YAMAHA DSP AZ-1 SPEC.
  • 2.477 views sinds 30-01-2008
  • SlowikPL
  • Laatst online: 18-08 14:37
Hallo
Ik ben geïnteresseerd om Yamaha DSP AZ-1 te kopen en heb voor mijzelf de specificaties vertaald van Japans naar Engels en beslot met jullie te delen.
http://pub7.ezboard.com/faussiedvdandhtforumfrm28
Yamaha corporation (Shizuoka prefecture Hamamatsu city Nakazawa Cho 10-1, president: Itoh Osamu two), choice of up-to-date amplifier technology is concentrated, Yamaha DSP AV amplifier " DSP-AZ1 " from the December middle is sold with entire country as a new product of this corporation flagship AV amplifier which actualizes the correspondence to treble quality conversion and the next generation audio format which it is thorough.
Summary > this time of the < product sells " DSP-AZ1 " to concentrate the choice of up-to-date AV amplifier technology such as leading D/A converter, it is the flagship model where the treble quality conversion which depends on digital maximum concept and is thorough and this corporation AV amplifier line-up which actualizes the correspondence to the next generation are located most significantly. All the it loads the 192kHz/24bitD/A converter of the YAMAHA corporation make which corresponds to the highest audio standard of DVD audio in channels 10 which include the super woofer. Furthermore high accuracy such as adopting the crystal semi-conductor corporation make digital control volume which actualizes multichannel playback and forming the simple circuit, high purity it actualizes playback loading the " processor direct circuit ", high grade purely converting & expanding the digital signal, it is thorough the refinement of the signal route which removes external influence it actualizes treble quality due to " digital maximum concept ". In addition, the treble quality which surpasses the former flagship model with the high grade design which is due to the adoption of substantial power rise and the treble quality part with loading the large capacity power transformer and is thorough is actualized.
Furthermore, " DSP-AZ1 " is the treble quality multichannel audio format of the next generation, as " the DTS96/24 " * it corresponds to 1, the DVD which is recorded with the up-to-date 6.1 channels
5.1 channel playbacks of BS digital broadcast can enjoy the software it can play back " DTS discrete 6.1 " * 2 and including " Dolby digital * matrix 6.1 ", " the MPEG-2
The AAC " * 3, furthermore channel 2 software can be enjoyed easily with 5.1 channels, " the ドルビ
Attendant upon the spread of DVD video and the start of BS digital broadcast, the foam/home theater demand which enjoys the appearance impression rich simultaneously with image has increased suddenly. As for this corporation, 1986 years Sound field origination machine " DSP-1 " ever since of year sale, being consistent, to pursue multichannel playback, in the foam/home theater market this corporation individual technology " cinema DSP " in the nucleus, family layer
In object foam/home theater system " cinema station " empty of simple installation * simple operation, high-class DSP AV amplifier series of single item and of various types
Until the car, arranging wide line-up, it leads/reads the market.
This time sells " DSP-AZ1 " to be the flagship model where the high-class DSP AV amplifier series is located most significantly, this corporation the high-class DSP AV which is cultivated over long time As everything of treble quality design technology of the amplifier is included, it is the first class AV amplifier which corresponds to also the audio format of the next generation who begins " DTS 96/24 ".
1.Substantial power rise audio circuit constitution of the advancement which thoroughly pursues treble quality
It corresponded to the highest audio standard of DVD audio the corporation make 192kHz/24bitcDac ", the super woofer and the front effect channel You adopt for all the channel 10 everything which it includes. Furthermore the channel to channel error in multichannel playing back is controlled " crystal semi-conductor corporation make digital control volume ", and connects directly the aural signal immediately after the D/A converting to the power amplifier directly in minimum
The simple circuit is formed by the fact that it does, the high purity which removes the influence outside playback is actualized the " processor direct circuit " and so on, purely expanding the digital signal, the signal which removes external influence treble quality is actualized due to " digital maximum concept "
It is thorough the refinement of signal route. In addition, the built-in power amplifier the 130W×6ch+45w×2ch which actualizes the substantial power rise of the total 140W in comparison with front model " DSP-AX1 " (rating, 6) builds in discrete constitution 8ch specification. It is low, loading the large capacity power transformer which improves limits drive ability substantially and adopting et cetera the treble quality film condenser the high grade design which it is thorough is administered, the treble quality which surpasses the former flagship model is actualized.
2.It builds in the which corresponds to the audio format of the next generation
As it corresponds to the audio format " DTS 96/24 " of the next generation who plays back 5.1ch everything with treble quality of the 96kHz/24bit, the up-to-date " DTS discrete 6.1 which " can play back the DVD software which is recorded with 6.1 channels and " Dolby digital * matrix 6.1 ", it can enjoy 5.1 channel playbacks of BS digital broadcast, the " MPEG-2 AAC ", furthermore channel 2 software can be enjoyed easily with 5.1 channels, the DOLBY PRO LOGIC II which corresponds to the up-to-date audio format " Dolby professional logic II ", including " the NEO:6 ", is built in.
The appearance impression the colorful sound field which overflows is actualized loads the " cinema DSP "
The Yamaha individual " cinema DSP " which raises the appearance impression rapidly by the fact that the DSP processing which is optimum to the sound of the various formats to 6.1 channels from monaural is added is loaded. And, the effect selection being possible from the which is climbed in as many as 41 types, the 6.1ch source to be is the ち even among them, this corporation is accumulated over long time survey day it is with it reproduces to real " digital Sci-Fi including 6.1 " and the " DTS Sci-Fi ES ",
It is based on the タ, the " HALL A IN Europe " and the " Village Gate " and so on you prepare also the HiFi DSP sound field abundantly. In addition, the colorful sound program of the " cinema DSP " can be enjoyed to can enjoy with just the front speaker even with the headphone which is convenient " virtual * cinema DSP " function, and the movie appreciation of nighttime, the pleasure of the cinema DSP can be actualized with various listening environment with loading " the silent theater " function.
3.It equips the abundant input/output terminal which raises expandability
In the input/output terminal the D5 terminal and the component image terminal which can enjoy the high picture quality of the highest standard of the HDTV (input 2 system and output 1 system) it equipped. In addition, the digital audio input terminal of 10 system of the total which includes the front input terminal (optical 7 same axis 3) and, the digital voice response terminal of 2 systems (light 2) it equips. Furthermore the expandability of the foam/home theater the abundant input/output terminal which such as analog audio input terminal of 5 systems and 6ch input terminal of the channel distribution functional attachment raises was equipped
4.To use it equips convenient multi-function remote control easily
With multi-function remote control of attachment, also the television and the DVD of other companies can equip operational learning & pre-setting function, can control also the selection and the fine control et cetera of the sound field program easily from actual appreciation position including power source and volume and input source change et cetera. Furthermore it equipped also the convenient macro function which can execute the operation of continuing with one switch. In addition, while the effect and the sound quality of the sound field program and the colorful parameter setting et cetera which begins the assign of the input terminal, looking at graphics and the text which are indicated in the TV picture, it equips the illuminating optical function whose operation is easy even at the convenient ounce clean function and the dark place which you can adjust.
1 DTS 96/24
Extended format of DTS. It is adopted at the up-to-date sound recording studio, it actualizes the treble quality " of the 96kHz/24bit " with the 5.1ch. Even with the former DTS decoder it can play back the software which in DVD video was recorded with DTS 96/24 with the usual sound quality.
2 DTS discrete 6.1
The new format where the front 3ch, in the rear 2ch the silent dedicated channel LFE (low effect) it makes the 6.1ch in the former 5.1ch constitution which is added including the rear center channel, furthermore it is recorded in the form where each channel becomes independent completely. By the matrix circuit extracts the center channel there is also a DTS-ES matrix 6.1 which in the 6.1ch of the DTS, DTS-ES matrix 6.1 and the DTS (the 5.1ch) with it can play back the software which was recorded with the DTS-ES 6.1 discrete.
3 MPEG-2 AAC
Standard audio format of BS digital broadcast. Low bit due to up-to-date speech compression technology rate is huge treble quality merit. 5.1ch sound and multi language broadcasts are made possible in addition to the usual 2ch stereo.
4 DOLBY PRO LOGIC II
The DOLBY PRO LOGIC II in order improves Dolby professional logic, to play back the 2ch sound source with the 5.1ch. There to be a movie mode and a music mode, with movie mode with the DOLBY PRO LOGIC II record
It corresponds to the software which is recorded, the sound field effect which is superior and it actualizes clearer normal position. Furthermore as for music mode vis-a-vis the usual stereo music software like the CD it is possible to actualize the stereophony effect which is superior
5 Neo:6
The matrix circuit which the DTS corporation developed. Maximum of channel 6 being extraction possible channel from 2 sound sources, there is a cinema mode for the soundtrack of the movie and a music mode in order to play back former stereo music.
6Cinema DSP
To the DTS and from Dolby digital monaural, plus doing the appearance impression like the cinema in all audio formats, the Yamaha individual sound field origination technology which it can reproduce. The DVD, it is optimum to all sources such as videotape and TV broadcast.
Main specification
Rated output (power amplifier section) at the time of main L/R operation 130W+130W (6, 20 - 20kHz and 0.015% THD) At the time of center operation 130W (6, 20 - 20kHz and 0.015% THD) At the time of rear L/C operation 130W+130W (6, 20 - 20kHz and 0.015% THD) At the time of rear center operation 130W (6, 20 - 20kHz and 0.015% THD) At the time of front effect operation 45W+45W (6, 20 - 20.000Hz and 0.05% THD) Utility installed capacity (EIAJ) at the time of main L/R operation 200W+200W (6, 1kHz and 10% THD) At the time of center operation 200W (6, 1kHz and 10% THD) At the time of rear L/C operation 200W+200W (6, 1kHz and 10% THD) At the time of rear center operation 200W (8, 1kHz and 10% THD) At the time of front effect operation 65W+65W (6, 1kHz and 10% THD) Dynamic power main L/R operational time 260W+260W (4) 360W+360W (2) Damping factor main L/R, center 200 (8, 20 - 20kHz SPEAKER-A) Input sensitivity / input impedance PHONO (mm) 2.5mV/47k CD other 150mV/47k Main L/R 1v/47k Maximum permissible input PHONO (mm) 100mV (1kHz and 0.1% THD) CD other things (EFFECT ON) 2.3v (1kHz and 0.5% THD) output voltage / output impedance REC OUT 150mV/600 PRE OUT 1.0V/1.2k (MAIN L/R, CENTER and REAR L/R/C) SUBWOOFER SPLIT 2.0V/1.2k MONO 4.0V/1.2k Headphone output / output impedance CD other input 150mV/100 (8, 1kHz and 40mV) Frequency characteristic CD other main 0/-3dB (10Hz - 100kHz) RIAA deviation PHONO (mm) 0 0.5dB (20 - 20kHz) Total height harmonic wave distortion factor PHONO (mm) -> PRE OUT 0.01% (20 - 20kHz, 1v) CD other things -> REC OUT main L/R 0.005% (20 - 20kHz, 1v) MAIN IN -> SP OUT L/C/R 0.008% (20 - 20kHz, 65w/6) Signal to noise ratio PHONO (mm) 86dB (input short 5mV SP OUT) CD other things (STEREO) 100dB (input short 250mV SP OUT) residual noise main L/R 150 mu V (SP OUT) channel separation PHONO (mm) 70dB/ XXGE 60dB (input short 1kHz/10kHz) CD other 70dB/ XXGE 60dB (input 5.1k short 1kHz/10kHz) Tone control quality Bass variable width 10dB (50Hz) Turn over frequency 350Hz Treble variable width 10dB (20kHz) Turn over frequency 3.5kHz center GEQ frequency 100/300/1k/3k/10kHz variable width 6dB Q 0.7 low-pass * filter quality SUBWOOFER fc=90Hz 24dB/oct. bus extension 6dB/60Hz cinema equalizer - High Shelving Filter frequency 1.0k - 12.7kHz variable width -9dB - 6dB Parametric Equalizer frequency 1.0k - 12.7kHz variable width -9dB - 6dB
DSP-AZ1 video section video signal system NTSC video signal 1vp-p/ 75 S video
signal Y: 1vp-p/ 75 C: 0.286vp-p/75 Component video signal Y: 1vp-p/ 75 Cb/Cr: 0.7vp-p/ 75 Maximum permissible input 1.5 Vp-p S/N 50dB monitor out frequency zone video / S video signal component video /D4 video signal 5hz - 10MHz - 3dB DC - 100MHz - 3dB The DSP-AZ1 input/output terminal input terminal analog aural signal 13 PHONO, the CD, the TUNER, the CD-R and the MD /TAPE, the DVD, the D-TV/LD, the CBL, the SAT and the VCR1, VCR2, VCR3/DVR, the VIDEO AUX digital aural signal optical 7 CD, the CDR, the DVD, the D-TV/LD, the SAT and the VCR3/DVR digital aural signal coaxial 3 CD, the DVD and the CBL AC3- RF 1 LD (as a same axis the assign possible) power amplifier input 5 main L/R, center, the front effect L/R composite image signal S image signal 8 DVD, the D-TV/LD, the CBL, the SAT and the VCR1, VCR2, VCR3/DVR, the VIDEO AUX component video 3 DVD, the D-TV/LD and the SAT D5- video 3 DVD, the D-TV/LD, SAT output terminal analog aural signal PRE OUT 8ch 8 terminal [ main L/R, center, rear L/R, rear center, front effect L/R ] sub woofer OUT 3ch [ SPLIT sub woofer L/R, REC OUT 5 VCR1, VCR2, VCR3/DVR, CDR and MD/TAPE ZONE2 OUT 1 digital aural signal light 2 CD-R, MD/TAPE MONITOR OUT composite image signal S image signal 2 component video 1 D5- video 1 REC OUT composite image signal S image signal 3 VCR1, VCR2, VCR3/DVR ZONE2 OUT composite 1 DSP-AZ1 comprehensive power source voltage AC 100V 50/60Hz electric power consumption 500W waiting electrical 1.4w AC outlet SWITCHED×3 100W MAX total size (height x width x depth) 435 (W) ×211 (H) ×473 (D) mm weight 28.0kg attachment remote control macro command, learning, pre-setting functional attaching and illuminating optical functional attachment The サDSP-AZ1 HiFi DSP (it corresponds to all input audio formats) the HALL 1 Hall A IN Europe Hall B IN Europe Hall C IN Europe HALL 2 Hall D IN U.S.A. Hall E IN Europe Live Concert CHURCH Tokyo Freiburg Royaumont JAZZ CLUB Village Gate Village Vanguard The Bottom Line ROCK CONCERT The Roxy Theatre Warehouse Loft Arena ENTERTAINMENT Disco Party 8ch Stereo The CINEMA DSP (it corresponds to all input audio formats) the ENTERTAINMENT Game CONCERT VIDEO 1 Pop/Rock DJ CONCERT VIDEO 2 Classical/Opera Pavillion TV THEATER Mono Movie Variety / the Sports MOVIE THEATER 1 Spectacle Sci-Fi MOVIE THEATER 2 Adventure General ENHANCED Enhanced Straight decoding (the program which does not do DSP sound field processing is) the DOLBY DIGITAL DOLBY DIGITAL Matrix 6.1 DTS DIGITAL SUR. DTS DIGITAL SUR. Matrix 6.1 (o'clock of DTS 96/24) DTS DIGITAL SUR. ES Matrix 6.1 DTS DIGITAL SUR. ES Discrete 6.1 DOLBY PRO LOGIC DOLBY PRO LOGIC II Movie/ Music DTS Neo:6 Cinema /Music AAC DIGITAL SUR. AAC DIGITAL SUR. Matrix 6.1 total 41
* Intel Core i7-6700K @ 4.8Ghz * Asus MAXIMUS VIII EXTREME* nVidia Asus Poseidon 1080Ti * Mushkin 16 GB * SSD Samsung M.2 2280 256GB + 3x Samsung 256GB 850Pro* Enermax Revolution85+ 1250W * CM Stacker 832 SE * Waretcooling CPU, NB ,VGA 3x Mora
  • Mr.David
  • Laatst online: 14-07 22:09
Ik heb 'm dinsdag avond gezien (in het echt). Ik kan je 1 ding vertellen hij ziet er echt HEEL bruut uit :9~ ,veel mooier dan op de plaatjes van 't internet. Jammer genoeg heb ik 'm niet kunnen horen want de AZ1 die ze hadden staan was een 110V versie :'( Het nadeel wat ik vind is dat hij alleen leverbaar is in zwart en goud en ik heb alles in titanium |:( (zie de foto)
Afbeeldingslocatie: http://www.endoria.net/upload/?bekijk=1014934525
[topic=376748/29/25] voor meer foto's...
Daarin tegen was de DSP-AX3200 wel in titanium leverbaar ook geen misselijk apparaat :+ .
Alle nieuwe modellen van Yamaha zijn op sterio gebied flink verbeterd, omdat uit onderzoek blijkt dat de consument de DD 'versterkers' meer voor 'gewone' muziek gebruiken (80% 'muziek' en 20% 'films') Eindelijk iemand die het door heeft...
Afbeeldingslocatie: http://www.endoria.net/upload/?bekijk=1351531448
De advies prijs voor de Yamaha DSP-AZ1 gaat 3250,- euro worden.
  • Duck-Twacy
  • Laatst online: 12-10 22:23
Duck-Twacy
I'm hit!
Hier vind je ook wat info
Btw. ga je nu 6 speakers bouwen :) ?
2 crush your enemies, 2 win the Tournament
  • JvS
  • Laatst online: 07:45
JvS
Ik heb hem zelf ook
woei, een cassettedeck :P
  • eXhale
:9~ :9~
En ik denken dat m'n DSP A1 stoer was :)
  • Duck-Twacy
Duck-Twacy
I'm hit!
Ik moet trouwens niet denken aan de AB van zo'n ding. Ik kom al nauwelijks uit de AB van mijn Yammie 620 (maar dat krijg je als je ouder wordt, heb ook moeite met de magnetron :D )
  • -Stef-
  • Laatst online: 09:37
-Stef-
Slainthe!
Op vrijdag 15 maart 2002 23:28 schreef Duck-Twacy het volgende:
Welke luidsprekers heb je bij die Yammie 620 als ik vragen mag?
Yamaha - Chario - MJ Acoustics - Squeezebox - Trends Audio - Beresford
  • Duck-Twacy
Duck-Twacy
I'm hit!
Op zaterdag 16 maart 2002 17:36 schreef -Stef- het volgende:
Deze
Afbeeldingslocatie: http://www.canton.de/www/images/products/en/movie4.jpg
  • -Stef-
-Stef-
Slainthe!
Op zaterdag 16 maart 2002 23:57 schreef Duck-Twacy het volgende:
Deze
Heb je die bewust in combinatie met de RX-V620 afgestemd of had je die al? Ik vraag dit omdat ik zelf zoekende ben naar een receiver icm luidsprekers. Zelf ben ik erg gecharmeerd van de Chario's 100/200T en wil deze bij een 620 kopen. Wat zie ik vandaag? Hebben de jongens van Yamaha hard doorgewerkt en een aantal nieuwe receivers aan hun programma toegevoegd. Dolby Pro Logic II en 6.1 enz. Alsof het al niet moeilijk was een keuze te maken. :)
  • Duck-Twacy
Duck-Twacy
I'm hit!
Op zondag 17 maart 2002 00:08 schreef -Stef- het volgende:
Niet echt, ik gebruik die Yamaha alleen voor films (DVD) en een beetje MP3 (achtergrond) en daar ben ik niet zo kritisch op. De Cantons zijn niet slecht, maar voor muziek had ik beter iets mildere speakers kunnen kopen (Dynaudio, bv).
Ik heb alles gekocht in Duitsland met flinke korting. Voor muziek (stereo) gebruik ik andere apparatuur en speakers (zelfbouw).
Je moet nu natuurlijk voor de nieuwe Yamaha's gaan, lijkt me (hoewel het oude model misschien nu nog goedkoper zal worden)
Suc6
edit. Ik weet niet in welke prijsklasse je iets zoekt, maar ik zie dat ze bij http://www.mediacheckpoint.de nu de Yamaha RXV1200 aanbieden voor 799 euro, best redelijke prijs volgens mij.
Afbeeldingslocatie: http://www.mediacheckpoint.de/isroot/mediacheckpoint/Produktbilder/68rxv1200.jpg
alleen in t zwart, geloof ik
Misschien heb je interesse in mijn 620, zeg voor 400 euro :)
  • -Stef-
-Stef-
Slainthe!
Op zondag 17 maart 2002 00:51 schreef Duck-Twacy het volgende:
Suc6
Ja ik had de RVX 1200 ook al daar gezien. Scheelt best genoeg om daar iets te bestellen. Ik zocht het zo tot rond die prijs van 800 euro voor een receiver. Luidsprekers gaan tot zo'n 300 euro per stuk. Ik heb een rekbaar budget dus staar me niet echt blind op de prijs. Het moet echter wel leuk blijven aangezien er ook nog wat andere aankopen op mijn lijstje staan. :)
