[MOHAA] DD server configutatie
  • 334 views sinds 30-01-2008
Mijn vorige bericht werd gelockt :? Maar goed.
Ik start via deze snelkoppeling, een server op:
"C:\Program Files\EA GAMES\MOHAA\MOHAA.EXE" +set dedicated 1 +set ui_console 1 +set g_gametype 1 +set sv_maxclients 12 +map dm/mohdm1 +exec server01.cfg
Mijn CFG file ziet er als volg uit:
// General Server Info Settigns
seta sv_hostname "Dutch FUBAR's Server 1.1"
sets Admin "None"
sets Email "btud@hotmail.com"
sets Location "NL"
seta g_motd "Welcome to FUBAR's place"
sets URL "http://dutchfubar.clanpages.com"
sets Connection "10 Mbit"
sets username "None" // Hide user accountname which started mohaa
// Map rotation
seta sv_maplist "dm/mohdm3 dm/mohdm4 dm/mohdm2 dm/mohdm1 dm/mohdm5 dm/mohdm6 dm/mohdm7"
// Server Setings
seta sv_privatePassword "" // Doesn't seem supported in MoH:AA
seta sv_privateClients "" // Doesn't seem supported in MoH:AA
seta sv_maxclients "12"
seta rconpassword "xxxxx" // Remote Control (rcon) password
seta sv_fps "20"
seta sv_timeout "120"
seta sv_pure "1"
seta sv_gamespy "0" // Show our server in gamespy
seta sv_allowdownload "1" // Allow clients to download paks of our server
seta sv_maxrate "8000"
seta sv_floodProtect "1"
seta sv_minping "0"
seta sv_maxping "0"
seta sv_precache "1"
// Master Server Settings - Redudant for normal operation
//seta sv_master1 "mohmaster.2015.com"
//seta sv_master2 "master0.gamespy.com"
//seta sv_master3 "master1.gamespy.com"
//seta sv_master4 "clanservers.net"
// Generic map settings
//seta g_doWarmup "1" // Doesn't seem supported in MoH:AA
//seta g_warmup "20"
seta g_allowvote "1"
seta g_gametype "2"
seta g_teamdamage "0"
seta g_teamForceBalance "1"
//seta g_smoothClients "1"
// Start with the map rotation
map dm/mohdm3
Toch krijg ik bij het opstarten de melding dat hij de CFG niet executen en een rare "Hitch Ping" melding.
Wat is hier fout aan of voor verbetering vatbaar?
Zo weinig mensen met een MOHAA server :z
check deze site maar eens
http://www.alliedassault.com/community/guides/bull/
hier staat precies wat je nodig hebt
Dank je voor de URL. Ik was er al geweest en bekeken, maar zelfs toen kwanm ik er ook niet uit.
Ik wil verder ook met Nederlanders in contact komen, die een DD MOHAA server draaien. Voor uitwisseling. Mooi plek hier voor, toch?
huh???????/
IK heb door middel van deze site mijn DD server opgezet en het draait prima.
Dus ik snap niet echt wat het probleem nou is :?
goed hier even een opsomming voor je:
seta g_motd "Welcome to FUBAR's place" Dit word zover men weet niet ondersteund in MOH
seta sv_fps "20" Deze zou ik op 15 zetten
seta sv_maxping "0" Deze zou ik ook zeker invullen
En dit is nog maar het begin. Ik zal vanavond als ik thuis ben mijn CFG files eens posten dan kan je zien wat er fout is aan je CFG :)
Ik wacht 8-)
sv_hostname "Killing Grounds MOH version 1.1"
sv_maplist "obj/obj_team4 obj/obj_team2 obj/obj_team1 obj/obj_team3"
sv_allowDownload 1
sv_maxRate 8000
sv_pure 0
sv_fps 15
sv_maxPing 175
sv_floodProtect 1
//flood_waitdelay 10
//flood_persecond 4
//flood_msgs 4
fraglimit 15
timelimit 45
set g_minGameClients "1"
set g_teamdamage 1
set g_inactiveKick 300
set g_inactiveSpectate 60
//g_showbullettrace 1
net_noipx 1
net_port 12203
rconpassword "jouw wachtwoord"
  • blouweKip
  • Laatst online: 12-09 21:42
Hoe zit het eigenlijk met de mohaa server (en client) voor Linux?
Het porten van dit spel naar linux kan nooit veel moeite kosten (ik draai het al voor 90% goed op linux met wine)..
Ik wil best een server opzetten (ik heb een redelijke verbinding dus 6vs6 oid kan wel), maar ik vind het onzin om een extra pc met windows als server te moeten gebruiken terwijl er hier een mooie linux server staat die het prima kan en nu de meeste tijd uit zn neus zit te eten.
"For my friends, anything; for my enemies, the law."
Wouter76 schreef:
Hier even een erg vaag probleem:
Een vriend van mij draait een dedicated MoH server (1.1 US English) voor onze clan. Alle andere 5 clanleden kunnen prima op deze server spelen. Echter wanneer ik connect en ga spelen lig ik er altijd binnen 15 seconden weer af, de server disconnect mij dus steeds. Het vreemde is dat ik daar op andere public internetservers echt nooit last van heb.
Extra info: de server maakt gebruik van een Chello abo en ik ook. De ping is goed te noemen (50), tenminste voor zolang ik er op zit. Zowel de server als mijn client-pc hangen via een router aan het internet.
Heeft iemand enig idee wat de oorzaak zou kunnen zijn van het feit dat ik er steeds afgemieterd wordt en anderen niet?
Ik ben dus die vriend en ik snap het ook niet.
En dit is niet met 5 tegelijk, dit gebeurd ook wanneer we er met z'n tweeen op willen spelen.
Wie kan helpen :?
wat staat er allemaal in de CFG file?
Dit is de shortcut:
"E:\Mohaa [FSF]I\MOHAA.exe" +set dedicated 1 +set g_gametype 2 +set net_port 12204 +set sv_maxclients 8 +exec server.cfg
Dit is de config van de server
set sv_hostname "[FSF]I Mohaa v1.10"
set sv_maplist "dm/mohdm2 dm/mohdm3 dm/mohdm4"
set sv_allowDownload 0
set sv_maxrate 8000
set rate 8000
set sv_fps 40
set com_maxfps 40
set sv_pure 0
set sv_gamespy 0
set deathmatch 1
set snaps 20
set fraglimit 100
set timelimit 20
set g_allowvote 1
set g_inactiveSpectate 120
set g_teamdamage 0
map dm/mohdm3
wat zij de server commands van alle levels ? zoals DM/mohdm1 bijvoorbeeld maar dan van objective
  • Bezulba
  • Laatst online: 13-10 12:24
Bezulba
Formerly known as Eendje
Op vrijdag 15 maart 2002 01:07 schreef blouweKip het volgende:
client zal iig nooit naar linux komen... daar valt geen droog brood mee te verdienen... maar een serverversie komt er wel aan (ooit is)
blup
