Cisco hulp gevraagd!
Heb morgen een toets en ik heb de vragen al... maar ik heb de stof niet :( kan iemand voor mij de vragen beantwoorden?
Dank u alvast!
Question 1:
Which of the following represents the use of binary ones in a subnet mask?
A. host bits
B. subnet bits
C. network bits
D. subnet and network bits
Question 2:
Which of the following is a benefit of network segmentation?
A. reduced congestion
B. reduced equipment requirements
C. creation of more IP addresses
D. creation of more MAC addresses
Question 3:
How large is the network/subnet portion of a Class B license having a subnet
mask of 255.255.240.0?
A. 18 bits
B. 19 bits
C. 20 bits
D. That is an invalid mask for a Class B network.
Question 4:
Which of the following describes the effect of subnetting on the amount of
broadcast traffic?
A. decreases it, because broadcasts are not forwarded outside a subnet
B. decreases it, because it will take less time for a host to get
broadcasts from the routers.
C. increases it, because the packets must be forwarded to all subnets
D. increases it, because router's duplicate broadcasts
Question 5:
Which address(es) appear in an IP packet's header?
A. source address
B. destination address
C. source and destination addresses
D. there are no addresses in the IP packet header.
Question 7:
What must be used to allow the rest of the Internet to see our organization
as a single network, but allow routing inside our network?
A. partitions
B. autonomous systems
C. subnets
D. divisions
Question 9:
Which octet(s) are assigned locally in a class B address?
A. The first octet is assigned locally.
B. The second octet is assigned locally.
C. The first and second octets are assigned locally.
D. The third and fourth octets are assigned locally.*
Question 11:
Which type of addressing scheme is formed by MAC addresses?
A. flat
B. circular
C. hierarchical
D. elliptical
Question 12:
Which of the following describes the relationship between path determination
and the routing of packets?
A. performed only by switches
B. performed only by different devices
C. they are different processes
D. they are the same process
Question 14:
What is specified by the network number in an IP address?
A. the network to which the host belongs
B. the physical identity of the computer on the network
C. the node of the subnetwork which is being addressed
D. the broadcast identity of subnetwork
Question 15:
Which of the following correctly describes an ISP?
A. Internal Service Protection
B. Internal Service Provider
C. Internet Service Provider
D. Internet Service Protection
Question 16:
Which part of a network layer address does the router use during path
determination?
A. the host address
B. the router address
C. the server address
D. the network address
Question 20:
What characteristic must hosts on a network possess in order to communicate
directly ?
A. same vendor code
B. same network ID
C. same MAC address
D. separate subnets
Question 21:
Which of the following assists devices on the same network in determining a
packet's final destination?
A. source IP address
B. vendor number
C. host protocol
D. host ID
Question 23:
Which OSI layer adds an IP header?
A. Layer 1
B. Layer 2
C. Layer 3
D. Layer 4
Question 24:
Which class of network addresses allows the borrowing of 15 bits to create
subnets?
A. Class A
B. Class B
C. Class C
D. No class of network allows the borrowing of 15 bits.
De vragen die ik al wist heb ik er dus uitgehaald...
  • jadjong
5. C
14. B
15. C
24. D
denk ik ik ben niet aansprakelijk voor het zakken bij deze test
Op dinsdag 05 maart 2002 20:39 schreef jadjong het volgende:
5. C
14. B
15. C
24. D
thnx iig
Wat wil je hier mee bereiken? Ik ga toch ook niet mn tweelingbroer scharrelen om mijn rijbewijs te halen.. |:(
Schiet je zelf toch niets mee op als je het door iemand anders laat doen!
Als je nou de antwoorden hier vandaan haalt, of uit je leerstof haalt. Ik zou het tevredenheidsgevoel voor mezelf als ik het zelf heb gehaald veel belangrijker vinden dan het papiertje hebben en een deel niet kennen.....
Maar dat is mijn mening :)
  • LordMithril
  • Laatst online: 18-08 21:49
uhm welk semester en hoofdstuk is dit? ik heb waarschijnlijk nog wel antwoorden voor je >:)
ook van semester 2 (als ik ze kan vinden) en semester 3 is onderweg :P
Bier, Whiskey en Metal!!
  • Predator
  • Laatst online: 16:57
Predator
Suffers from split brain
PS: met antwoorden ben je NIETS
Je moet de leerstof begrijpen.
Maar voor de lol:
Op dinsdag 05 maart 2002 20:34 schreef StefanWWW het volgende:
Dank u alvast!
Question 1:
A. host bits
B. subnet bits
C. network bits
C
Question 2:
A
Question 3:
A. 18 bits
B. 19 bits
C. 20 bits
C
Question 4:
broadcast traffic?
A
Question 5:
A. source address
C
Question 7:
A. partitions
C. subnets
D. divisions
C
Het antwoord is subnet'n die kunnen geaggrereerd worden tot 1 groot netwerk.
Question 9:
D :?
Question 11:
A. flat
B. circular
C. hierarchical
D. elliptical
C
Question 12:
C of D hangt er vanaf wat ze als 1 proces zien.
Question 14:
A
Question 15:
C
Wist je deze niet :?
Question 16:
determination?
A. the host address
D maar eigenlijk ook A je kan host-routes hebben ook
Question 20:
directly ?
A. same vendor code
B. same network ID
C. same MAC address
D. separate subnets
B
Question 21:
B. vendor number
C. host protocol
D. host ID
D
Question 23:
A. Layer 1
B. Layer 2
C. Layer 3
D. Layer 4
C
Question 24:
subnets?
A. Class A
B. Class B
C. Class C
:? wat bedoelen ze met borrowing ?
* Predator is ook niet aansprakelijk voor fouten
Ik ben moe en ik het zo maar ff snel uit het hoofd gedaan :)
Everybody lies | BFD rocks ! | PC-specs
Op dinsdag 05 maart 2002 20:55 schreef Lord_Mithril het volgende:
semester 1 maar 2 is ook welkom...
Op dinsdag 05 maart 2002 20:57 schreef Predator het volgende:
Maar voor de lol:
C
A
C
A
C
C
D :?
C
A
C
B
D
C
DANK U!!!
  • Tomsworld
Tomsworld
officieel ele fan :*
Dank u alvast!
Hier stond een CCNA chapter test
De stof die vind je hier http://cisco.netacad.com en dan students login
Die login moet je zeker hebben als je ergens een cisco cursus volgt. >:)
De antwoorden op zo'n testen zijn natuurlijk ook online te vinden. Maar ik denk dat het beter is en eerlijker voor jezelf om deze zelf te maken. Zo weet je ook wat je er van kent :)
"De kans dat een snee brood op een nieuw tapijt valt met de beboterde zijde onderaan, is recht evenredig met de prijs van het tapijt"
Maar voor de lol:
C
A
C
A
C
C
D :?
C
A
C
B
D
C
24 is A.
Met borrowing wordt bedoeld: het gebruiken van bits van de hostid om een subnet te maken. Iets waar classe B en C te weinig voor hebben.
12 is D.
routing is path determination
had voor Cisco Networking Acadamy Program examen een 9.1. En voor het semester gemiddeld een 9.3
  • Glottis
  • Laatst online: 25-11-2024
Op dinsdag 05 maart 2002 21:17 schreef ugh het volgende:
It doesn't hurt to be a nerd :P
  • Predator
Predator
24 is A.
Ik dacht dat ze dat bedoelde maar ik was niet zeker.
Ik herkende de engelse term niet.
12 is D.
Hangt er vanaf hoe je "proces" definieerd. Een proces kan uit meerdere process'n bestaan. Daar zei ik C of D
  • Adze
  • Laatst online: 19-08 07:12
Adze
CCNP !
Vraag 1 = D
In vraag 3 geven ze het antwoord al:
Voorbeeld1: 10.45.4.0 mask 255.255.252.0
aantal network bits = 8
aantal subnet bits = 14
aantal host bits = 10
totaal aantal "1" in mask = 22
Voorbeeld2: 210.44.231.8 mask 255.255.255.248
aantal network bits = 24
aantal subnet bits = 5
aantal host bit = 3
totaal aantal "1" in mask = 29
  • markvt
  • Laatst online: 15:13
markvt
Peppi Cola
ik ga je niet helpen maar google er eens op los dude
van-tilburg.info -=- meka (sega emulator) - Proud MEDION fanclub member - KOPPIG VOLHOUDEN !
