harddisk trubles
  • 38 views sinds 30-01-2008
ik heb wat problemen met mijn hdd; ik vraag me alleen een beetje af of het aan de controller of aan de schijf ligt - misschien is er iemand die wat op kan maken uit de (linux)foutberichten
Mar 14 18:53:54 trepper kernel: hda: dma_intr: status=0x51 { DriveReady SeekComplete Error }
Mar 14 18:53:54 trepper kernel: hda: dma_intr: error=0x04 { DriveStatusError }
Mar 14 18:53:54 trepper kernel: hda: recal_intr: status=0x51 { DriveReady SeekComplete Error }
Mar 14 18:53:54 trepper kernel: hda: recal_intr: error=0x04 { DriveStatusError }
Mar 14 18:53:54 trepper kernel: hda: DMA disabled
Mar 14 18:54:03 trepper kernel: ide0: reset: success
Mar 14 18:55:57 trepper kernel: hda: irq timeout: status=0x90 { Busy }
Mar 14 18:56:02 trepper kernel: ide0: reset: success
Mar 14 18:56:44 trepper kernel: spurious 8259A interrupt: IRQ7.
Mar 14 18:56:47 trepper kernel: hda: status timeout: status=0x90 { Busy }
Mar 14 18:56:47 trepper kernel: hda: drive not ready for command
Mar 14 18:56:48 trepper kernel: ide0: reset: master: error (0x00?)
Mar 14 18:56:48 trepper kernel: hda: status error: status=0x00 { }
Mar 14 18:56:48 trepper kernel: hda: drive not ready for command
Mar 14 18:56:54 trepper kernel: ide0: reset: success
Mar 14 18:58:14 trepper kernel: hda: status timeout: status=0x90 { Busy }
Mar 14 18:58:14 trepper kernel: hda: drive not ready for command
Mar 14 18:58:19 trepper kernel: ide0: reset: success
Mar 14 18:59:54 trepper kernel: hda: irq timeout: status=0xd0 { Busy }
Mar 14 19:00:24 trepper kernel: ide0: reset timed-out, status=0xd0
Mar 14 19:00:24 trepper kernel: hda: status timeout: status=0xd0 { Busy }
Mar 14 19:00:24 trepper kernel: hda: drive not ready for command
Mar 14 19:00:28 trepper kernel: ide0: reset: success
Mar 14 19:03:28 trepper kernel: hda: write_intr error1: nr_sectors=1, stat=0x51
Mar 14 19:03:28 trepper kernel: hda: write_intr: status=0x51 { DriveReady SeekComplete Error }
Mar 14 19:03:28 trepper kernel: hda: write_intr: error=0x04 { DriveStatusError }
Mar 14 19:03:28 trepper kernel: hda: recal_intr: status=0x51 { DriveReady SeekComplete Error }
Mar 14 19:03:28 trepper kernel: hda: recal_intr: error=0x04 { DriveStatusError }
Mar 14 19:03:36 trepper kernel: ide0: reset: success
Als je het zo bekijkt denk je: harddisk. Nou is het zo dat de andere schijf die in mijn bak zit de laatste tijd ook vaag doet; kan natuurlijk toeval zijn, maar voordat ik naar de winkel ren...
output van cat /proc/hda/settings :
name value min max mode
bios_cyl 2482 0 65535 rw
bios_head 255 0 255 rw
bios_sect 63 0 63 rw
breada_readahead 4 0 127 rw
bswap 0 0 1 r
current_speed 66 0 69 rw
failures 0 0 65535 rw
file_readahead 0 0 2097151 rw
ide_scsi 0 0 1 rw
init_speed 66 0 69 rw
io_32bit 0 0 3 rw
keepsettings 0 0 1 rw
lun 0 0 7 rw
max_failures 1 0 65535 rw
max_kb_per_request 127 1 127 rw
multcount 0 0 8 rw
nice1 1 0 1 rw
nowerr 0 0 1 rw
number 0 0 3 rw
pio_mode write-only 0 255 w
slow 0 0 1 rw
unmaskirq 0 0 1 rw
using_dma 0 0 1 rw
Ik hoop dat iemand hier een antwoord voor heeft, heb hetzelfde probleem. Ik heb elk stukje hardware in het systeem vervangen en de meest uiteenlopende kernel configuraties gebruikt, het probleem blijft.
Ik wordt er haast moedeloos van, het gaat om een server op debian 3.0.
  • BalusC
BalusC
Carpe diem
Lees eens de FAQ Opslagmedia & I/O Controllers (09-02-2003) onder het kopje "mijn harddisk doet vaag" :)
Mocht je er nog niet uitkomen, open dan een nieuw topic met alle relevante informatie, zoals de mobo/HDD specificaties, alles wat je zelf had geprobeerd (maar dan duidelijker en specifieker), etc.
