[Winamp] Playlist in PHP Dbase probleem
  • 65 views sinds 30-01-2008
Hallo Tweakers,
Ik probeer mijn winamp playlist in php te krijgen zodat mensen kunnen stemmen welk nummer er draait.
Dit heb ik gedaan door middel van dit topic:
[topic=188484/1/50]
Nu wil het feit dat mn Mysql Database (heb al gedowngrade van 4 alpha om zeker te weten dat het niet aan de database ligt.) gigantisch zit te bokken.
Ik krijg steeds deze error:
http://www.atteveld.cistron.nl/mp3.JPG
Dit is mn index.php
PHP:
<?     //    // MP3vote (Freeware) by Michel Arendsen, 2001 < michel@arendsen-webdevelopment.nl >   //  It is a bit of a mess, but it works ;)  //include("conf.php");$conn = mysql_connect($dbserver, $dbuser, $dbpasswd);function give_me_next() {global $conn, $db;       $pquery = "select * from playlist where (votes <> 0) order by votes desc, pid asc limit 1";        $presult = mysql_db_query($db, $pquery);      $counti = mysql_numrows($presult);        if ($counti<>0) {        $p = mysql_fetch_array($presult);                $pid = $p["pid"];                $title = $p["title"];            echo "$pid: $title";                } else {            echo "No votes: Playing random";            }}echo "<html>";echo "<title>MP3vote</title>";echo "</head>";echo "";echo "<body link=\"#000080\" vlink=\"#000080\" alink=\"#000080\">";echo "";if (!isset($wat)) {echo "<font face=\"Verdana\"><h2>MP3vote v1.1-beta</h2></font>";echo "<font size=\"2\" face=\"Verdana\">";check_if_running();echo "Now playing: <b>'";include("$urlPlay?wat=track"); [b]REGEL 44[/b]// Try this of the include fails??//$fp = fopen("$urlPlay?wat=track","r");//$fp2 = fgets($fp, 4096);//echo "$fp2";echo "'</b><br>Next: '";echo give_me_next();echo "'<br><a href='list.php'>Voted playlist</a></font><br><br>";echo "  <table border=\"0\" width=\"464\" height=\"33\">";echo "    <tr>";echo "      <td width=\"19\" height=\"11\" bgcolor=\"#C0C0C0\"><b><font size=\"2\" face=\"Verdana\">ID</font></b></td>";echo "      <td width=\"344\" height=\"11\" bgcolor=\"#C0C0C0\"><b><font size=\"2\" face=\"Verdana\">&amp;nbsp;<a href='index.php?order=title'>Title</a></font></b></td>";echo "      <td width=\"79\" height=\"11\" bgcolor=\"#C0C0C0\"><font size=\"2\" face=\"Verdana\"><b><a href='index.php?order=rank'>Vote</a></b></font></td>";echo "    </tr>";if (!isset($order)) {    $pquery = "select * from playlist order by pid";} else if ($order=="rank") {    $pquery = "select * from playlist order by votes desc";} else if ($order=="title") {    $pquery = "select * from playlist order by title";}    $presult = mysql_db_query($db, $pquery);    if ($presult) {    while ($p = mysql_fetch_array($presult)) {        $pid = $p["pid"];        $title = $p["title"];echo "    <tr>";echo "      <td width=\"19\" height=\"10\"><font size=\"2\" face=\"Verdana\">$pid</font></td>";echo "      <td width=\"344\" height=\"10\"><font size=\"2\" face=\"Verdana\">$title</font></td>";echo "      <td width=\"79\" height=\"10\"><font size=\"2\" face=\"Verdana\">[<a href=\"index.php?wat=vote&amp;id=$pid\">vote</a>]</font></td>";echo "    </tr>";    }}echo "  </table>";}if ($wat=="vote" &amp;&amp; isset($id)) {mysql_connect($dbserver, $dbuser, $dbpasswd);    $pquery = "select * from playlist where pid = '$id'";    $presult = mysql_db_query($db, $pquery);    if ($presult) {    while ($p = mysql_fetch_array($presult)) {        $pid = $p["pid"];        $title = addslashes($p["title"]);        $votes = ($p["votes"])+1;        $squery = "select vid from votes where title='$title' and ip='$REMOTE_ADDR' and DATE_ADD(datum, interval $min_vote MINUTE) > now()";        $sresult = mysql_db_query($db, $squery);          $counts = mysql_numrows($sresult);            if ($counts==0) {            $query = "update playlist set votes='$votes' where pid='$pid'";            $result = mysql_db_query($db, $query);            $datum = date("Y-m-d H:i:s");            $iquery = "insert into votes values(NULL, '$title', '$REMOTE_ADDR', '$datum')";            $iresult = mysql_db_query($db, $iquery);            if ($result) {                echo "<font size=\"2\" face=\"Verdana\">Your vote has been processed...<br>Total vote count for '$title' is $votes</font>";            }        } else {                echo "<font size=\"2\" face=\"Verdana\"><b>Sorry</b>, you are not allowed to vote more times in $min_vote minutes for the same song.</font>";        }       }    }    echo "<br><br>[<a href='index.php'>terug</a>]";}echo "<p align='right'><font size=\"1\" align='right' face=\"Verdana\">MP3vote - &amp;copy M. Arendsen, 2001</font></p>";echo "</body>";echo "";echo "</html>";?>
Weet iemand wat ik hier aan kan doen?
Bedankt :)
  • Grum
de manual lezen ...
bestaat het bestand wat je wil include ?
waarom include je het in godsnaam via http ?
Je meent het ;) . Die lees ik echt wel hoor :) Maar bedankt voor je super solution ;)
play.php kannie niet vinden? Lijkt me dat ie die op een verkeerde lokatie loopt te zoeken. (namelijk in je webspace, ipv op je hdd). $urlPlay heb je volgens mij als:
[url="http://localhost/mp3/play.php"]http://localhost/mp3/play.php[/url] ofzow?
Probeer es $urlPlay="play.php"
  • Grum
ach als je de manual had gelezen dan kan je een http adres opgeven maar je krijgt de GEPARSED pagina terug dus je hebt er waarschijnlijk geen FUCK aan.
zucht ...
Woei die werkt :). Nu zit er nog een fout in mn vote.php maar die ga ik aanpassen :)
ff kijken naar je foutmeldingen helpt enorm he... dit had je natuurlijk ook zelf kunnen bedenken >:) Maar goed, ik ben in een vriendelijke bui ;)
  • D2k
  • Laatst online: 31-08 10:19
D2k
maaruh we benne hier eik niet van de debug club
Doet iets met Cloud (MS/IBM)
