heeelllluuup mn pc werkt niet meer :(
  • 52 views sinds 30-01-2008
  • lo3k
  • Laatst online: 08-05-2024
ey, ik heb dit ook op een ander forum gepost, maar dat was in het engels... dus ik heb het ff ge copy/paste...
my pc DOESNT WORK ANYMORE !!! :( :(
i had 2 8mm fans in my pc but i didnt had them connected very well.... (for about a week, worked normal, no probs at all) but today i took them out (after turning my pc OFF) and i soldered the wires together, after that i put some tape around the wires so it wouldnt harm anything or whatever...
i also decided to unplug my IDE cables and put them nice back into my case since it was a VERY BIG mess in there...
im SURE i put them back right... so thats not the problem.
then i put the fans back into my pc and turned my pc on...
everything seemed to work fine.... but my monitor wouldnt turn on... it just stayed at stand-by :(
i rechecked my (IDE) cables and stuff...
still nothing
so i decided to try the monitor on another PC... worked perfect... so its not the monitor...
then i tried my vidcard, worked great too on the other pc...
i also plugged another vidcard into my pc.... still nothing
i also tried the ram and HDD on another PC... but that just worked fine....
i didnt got a "beeep" or anything when i booted my pc... my monitor just wont powerup.
i think its the AGP slot :(
i dont think its the PSU because my pc does power up.
ah please help me with this :(
thanks in advance to all those who can help me in any way.....
alsjeblieft help me hiermee :(
ik kan er niet tegen dat ie het niet meer doet...
specs leken me niet relevant maar als je ze toch wilt weten:
abit k7t mobo
amd duron 700@900
2x 128mbram
45 gig WD
geforce 2 mx 400/400 32MB
Belinea 17" monitor
  • SH007
vertaal het ook even in het Nederlands, dat leest wel zo prettig.(mijn Engels in niet al te best :( )
  • blackd
Kies volgende keer even een betere topictitel:
FAQ:
Als je een topic post, geef het dan een duidelijke titel mee. Een titel als "HELP, MIJN PC CRASHT" is irritant en geeft niet weer wat je probleem is. Kies voor een titel als "Pc crasht zodra Winamp gestart wordt" of iets in die trend. Hou het netjes, ook een topic titel kan een (aanleiding tot) flame zijn.
is al gemeld in SU
Verder: Heb je al geprobeerd je Duron op zijn originele snelheid te zetten? (D.m.v. een bios reset)
9000Wp o/w SolarEdge SE6K - Panasonic 5kW bi-bloc - gasloos sinds 17-7-2023
Zo :)
Mn pc werkt niet meer!
Ik had 2 80mm koelers in mn computer maar i had ze niet zo goed vast gemaakt. (voor ongeveer een week, werkte goed, geen problemen dus) maar vandaag had ik ze eruit gehaald (na mn pc uit gezet te hebben natuurlijk) en had ik de draden gesoldeerd. Daarna heb ik er ff wat tape om gedaan om kortsluiting etc tegen te gaan.
Ik heb ook ff mn ide kabels enzo opgeruimd want het was een zooitje. Ik heb ze GOED terug gedaan dus dat is het probleem niet..
Toen heb ik mn koelers dus weer terug in mn pc gezet en mn pc aangezet.
Alles leek te werken maar mn monitor wilde niet van de stand-by mode af. Hij deed dus nix :(
ff gechecked of mn IDE kabels toch misschien niet goed zaten.. Nog steeds nix :/
Ik ging maar eens even mn monitor proberen op een andere pc.. Werke prima... Zelfde voor mn videokaart..
Ik heb ook nog mn RAM en HD getest op een andere pc.. Werkte goed.
Ik kreeg geen "beep" toen ik mn pc opstartte ofzo.. Ik denk dat mn AGP slot gaar is :(
Waarschijnlijk is het niet mn voeding want mn pc zelf start wel op..
  • lo3k
Op zondag 03 maart 2002 23:16 schreef blackd het volgende:
FAQ:
is al gemeld in SU
sorry voor topic title....
en over die originele snelheid... nope dat heb ik nog niet gedaan... :S
maar lijkt me sterk dat het daaraan ligt... werkt al bijna anderhalf jaar perfect op 900mhz...
  • De_Flexe_Toki
  • Laatst online: 23-10 15:43
De_Flexe_Toki
Opgeroegd staat noger!
Zoiets heb ik ook een keer meegemaakt, toen zat er een geheugenbankje half los. Misschien dat er een een beetje is losgeraakt terwijl je met die kabels aan het kloten was?
Lijkt me niet heel erg onwaarschijnlijk.
Je proc op default snelheid laten lopen is natuurlijk vaste prik als je problemen hebt hè?!
specs
  • lo3k
wow tnx EviL SiqKNeSS :)
  • lo3k
De_Flexe_Toki, dat heb ik dus al geprobeerd, ook al met ander ram.... maar misschien morgen dan maar eens die CPU proberen...
-EDIT: damn typo's :p
  • blackd
Op zondag 03 maart 2002 23:24 schreef De_Flexe_Toki het volgende:
Precies ;)
Probeer gewoon effe al het 'onnodige' spul eruit te halen, dus alleen processor, moederbord, videokaart en ram, en kijk of het dan werkt. Daarna stuk voor stuk je onderdelen toevoegen.
Neigt wel errug naar iets fouts op je mobo btw :(
Op zondag 03 maart 2002 23:25 schreef CroitiX het volgende:
Op zondag 03 maart 2002 23:27 schreef CroitiX het volgende:
Edit button plz :)
  • Sine
  • Laatst online: 20:15
Spinnen je hd's toevallig ook niet op ?
Haal je ide kabels eens los (van je mobo) en kijk wat ie dan doet
klinkt namelijk stiekem toch naar "er zit een ide kabel verkeerd om"
Repareren doe je zo.
  • Bulldog
Je topic titel /subject is onduidelijk /vaag.
Probeer het nog maar eens, op een normale en duidelijke manier! :).
Dit topic gaat op slot, sorry maar helaas.
