Nero foutmelding :S
Ik krijg bij het branden van ELKE cd...
de volgende melding...
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
Windows NT 5.0
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1020), size=45056 bytes, created 15-7-1999 13:06:00
ahead WinASPI: File 'D:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2, 0, 0, 11, size=143427 bytes, created 9-3-2002 8:54:00
Nero Version: 5.0.0.3
Recorder:        <YAMAHA CRW4416S>     Version: 1.0e - HA 3 TA 3 - 5.0.0.3
 Adapter driver:    <symc8xx>            HA 3
 Drive buffer  :    2048kB
CD-ROM:        <PLEXTOR  CD-ROM PX-40TS> Version: 1.00 - HA 3 TA 2
NT Autorun = 0x00000000
CmdQueuing     : 1
CmdNotification: 2
WriteBufferSize: 20971520 (0) Byte
ShowDrvBufStat : 0
EraseSpeed     : 0
BUFE         : 0
Physical memory     : 127MB (130612kB)
Free physical memory: 14MB (14512kB)
Memory in use    : 88 %
Uncached PFiles: 0xFF
Wizard: On
CD-ROM (ISO)
9.3.2002
9:29:57 #1 Text 0 File BusArbiter.cpp, Line 82
    bus arbitration:     bus type    category
                     SCSI      0
                    unknown  1
                     other    2
                     IDE        3
    drives from category 1 and 3 competition level 1
    stall writers at 95%, reactivate at 70%
9:29:58 #2 Text 0 File Reader.cpp, Line 75
    Reader running
9:29:58 #3 Text 0 File Writer.cpp, Line 87
    Writer YAMAHA CRW4416S running
9:29:58 #4 ISO9660GEN -11 File geniso.cpp, Line 3236
    First writeable address = 0 (0x00000000)
9:29:58 #5 Text 0 File BusArbiter.cpp, Line 821
    Sat Mar 09 09:29:58 2002
    YAMAHA CRW4416S: Register
    arbitration disabled
    n. category bus drive writer name
    0.     0     3    3    yes   YAMAHA CRW4416S
    i
    r
9:29:59 #6 Text 0 File ThreadedTransferInterface.cpp, Line 622
    Setup items (original item values)
     0: TRM_DATA_MODE1 (CTransferItem)
        2 indices, index0 (150) not provided
        original CD pos #0 + 324101 (324101) = #324101
        relocatable, CD pos for caching/writing not required/required, no patch infos
9:30:02 #7 Text 0 File ThreadedTransferInterface.cpp, Line 754
    Prepare recorder YAMAHA CRW4416S for write in TAO
    DAO infos:
    MCN:
    TOCTYPE: 0x0   Close Session
    Tracks 1 to 1:
       TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 664066048
9:30:02 #8 Text 0 File ThreadedTransferInterface.cpp, Line 622
    Setup items (after recorder preparation)
        -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 324099 blocks [YAMAHA CRW4416S]
9:30:02 #9 Phase 26 File dlgbrnst.cpp, Line 1147
    Caching of files failed
9:30:10 #10 Phase 36 File dlgbrnst.cpp, Line 1147
    Start of burnprocess at 4x (600 KB/s)
9:30:10 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1661
    Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
9:30:11 #12 Text 0 File BusArbiter.cpp, Line 821
    Sat Mar 09 09:30:11 2002
    READ: Register
    1.     1     -1    -1    no    READ
    i i
    r r
9:45:58 #13 SCSI -1119 File Cdrdrv.cpp, Line 1251
    SCSI Exec, HA 3, TA 3, LUN 0, buffer 0x033CDA94
    Status:     0x04 (0x01, SCSI_ERR)
    HA-Status   0x00 (0x00, OK)
    TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key:  0x04 (KEY_HARDWARE_ERROR)
    Sense Code: 0x09
    Sense Qual: 0x02
    CDB Data:   0x2A 0x00 0x00 0x04 0x3A 0x1C 0x00 0x00 0x1E 0x00
    Sense Data: 0x70 0x00 0x04 0xD0 0x00 0x00 0x00 0x0A
            0x00 0x00 0x00 0x00 0x09 0x02
9:45:58 #14 mmc 2306 File Writer.cpp, Line 248
    Focus servo failure
9:45:58 #15 Text 0 File ThreadedTransfer.cpp, Line 211
    all writers idle, stopping conversion
9:45:58 #16 Text 0 File ThreadedTransfer.cpp, Line 205
    conversion idle, stopping reader
9:45:58 #17 CDR -201 File WriterStatus.cpp, Line 155
    Invalid writestate
9:45:58 #18 TRANSFER -18 File WriterStatus.cpp, Line 155
    Could not perform EndTrack
9:45:58 #19 SCSI -1026 File Cdrdrv.cpp, Line 1093
    Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x2C
    Sense Qual: 0x04
    CDB Data:   0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
            0x00 0x00 0x00 0x00 0x2C 0x04
9:45:58 #20 mmc 11268 File WriterStatus.cpp, Line 194
    Current program area is empty
9:45:58 #21 TRANSFER -19 File WriterStatus.cpp, Line 194
    Could not perform Fixation
9:45:58 #22 Text 0 File WriterStatus.cpp, Line 203
    falling back to disc fixation
9:45:58 #23 SCSI -1026 File Cdrdrv.cpp, Line 1093
    Sense Code: 0x2C
    Sense Qual: 0x04
9:45:58 #24 mmc 11268 File WriterStatus.cpp, Line 194
9:45:58 #25 TRANSFER -19 File WriterStatus.cpp, Line 194
9:45:58 #26 Phase 38 File dlgbrnst.cpp, Line 1147
    Burnprocess failed at 4x (600 KB/s)
9:45:58 #27 Text 0 File Scsicmd.cpp, Line 260
    SCSI not using temporary buffers
9:45:58 #28 Text 0 File Scsicmd.cpp, Line 283
    10 out of 10 temporary buffers allocated
9:45:58 #29 Text 0 File WinNeroThreads.cpp, Line 909
    Thread priorities:
     Pri.    name -> class / level
       0.    Idle ->    32 /   -15 = default
       1. Background ->    32 /    -2 = default
       2.     Normal ->    32 /     0 = default
       3.   HighIdle ->   128 /    -1 = default
       4.    High ->   128 /     0 = default
       5.     Higher ->   128 /     1 = default
       6.   Realtime ->   128 /     2 = default
9:45:59 #30 SCSI -1119 File Cdrdrv.cpp, Line 1093
    Sense Code: 0x09
    Sense Qual: 0x00
    CDB Data:   0x1B 0x01 0x00 0x00 0x02 0x00
    Sense Data: 0x70 0x00 0x04 0x02 0x1D 0x33 0x00 0x0A
            0x00 0x00 0x00 0x00 0x09 0x00
9:45:59 #31 mmc 2304 File Burncd.cpp, Line 1034
    Track following error
Existing drivers:
File 'Drivers\CDR4VSD.SYS': Ver=2.5 (077), size=60688 bytes, created 23-9-1999 10:48:10
File 'Drivers\ASPI32.SYS': Ver=4.60 (1020), size=25244 bytes, created 15-7-1999 13:06:00
Kort samengevat gaat het CONSTANT bij de lead-out fout!
Hopelijk kunnen jullie me helpen voordat er weer een complete doos met CD's aan moet geloven!
Luc
  • Tony Vroon
  • Laatst online: 13-06-2020
Tony Vroon
Werkt nu ergens anders
Focus servo failure
Hier gaat het fout, je focus servo is zo te zien kapot :(. Da's niet zo mooi, die kun je namelijk niet eenvoudig vervangen.
Je kunt geluk hebben, dat het dus een aanstuurfout is... Installeer even een ander burn-programma. Als dat ook fouten geeft, ga dan terug voor de garantie (of als je dat niet hebt, steek 'm in de brand en koop 'n nieuwe).
"Wie is deesen figuur, hier ten topic aangheduidt als 'hij', wiens mededelinghe soo eenen consternatie weet te ontluycken :? " -- dion_b
CRAP...
Easy CD Creator deed het ook al...
Dat wordt een nieuwe kopen :(
spanks alot voor de info!!!!
Luc
  • Shaidar
  • Laatst online: 02-04 15:01
Shaidar
Hmm .. als er echt hardware kapot is .. dan helpt er niets meer ..
Maar heb je al eens geprobeerd van er een nieuwe firmware op te zetten?
 iPhone 12 Pro 128GB  MacBook Pro (13-inch, 2020, i7, 16GB, 1TB)
