[java] javamail
  • 43 views sinds 30-01-2008
Ik heb hier een voorbeeldprogrammatje gevonden om een email te verzenden met javamail. Ik weet totaal niet hoe dat ik die argumenten van de methode send moet inbrengen.
import javax.mail.*;
import javax.mail.internet.*;
import java.util.*;
* A simple email sender class.
public class SimpleSender
*Main method to send a message given on the command line.
public static void main(String args[])
try
String smtpServer=args[0];
String to=args[1];
String from=args[2];
String subject=args[3];
String body=args[4];
send(smtpServer,to,from,subject,body);
catch (Exception ex)
System.out.println("Usage:java com.lotontech.mail.SimpleSender"
+" smtpServer toAdress fromAddress FromAddress subjectText bodyText");
System.exit(0);
*"send" method to send the message.
public static void send(String smtpServer,String to,String from
,String subject,String body)
try
Properties props=System.getProperties();
//Attaching to default Session, or we could start a new one
props.put("mail.smtp.host",smtpServer);
Session session=Session.getDefaultInstance(props,null);
//Create a new message
Message msg=new MimeMessage(session);
//Set the FROM and TO fields
msg.setFrom(new InternetAddress(from));
msg.setRecipients(Message.RecipientType.TO,
InternetAddress.parse(to,false));
//We could include CC recipients too
//if (cc !=null)
//msg.setRecipients(Message.RecipientType.cc
//,InternetAdress.parse(cc,false));
//Set the subject and the body text
msg.setSubject(subject);
msg.setText(body);
//Set some other header information
msg.setHeader("X-Mailer","Lotontechmail");
msg.setSentDate(new Date());
//Send the message
Transport.send(msg);
System.out.println("Message sent OK.");
catch(Exception ex)
ex.printStackTrace();
Als iemand het zou weten, weet iets te zeggen.
Dankt u.
  • Alarmnummer
  • Laatst online: 09-07-2024
Alarmnummer
-= Tja =-
je moet je code even tussen
[ code ] [/ code ]
tags zetten zodat het er wat beter uitziet (spaties moeten er niet bij).
dan krijg je dit
   if(a>b){
     ontplof();
   }else{
     ontplofOokMaar();
En ik denk dat je keurig je antwoord kan vinden in de documentatie want sun die documenteerd hun api`s redelijk goed.
en hier kan je altijd wel zoeken naar docs en vragen over api`s van Sun:
http://search.java.sun.com/
zet hem even in je hotlist ofzo want hier kom je echt vaak.
  • dusty
  • Laatst online: 21-02 00:06
dusty
Celebrate Life!
Helpdesk?
Back In Black!
"Je moet haar alleen aan de ketting leggen" - MueR
