[WINXP] Route adden?
Hoe add ik een route naar me andere pc die ook op internet zit via een hub waar mijn pc ook aan zit maar de computers kennen elkaar niet bedanderen :( k zit in 2 subnets ook nog:(
is het dan uberhuabt wel mogelijk?
  • warp
start > run > cmd > route add 'bla'
H:\>route
Manipulates network routing tables.
ROUTE [-f] [-p] [command [destination]
[MASK netmask] [gateway] [METRIC metric] [IF interface]
-f Clears the routing tables of all gateway entries. If this is
used in conjunction with one of the commands, the tables are
cleared prior to running the command.
-p When used with the ADD command, makes a route persistent across
boots of the system. By default, routes are not preserved
when the system is restarted. Ignored for all other commands,
which always affect the appropriate persistent routes. This
option is not supported in Windows 95.
command One of these:
PRINT Prints a route
ADD Adds a route
DELETE Deletes a route
CHANGE Modifies an existing route
destination Specifies the host.
MASK Specifies that the next parameter is the 'netmask' value.
netmask Specifies a subnet mask value for this route entry.
If not specified, it defaults to 255.255.255.255.
gateway Specifies gateway.
interface the interface number for the specified route.
METRIC specifies the metric, ie. cost for the destination.
All symbolic names used for destination are looked up in the network database
file NETWORKS. The symbolic names for gateway are looked up in the host name
database file HOSTS.
If the command is PRINT or DELETE. Destination or gateway can be a wildcard,
(wildcard is specified as a star '*'), or the gateway argument may be omitted.
If Dest contains a * or ?, it is treated as a shell pattern, and only
matching destination routes are printed. The '*' matches any string,
and '?' matches any one char. Examples: 157.*.1, 157.*, 127.*, *224*.
Diagnostic Notes:
Invalid MASK generates an error, that is when (DEST & MASK) != DEST.
Example> route ADD 157.0.0.0 MASK 155.0.0.0 157.55.80.1 IF 1
The route addition failed: The specified mask parameter is invalid.
(Destination & Mask) != Destination.
Examples:
> route PRINT
> route ADD 157.0.0.0 MASK 255.0.0.0 157.55.80.1 METRIC 3 IF 2
destination^ ^mask ^gateway metric^ ^
Interface^
If IF is not given, it tries to find the best interface for a given
gateway.
> route PRINT
> route PRINT 157* .... Only prints those matching 157*
> route DELETE 157.0.0.0
> route PRINT
Suc6 ;)
Hey Dannyke,
Ik zie dat je al keurig het OS tussen de tags hebt gezet, ik mis alleen het onderwerp nog :)
De huidige topictitel geeft niet duidelijk aan waar het topic over gaat. Als je de volgende keer hier even aan denkt dan is je topictitel perfect *D
Zie ook: [topic=331522/1/25] stap 3.
Op donderdag 14 maart 2002 13:35 schreef Dannyke het volgende:
My Network Places
Setup small business or home network o.i.d.
FF draaien op alle pc's
Op de clients IE FF instellingen automatisch detecteren en klaar.
  • Han
Han
--> [forum=19]
En titel aangepast @ Havana ;)
  • warp
Op donderdag 14 maart 2002 13:40 schreef computeraap het volgende:
My Network Places
FF draaien op alle pc'sOp de clients IE FF instellingen automatisch detecteren en klaar.
En wat heeft dit precies met een route toevoegen te maken :?
k bedoel dus ff dat ik gewoon mijn andere xp machientje kan pingen enzo :-)
  • warp
Op donderdag 14 maart 2002 14:10 schreef Dannyke het volgende:
:D :D :D
Nja, HowTo.. zie mijn reply boven ;)
dat vertikt die dus omdat ik 2 verdomde subnets heb en 2 verschillende gateway iptjes :(
