De code:
test.php
test2.php:
Het probleem:
in test 2 geeft hij de variable niet aan
hoe kan dit nou weer???
wat doe ik fout....
test.php
PHP:
| <? session_start(); include("../unio/incl/var.inc.php"); mysql_connect("$db_hostname", "$db_user", "$db_password") or die ("GVD"); mysql_select_db("$db_name"); function login_form() { print("<form name=login_form method=get action=$PHP_SELF>"); print("<input type=text name=u_name><br>\n"); print("<input type=text name=u_pass><br>\n"); print("<input type=submit value=login>\n"); } function login_check($u_name, $pass) { $check_q="SELECT id, type, pass FROM user WHERE name=\"$u_name\""; $check_r=mysql_query($check_q); list($u_id, $u_type, $u_pass) = mysql_fetch_row($check_r); print("<b>Doorgegeven:</b> \$u_name = $u_name <br> \$pass = $pass <br>\n"); print("<b>Gekregen van db:</b> \$u_id=$u_id \$u_type=$u_type \$u_pass = $u_pass"); if ($pass == $u_pass) { $blaat = "blaat"; session_register("blaat"); session_register("u_id"); session_register("u_type"); } } login_form(); print("<br><br>\n"); login_check($u_name, $u_pass); $sid=session_id(); print("<br>naar pagina <a href=test2.php>2</a>");?> |
test2.php:
PHP:
| <?session_start();echo $HTTP_SESSION_VARS["u_id"];echo $HTTP_SESSION_VARS["u_type"];echo $HTTP_SESSION_VARS["blaat"];?> |
Het probleem:
wat doe ik fout....
