp, Line 679
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 332149 (332149) = #332149/73:48.49
relocatable, CD pos for caching/writing not required/required, no patch infos
16:30:19#6 Text 0 File DlgWaitCD.cpp, Line 194
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 332151 (73:50.51)
16:30:21#7 Text 0 File DlgWaitCD.cpp, Line 1331
Recorder: ATAPI CD-R/RW 12X8X32;
CDR code: 00 97 31 01; OSJ entry from: Ritek Co.
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1F 01 (LI 97:31.01), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
16:30:23#8 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder ATAPI CD-R/RW 12X8X32 for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close Session
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 680548352
16:30:23#9 Text 0 File ThreadedTransferInterface.cpp, Line 852
Removed 2 run-out blocks from end of track 1.
16:30:23#10 Text 0 File ThreadedTransferInterface.cpp, Line 679
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 332147 blocks [ATAPI CD-R/RW 12X8X32 ]
16:30:23#11 Phase 24 File dlgbrnst.cpp, Line 1436
Caching of files started
16:30:28#12 Phase 25 File dlgbrnst.cpp, Line 1436
Caching of files completed
16:30:28#13 Phase 28 File dlgbrnst.cpp, Line 1436
Speed measurement started
16:30:28#14 Text 0 File ThreadedTransferInterface.cpp, Line 1950
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
16:32:28#15 Text 0 File ThreadedTransfer.cpp, Line 219
all writers idle, stopping conversion
16:32:28#16 Phase 29 File dlgbrnst.cpp, Line 1396
Speed measurement completed: 38.6x (5.790 KB/s)
16:32:28#17 Phase 32 File dlgbrnst.cpp, Line 1436
Simulation started at 12x (1.800 KB/s)
16:32:28#18 Text 0 File ThreadedTransferInterface.cpp, Line 1950
16:32:28#19 Text 0 File Mmc.cpp, Line 15217
Set BUFE: Seamless Link -> ON
16:34:56#20 SCSI -400 File Cdrdrv.cpp, Line 1411
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03926F60
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x09 (KEY_VENDOR_SPECIFIC)
Sense Code: 0x8F
Sense Qual: 0xE9
CDB Data: 0x2A 0x00 0x00 0x01 0xDD 0xF5 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x51 0xB7 0x29 0x93 0x62 0x45 0x86 0xD2
0xE5 0x87 0xA1 0x4A 0x8F 0xE9
16:34:56#21 mmc -400 File Writer.cpp, Line 321
SCSI Target error
16:34:56#22 Text 0 File ThreadedTransfer.cpp, Line 219
16:34:57#23 Text 0 File ThreadedTransfer.cpp, Line 213
conversion idle, stopping reader
16:35:07#24 SCSI -1093 File Cdrdrv.cpp, Line 1207
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0xFF
CDB Data: 0x35 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x02 0xFF
16:35:07#25 mmc -1093 File WriterStatus.cpp, Line 142
No seek complete
16:35:07#26 TRANSFER -18 File WriterStatus.cpp, Line 142
Could not perform EndTrack
16:35:07#27 CDR -201 File WriterStatus.cpp, Line 145
Invalid writestate
16:35:07#28 TRANSFER -18 File WriterStatus.cpp, Line 145
16:35:07#29 Phase 34 File dlgbrnst.cpp, Line 1436
Simulation failed at 12x (1.800 KB/s)
16:35:07#30 Text 0 File Scsicmd.cpp, Line 371
SCSI uses static buffer memory. Buffer start: 0x21020000
20 out of 20 temporary buffers allocated
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 5-5-99 22:22:00
File 'IoSubsys\NEROCD95.VXD': Ver=4, 5, 0, 12, size=37811 bytes, created 6-3-02 17:59:44
File 'IoSubsys\CDR4VSD.VXD': Ver=2.5 (099), size=197884 bytes, created 27-3-01 2:50:00
File 'IoSubsys\CDRALVSD.VXD': Ver=1.00 (1039), size=20047 bytes, created 27-3-01 1:00:00
File 'IoSubsys\ACBHLPR.VXD': Ver=1.01, size=40508 bytes, created 6-3-02 17:26:44
File 'IoSubsys\CDUDF.VXD': Ver=5.0 (141), size=133897 bytes, created 11-1-01 5:00:00
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 5-5-99 22:22:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 5-5-99 22:22:00
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69574 bytes, created 5-5-99 22:22:00
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 5-5-99 22:22:00
File 'IoSubsys\ElbyCDIO.vxd': Ver=3, 3, 1, 1, size=15635 bytes, created 19-12-01 0:12:14
iemand die dit probleem kent, hij verkracht al mijn cd'tjes zo, blij dat ik nu simulatie gedaan heb ;)
  • Twynn
  • Laatst online: 10-09 08:16
Hmm.. Ik zie dat je nieuw bent op GoT.. Allereerst natuurlijk welkom..
Ik zou je even een paar tips willen geven, want je topic is een beetje lastig te ontcijferen..
Begin allereerst eens met een duidelijke omschrijving van het probleem.. Logfiles kunnen nuttig zijn, maar laat de overbodige dingen achterwege..
Vermeld verder duidelijk even wat voor systeem je hebt.. Dat scheelt ook al veel..
En zoek natuurlijk in de database of je probleem vaak voorkomt, en probeer de gevonden oplossingen ook voordat je een topic opent..
En probeer verder een duidelijke topictitel te verzinnen.. (zie ook de algemene FAQ).
Als je er dus niet uitkomt, open gerust een nieuw topic, maar probeer het een beetje overzichtelijk te maken :)
