Meer geheugen in Pentium 4
  • 204 views sinds 30-01-2008
  • Quaker
  • Laatst online: 30-11-2021
Ik heb een pentium 4 1400 Mhz met 256 RD RAM pc800 geheugen
heeft het zin om dit up te graden met 2 blokjes van 256 MB?
Ik draai er games op als RtCW, MoH:AA, Quake 3, CS, UT
en WinXP
OS NameMicrosoft Windows XP Professional
Version5.1.2600 Build 2600
OS Manufacturer Microsoft Corporation
System Manufacturer System Manufacturer
System Model System Name
System Type X86-based PC
Processor x86 Family 15 Model 0 Stepping 7 GenuineIntel ~1395 Mhz
BIOS Version/Date Award Software, Inc. ASUS P4T-M ACPI BIOS Revision 1004, 16-7-2001
SMBIOS Version 2.3
Windows Directory C:\WINXP
System Directory C:\WINXP\System32
Boot Device \Device\HarddiskVolume1
Locale Netherlands
Hardware Abstraction Layer Version = "5.1.2600.0 (xpclient.010817-1148)"
Time ZoneW. Europe Standard Time
Total Physical Memory 256,00 MB
Available Physical Memory 35,56 MB
Total Virtual Memory 874,17 MB
Available Virtual Memory 431,57 MB
Page File Space 618,71 MB
Page File C:\pagefile.sys
DISPLAY DRIVER
NameGM3000 (GeForce2 MX 100/200)
PNP Device IDPCI\VEN_10DE&DEV_0111&SUBSYS_6107147B&REV_B2\4&252D6E8&0&0008
Adapter TypeGeForce2 MX 100//200, NVIDIA compatible
Adapter DescriptionGM3000 (GeForce2 MX 100/200)
Adapter RAM32,00 MB (33.554.432 bytes)
Installed Driversnv4_disp.dll
Driver Version6.13.10.2770
INF Fileoem5.inf (nv4_novpe section)
Color Planes1
Color Table Entries4294967296
Resolution1024 x 768 x 60 hertz
Bits/Pixel32
Memory Address0xEE000000-0xEFDFFFFF
Memory Address0xF0000000-0xF7FFFFFF
IRQ ChannelIRQ 11
I/O Port0x000003B0-0x000003BB
I/O Port0x000003C0-0x000003DF
Memory Address0xA0000-0xBFFFF
Driverc:\winxp\system32\drivers\nv4_mini.sys (6.13.10.2770, 866,29 KB (887.085 bytes), 2-3-2002 18:39)
  • 8088
NaN
Afhankelijk van de applicaties die je draait : ja.
The Flat Earth Society has members all around the globe.
  • Abbadon
  • Laatst online: 20-11 23:33
Ja, het kan nooit kwaad nee (ik zou welhaast 'duh' willen zeggen ;) ) maar wat doe je met jouw bak, wat draait er allemaal op? En wat is je huidige ram verbruik?
  • BalusC
BalusC
Carpe diem
Als WinXP eenmaal draait en je de dagelijkse applicaties gebruikt, dan raakt je huidige 256MB best wel snel vol. Al helemaal als je ook nog gaat gamen. Dus ja, het is het waard om extra geheugen bij te prikken :)
  • Quaker
En is het ook de moeite waard om op beter RAMBUS te wachten pc4200 ofzoiets?
Een pentium 4 heeft nu eenmaal een langere pipeline, dus wanneer er meer in het geheugen staat, kan hij dit sneller bereiken dan vanaf een harde schijf.
Meer geheugen heeft dus meer nut, aangezien de pentium 4 helaas met de huidige applicaties (lees PIII en AMD :P optimized ), eigenlijk soms het verkeerde in zijn pipeline zuigt en deze dan soms helemaal moet legen en weer opnieuw moet vullen.
BTW, tis absoluut geen intel vs. amd flame :)
AUW, wat is dat RIMM geheugen trouwens duur zeg, best wel jammerzzzz :(
  • WiXX
  • Laatst online: 06-11 14:47
WiXX
Kijk uit malloot een...
Ik heb nu 640 in mn p4 bak liggen, en het werkt super beter als een andere p4 bak met 256 die ik hier heb staan
  • Quaker
oke dan ga ik er 2 reepjes van 256 MB pc800 in stoppen
  • Quaker
Op zaterdag 09 maart 2002 22:28 schreef DragonLord het volgende:
Ja en 512 MB is naar verhouding duurder dan 256 MB
Op zaterdag 09 maart 2002 22:38 schreef Quaker het volgende:
MMh, zal wel liggen omdat die chippies nog wat moeilijker verkrijgbaar zijn wat als gevolg heeft dat de prijzen hoger liggen.
helaas heeft www.mci.de geen RIMM moduletjes, dit bedrijfje in duitsland heeft anders wel interessante modules.
Goed getest en goedgeprijsd :9~
  • viper3007
  • Laatst online: 07-11 11:41
Dat ligt er helemaal aan wat voor applicaties je draait of wilt gaan draaien.
Als je gewoon standaard office applicaties gaat draaien met een beetje surfen zo ik je het niet aanraden.
als je echt videobewerking en andere heftige proggies gaan draaien.
Is het eigenlijk bijna verplicht hiervoor.
videobewerking: advies 2x 512 mb rambus geheugen.
8-)
workstation server laptop
  • AlPha.BeYoNdeR
  • Laatst online: 04-05 16:07
Ik zou eerder denken aan een betere processor of video (weet niet wat je nu hebt)
Want je huidige processor is vast zo'n socket 423 1,4 Ghz P4 en die zijn traaag :r
Upgrade naar een 1,8 Nortwood ofzo en die dan op 2,6 GHz zetten.
Kijk ook naar je videokaart.. Een Geforce 4 Ti4400 of een Radeon 8500 geeft ook vet veel verschil.
(als je serious gamer bent natuurlijk ;) )
als je geld hebt en je wilt het aan je pc uitgeven zou ik idd meer geheugen kopen.
ik weet verder je specs niet maar dat zal dan wel allemaal goed zitten :?
  • Jivecar
  • Laatst online: 12-11-2025
Op zondag 10 maart 2002 11:51 schreef AlPha.BeYoNdeR het volgende:
Northwood means socket 478 |:(
Wordt toch moeilijk met een 423 mobo.......
Intel P4D-2800@2800, Asus P4P800-SE, 1024MB Corsair, Asus v9999/TD, Maxtor DiamondMax 10 250GB, Western Digital 600BB 60GB, Pioneer DVDR, HP 9150, Soundblaster Audigy. + Toshiba E400......
  • Jivecar
Op zaterdag 09 maart 2002 21:43 schreef Quaker het volgende:
en WinXP
SMBIOS Version 2.3
Locale Netherlands
DISPLAY DRIVER
Color Planes1
Bits/Pixel32
IRQ ChannelIRQ 11
Voor de games:
Neem svp een andere videokaart.....deze kan dus echt niet. De MX200 is dus het budgetkaartje van nvidia, geen wonder als spellen niet supergoed lopen. Neem op z'n minst een mx400.....
  • BlizzarD
BlizzarD
Hooooooh
Koop eerst een betere videokaart, dan pas 256mb erbij prikken. Dat merk je veel beter met games
iStockphoto
  • Tyrian
Tyrian
It's Unreal.
Een upgrade naar 512 MB is zeker nuttig, 768 MB is misschien wat overkill, maar dan ben je wel voorbereid op de toekomst.
Wat de games betreft: Een nieuwe videokaart (Radeon 8500 / GeForce 3 / GeForce 4) is een zinnigere upgrade.
http://www.hypercoop.tk | GW user page | GW2 user page
Specs
Ik heb er hier 768 mb inzitten keek net ff in het taakbeheer.
totaal 768mb ram
beschikbaar 613 mb ram
systeemcache 153mb ram
Het voordeel is dat je pagefile kan uitschakelen.Verder zie ik niet veel voordeel.
Ps.zo goedkoop vind ik dat duitse mci niet hoor.
