Ik heb het even nagekeken op de AMD website bij de techdocs. Daar staat het volgende over de Duron (die trouwens een standaardvoltage heeft van 1,6 ipv 1,5 dat de KT7 aangeeft):
For information about thermal design, including layout and
airflow considerations, see the AMD Thermal, Mechanical, and
Chassis Cooling Design Guide, order# 23794 and the cooling
guidelines on www.amd.com. Table 2 shows the thermal design
power. The thermal design power represents the maximum
sustained power dissipated while executing publicly-available
software or instruction sequences under normal system
operation at nominal VCC_CORE. Thermal solutions must
monitor the processor temperature to prevent the processor
from exceeding its maximum die temperature. The maximum
die temperature is specified through characterization at 90C.
Table 2. Thermal Design Power
Frequency
(MHz) Voltage Maximum Thermal
Power
Typical Thermal
Power
600
1.6 V
26.07 W 23.40 W
650 27.87 W 25.02 W
700 29.66 W 26.63 W
750 31.46 W 28.25 W
Sorry voor de fucked up lay-out (copy-paste vanuit PDF) maar nu weet iedereen dat ze de Duron veilig tot 80-85 graden op kunnen jagen!
Success oc'ers!
Frequency
Power
Typical Thermal
Power
600
1.6 V
26.07 W 23.40 W
650 27.87 W 25.02 W
700 29.66 W 26.63 W
750 31.46 W 28.25 W
Success oc'ers!
