|=|=|=||=|=|=||=|=|=| http://www.vanwijck.com |=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=|
aliases:
root: x@y
.forward in /
root: x@y
sendmail.cf
# Copyright (c) 1998 Sendmail, Inc. All rights reserved.
# Copyright (c) 1983, 1995 Eric P. Allman. All rights reserved.
# Copyright (c) 1988, 1993
#The Regents of the University of California. All rights reserved.
# Copyright (c) 1993, 1997, 1998
#Sun Microsystems, Inc. All rights reserved.
# By using this file, you agree to the terms and conditions set
# forth in the LICENSE file which can be found at the top level of
# the sendmail distribution.
#####SENDMAIL CONFIGURATION FILE
##### @(#)cfhead.m48.22+1.6 (Berkeley+Sun) 05/19/98 #####
##### @(#)cf.m48.24 (Berkeley) 8/16/95 #####
##### @(#)subsidiary-v7sun.mc1.3 (Sun) 07/02/98 #####
##### @(#)remote-mode.m48.1 (Sun) 11/5/97 #####
##### @(#)solaris2.ml.m48.8+1.2 (Berkeley+Sun) 05/19/98 #####
##### @(#)solaris-generic.m41.4 (Sun) 05/19/98 #####
##### @(#)redirect.m48.5 (Berkeley) 8/17/96 #####
##### @(#)use_cw_file.m48.1 (Berkeley) 6/7/93 #####
##### @(#)use_ct_file.m48.1 (Berkeley) 9/17/95 #####
##### @(#)accept_unqualified_senders.m48.3 (Berkeley) 5/19/98 #####
##### @(#)accept_unresolvable_domains.m48.7 (Berkeley) 5/19/98 #####
##### @(#)relay_entire_domain.m48.7 (Berkeley) 5/19/98 #####
##### @(#)proto.m48.223+1.7 (Berkeley+Sun) 08/11/98 #####
# level 8 config file format
V8/Sun
# override file safeties - setting this option compromises system security
# need to set this now for the sake of class files
#O DontBlameSendmail=safe
# local info #
Cwlocalhost
# file containing names of hosts for which we receive email
Fw-o /etc/mail/sendmail.cw
# my official domain name
# ... define this only if sendmail cannot automatically determine your domain
#Dj$w.Foo.COM
CP.
# "Smart" relay host (may be null)
#DSmailhost.$m
DSserverY.$m
# operators that cannot be in local usernames (i.e., network indicators)
CO @ % !
# a class with just dot (for identifying canonical names)
C..
# a class with just a left bracket (for identifying domain literals)
C[[
# Hosts that will permit relaying ($=R)
FR-o /etc/mail/relay-domains
# who I send unqualified names to (null means deliver locally)
DR
# who gets all local email traffic ($R has precedence for unqualified names)
DH
# dequoting map
Kdequote dequote
# class E: names that should be exposed as from this host, even if we masquerade
# class L: names that should be delivered locally, even if we have a relay
# class M: domains that should be converted to $M
#CL root
CE root
# who I masquerade as (null for no masquerading) (see also $=M)
DM
# my name for error messages
DnMAILER-DAEMON
CPREDIRECT
# Configuration version number
DZ8.9.1
# Options #
# strip message body to 7 bits on input?
O SevenBitInput=False
# 8-bit data handling
O EightBitMode=pass8
# wait for alias file rebuild (default units: minutes)
O AliasWait=10
# location of alias file
O AliasFile=dbm:/etc/mail/aliases
# minimum number of free blocks on filesystem
O MinFreeBlocks=100
# maximum message size
#O MaxMessageSize=1000000
# substitution for space (blank) characters
O BlankSub=.
# avoid connecting to "expensive" mailers on initial submission?
O HoldExpensive=False
# checkpoint queue runs after every N successful deliveries
#O CheckpointInterval=10
# default delivery mode
O DeliveryMode=background
# automatically rebuild the alias database?
O AutoRebuildAliases=True
# error message header/file
#O ErrorHeader=/etc/sendmail.oE
# error mode
#O ErrorMode=print
# save Unix-style "From_" lines at top of header?
#O SaveFromLine
# temporary file mode
O TempFileMode=0600
# match recipients against GECOS field?
#O MatchGECOS
# maximum hop count
#O MaxHopCount=17
# location of help file
O HelpFile=/etc/mail/sendmail.hf
# ignore dots as terminators in incoming messages?
#O IgnoreDots
# name resolver options
#O ResolverOptions=+AAONLY
# deliver MIME-encapsulated error messages?
O SendMimeErrors=True
# Forward file search path
O ForwardPath=$z/.forward.$w+$h:$z/.forward+$h:$z/.forward.$w:$z/.forward
# open connection cache size
O ConnectionCacheSize=2
# open connection cache timeout
O ConnectionCacheTimeout=5m
# persistent host status directory
#O HostStatusDirectory=.hoststat
# single thread deliveries (requires HostStatusDirectory)?
#O SingleThreadDelivery
# use Errors-To: header?
O UseErrorsTo=False
# log level
O LogLevel=9
# send to me too, even in an alias expansion?
#O MeToo
# verify RHS in newaliases?
O CheckAliases=False
# default messages to old style headers if no special punctuation?
O OldStyleHeaders=True
# SMTP daemon options
#O DaemonPortOptions=Port=esmtp
# privacy flags
O PrivacyOptions=authwarnings
# who (if anyone) should get extra copies of error messages
#O PostMasterCopy=Postmaster
# slope of queue-only function
#O QueueFactor=600000
# queue directory
O QueueDirectory=/var/spool/mqueue
# timeouts (many of these)
#O Timeout.initial=5m
#O Timeout.connect=5m
#O Timeout.iconnect=5m
#O Timeout.helo=5m
#O Timeout.mail=10m
#O Timeout.rcpt=1h
#O Timeout.datainit=5m
#O Timeout.datablock=1h
#O Timeout.datafinal=1h
#O Timeout.rset=5m
#O Timeout.quit=2m
#O Timeout.misc=2m
#O Timeout.command=1h
#O Timeout.ident=30s
#O Timeout.fileopen=60s
O Timeout.queuereturn=5d
#O Timeout.queuereturn.normal=5d
#O Timeout.queuereturn.urgent=2d
#O Timeout.queuereturn.non-urgent=7d
O Timeout.queuewarn=4h
#O Timeout.queuewarn.normal=4h
#O Timeout.queuewarn.urgent=1h
#O Timeout.queuewarn.non-urgent=12h
#O Timeout.hoststatus=30m
# should we not prune routes in route-addr syntax addresses?
#O DontPruneRoutes
# queue up everything before forking?
O SuperSafe=True
# status file
O StatusFile=/etc/mail/sendmail.st
# time zone handling:
# if undefined, use system default
# if defined but null, use TZ envariable passed in
# if defined and non-null, use that info
#O TimeZoneSpec=
# default UID (can be username or userid:groupid)
#O DefaultUser=mailnull
# list of locations of user database file (null means no lookup)
#O UserDatabaseSpec=/etc/userdb
# fallback MX host
#O FallbackMXhost=fall.back.host.net
# if we are the best MX host for a site, try it directly instead of config err
#O TryNullMXList
# load average at which we just queue messages
#O QueueLA=8
# load average at which we refuse connections
#O RefuseLA=12
# maximum number of children we allow at one time
#O MaxDaemonChildren=12
# maximum number of new connections per second
#O ConnectionRateThrottle=3
# work recipient factor
#O RecipientFactor=30000
# deliver each queued job in a separate process?
#O ForkEachJob
# work class factor
#O ClassFactor=1800
# work time factor
#O RetryFactor=90000
# shall we sort the queue by hostname first?
#O QueueSortOrder=priority
# minimum time in queue before retry
#O MinQueueAge=30m
# default character set
#O DefaultCharSet=iso-8859-1
# service switch file (ignored on Solaris, Ultrix, OSF/1, others)
#O ServiceSwitchFile=/etc/service.switch
# hosts file (normally /etc/hosts)
#O HostsFile=/etc/hosts
# dialup line delay on connection failure
#O DialDelay=10s
# action to take if there are no recipients in the message
#O NoRecipientAction=add-to-undisclosed
# chrooted environment for writing to files
#O SafeFileEnvironment=/arch
# are colons OK in addresses?
#O ColonOkInAddr
# how many jobs can you process in the queue?
#O MaxQueueRunSize=10000
# shall I avoid expanding CNAMEs (violates protocols)?
#O DontExpandCnames
# SMTP initial login message (old $e macro)
O SmtpGreetingMessage=$j Sendmail $v/$Z; $b
# UNIX initial From header format (old $l macro)
O UnixFromLine=From $g $d
# From: lines that have embedded newlines are unwrapped onto one line
#O SingleLineFromHeader=False
# Allow HELO SMTP command that does not include a host name
#O AllowBogusHELO=False
# Characters to be quoted in a full name phrase (@,;:\()[] are automatic)
#O MustQuoteChars=.
# delimiter (operator) characters (old $o macro)
O OperatorChars=.:%@!^/[]+
# shall I avoid calling initgroups(3) because of high NIS costs?
#O DontInitGroups
# are group-writable :include: and .forward files (un)trustworthy?
#O UnsafeGroupWrites
# where do errors that occur when sending errors get sent?
#O DoubleBounceAddress=postmaster
# what user id do we assume for the majority of the processing?
#O RunAsUser=sendmail
# treat /var/mail mount source, or specified value, as mail-server
O RemoteMode=
# maximum number of recipients per SMTP envelope
#O MaxRecipientsPerMessage=100
# shall we get local names from our installed interfaces?
#O DontProbeInterfaces
# maximum length of MIME header fields (total) and each of their parameters
#O MaxMimeHeaderLength=1024/256
# Message precedences #
Pfirst-class=0
Pspecial-delivery=100
Plist=-30
Pbulk=-60
Pjunk=-100
# Trusted users #
# this is equivalent to setting class "t"
Ft-o /etc/mail/sendmail.ct
Troot
Tdaemon
Tuucp
# Format of headers #
H?P?Return-Path: <$g>
HReceived: $?sfrom $s $.$?_($?s$|from $.$_)
$.by $j ($v/$Z)$?r with $r$. id $i$?u
for $u; $|;
$.$b
H?D?Resent-Date: $a
H?D?Date: $a
H?F?Resent-From: $?x$x <$g>$|$g$.
H?F?From: $?x$x <$g>$|$g$.
H?x?Full-Name: $x
# HPosted-Date: $a
# H?l?Received-Date: $b
H?M?Resent-Message-Id: <$t.$i@$j>
H?M?Message-Id: <$t.$i@$j>
#####REWRITING RULES
### Ruleset 3 -- Name Canonicalization ###
S3
# handle null input (translate to <@> special case)
R$@$@ <@>
# strip group: syntax (not inside angle brackets!) and trailing semicolon
R$*$: $1 <@>mark addresses
R$* < $* > $* <@>$: $1 < $2 > $3unmark <addr>
R@ $* <@>$: @ $1unmark @host:...
R$* :: $* <@>$: $1 :: $2unmark node::addr
R:include: $* <@>$: :include: $1unmark :include:...
R$* [ $* : $* ] <@>$: $1 [ $2 : $3 ]unmark IPv6 addrs
R$* : $* [ $* ]$: $1 : $2 [ $3 ] <@>remark if leading colon
R$* : $* <@>$: $2strip colon if marked
R$* <@>$: $1unmark
R$* ; $1strip trailing semi
R$* < $* ; > $1 < $2 >bogus bracketed semi
# null input now results from list:; syntax
R$@$@ :; <@>
# strip angle brackets -- note RFC733 heuristic to get innermost item
R$*$: < $1 >housekeeping <>
R$+ < $* > < $2 >strip excess on left
R< $* > $+ < $1 >strip excess on right
R<>$@ < @ >MAIL FROM:<> case
R< $+ >$: $1remove housekeeping <>
# make sure <@a,@b,@c:user@d> syntax is easy to parse -- undone later
R@ $+ , $+@ $1 : $2change all "," to ":"
# localize and dispose of route-based addresses
R@ $+ : $+$@ $>96 < @$1 > : $2handle <route-addr>
# find focus for list syntax
R $+ : $* ; @ $+$@ $>96 $1 : $2 ; < @ $3 >list syntax
R $+ : $* ;$@ $1 : $2;list syntax
# find focus for @ syntax addresses
R$+ @ $+$: $1 < @ $2 >focus on domain
R$+ < $+ @ $+ >$1 $2 < @ $3 >move gaze right
R$+ < @ $+ >$@ $>96 $1 < @ $2 >already canonical
# do some sanity checking
R$* < @ $* : $* > $*$1 < @ $2 $3 > $4nix colons in addrs
# convert old-style addresses to a domain-based address
R$- ! $+$@ $>96 $2 < @ $1 .UUCP >resolve uucp names
R$+ . $- ! $+$@ $>96 $3 < @ $1 . $2 >domain uucps
R$+ ! $+$@ $>96 $2 < @ $1 .UUCP >uucp subdomains
# if we have % signs, take the rightmost one
R$* % $*$1 @ $2First make them all @s.
R$* @ $* @ $*$1 % $2 @ $3Undo all but the last.
R$* @ $*$@ $>96 $1 < @ $2 >Insert < > and finish
# else we must be a local name
R$*$@ $>96 $1
### Ruleset 96 -- bottom half of ruleset 3 ###
S96
# handle special cases for local names
R$* < @ localhost > $*$: $1 < @ $j . > $2no domain at all
R$* < @ localhost . $m > $*$: $1 < @ $j . > $2local domain
R$* < @ localhost . UUCP > $*$: $1 < @ $j . > $2.UUCP domain
R$* < @ [ $+ ] > $*$: $1 < @@ [ $2 ] > $3mark [a.b.c.d]
R$* < @@ $=w > $*$: $1 < @ $j . > $3self-literal
R$* < @@ $+ > $*$@ $1 < @ $2 > $3canon IP addr
# if really UUCP, handle it immediately
# try UUCP traffic as a local address
R$* < @ $+ . UUCP > $*$: $1 < @ $[ $2 $] . UUCP . > $3
R$* < @ $+ . . UUCP . > $*$@ $1 < @ $2 . > $3
# pass to name server to make hostname canonical
R$* < @ $* $~P > $*$: $1 < @ $[ $2 $3 $] > $4
# local host aliases and pseudo-domains are always canonical
R$* < @ $=w > $*$: $1 < @ $2 . > $3
R$* < @ $j > $*$: $1 < @ $j . > $2
R$* < @ $=M > $*$: $1 < @ $2 . > $3
R$* < @ $* $=P > $*$: $1 < @ $2 $3 . > $4
R$* < @ $* . . > $*$1 < @ $2 . > $3
### Ruleset 4 -- Final Output Post-rewriting ###
S4
R$* <@>$@handle <> and list:;
# strip trailing dot off possibly canonical name
R$* < @ $+ . > $*$1 < @ $2 > $3
# eliminate internal code -- should never get this far!
R$* < @ *LOCAL* > $*$1 < @ $j > $2
# externalize local domain info
R$* < $+ > $*$1 $2 $3defocus
R@ $+ : @ $+ : $+@ $1 , @ $2 : $3<route-addr> canonical
R@ $*$@ @ $1... and exit
# UUCP must always be presented in old form
R$+ @ $- . UUCP$2!$1u@h.UUCP => h!u
# delete duplicate local names
R$+ % $=w @ $=w$1 @ $2u%host@host => u@host
### Ruleset 97 -- recanonicalize and call ruleset zero ###
### (used for recursive calls) ###
S97
R$*$: $>3 $1
R$*$@ $>0 $1
### Ruleset 0 -- Parse Address ###
S0
R$*$: $>Parse0 $1initial parsing
R<@>$#local $: <@>special case error msgs
R$*$: $>98 $1handle local hacks
R$*$: $>Parse1 $1final parsing
# Parse0 -- do initial syntax checking and eliminate local addresses.
#This should either return with the (possibly modified) input
#or return with a #error mailer. It should not return with a
##mailer other than the #error mailer.
SParse0
R<@>$@ <@>special case error msgs
R$* : $* ; <@>$#error $@ 5.1.3 $: "List:; syntax illegal for recipient addresses"
#R@ <@ $* >< @ $1 >catch "@@host" bogosity
R<@ $+>$#error $@ 5.1.3 $: "User address required"
R$*$: <> $1
R<> $* < @ [ $+ ] > $*$1 < @ [ $2 ] > $3
R<> $* <$* : $* > $*$#error $@ 5.1.3 $: "Colon illegal in host name part"
R<> $*$1
R$* < @ . $* > $*$#error $@ 5.1.2 $: "Invalid host name"
R$* < @ $* .. $* > $*$#error $@ 5.1.2 $: "Invalid host name"
# now delete the local info -- note $=O to find characters that cause forwarding
R$* < @ > $*$@ $>Parse0 $>3 $1user@ => user
R< @ $=w . > : $*$@ $>Parse0 $>3 $2@here:... -> ...
R$- < @ $=w . >$: $(dequote $1 $) < @ $2 . >dequote "foo"@here
R< @ $+ >$#error $@ 5.1.3 $: "User address required"
R$* $=O $* < @ $=w . >$@ $>Parse0 $>3 $1 $2 $3...@here -> ...
R$- $: $(dequote $1 $) < @ *LOCAL* >dequote "foo"
R< @ *LOCAL* >$#error $@ 5.1.3 $: "User address required"
R$* $=O $* < @ *LOCAL* >
$@ $>Parse0 $>3 $1 $2 $3...@*LOCAL* -> ...
R$* < @ *LOCAL* >$: $1
# Parse1 -- the bottom half of ruleset 0.
SParse1
# handle numeric address spec
R$* < @ [ $+ ] > $*$: $>98 $1 < @ [ $2 ] > $3numeric internet spec
R$* < @ [ $+ ] > $*$#esmtp $@ [$2] $: $1 < @ [$2] > $3still numeric: send
# short circuit local delivery so forwarded email works
R$=L < @ $=w . >$#local $: @ $1special local names
R$+ < @ $=w . >$#local $: $1regular local name
# resolve remotely connected UUCP links (if any)
# resolve fake top level domains by forwarding to other hosts
# figure out what should stay in our local mail system
R$* < @ $* .$m. > $*$#esmtp $@ $2.$m $: $1 < @ $2.$m. > $3
# pass names that still have a host to a smarthost (if defined)
R$* < @ $* > $*$: $>95 < $S > $1 < @ $2 > $3glue on smarthost name
# deal with other remote names
R$* < @$* > $*$#esmtp $@ $2 $: $1 < @ $2 > $3user@host.domain
# handle locally delivered names
R$=L$#local $: @ $1special local names
R$+$#local $: $1regular local names
### Ruleset 5 -- special rewriting after aliases have been expanded ###
S5
# deal with plussed users so aliases work nicely
R$+ + *$#local $@ $&h $: $1
R$+ + $*$#local $@ + $2 $: $1 + *
# prepend an empty "forward host" on the front
R$+$: <> $1
# see if we have a relay or a hub
R< > $+$: < $H > $1try hub
R< > $+$: < $R > $1try relay
R< > $+$: < > < $1 $&h >nope, restore +detail
R< > < $+ + $* > $* < > < $1 > + $2 $3find the user part
R< > < $+ > + $*$#local $@ $2 $: @ $1strip the extra +
R< > < $+ >$@ $1no +detail
R$+$: $1 $&hadd +detail back in
R< local : $* > $*$: $>95 < local : $1 > $2no host extension
R< error : $* > $*$: $>95 < error : $1 > $2no host extension
R< $- : $+ > $+$: $>95 < $1 : $2 > $3 < @ $2 >
R< $+ > $+$@ $>95 < $1 > $2 < @ $1 >
### Ruleset 33 -- needed only for Suns RemoteMode###
S33
R$+ < @ $=w . >$1
R$* < @ $+ > $*$#relay $@${ms} $:$1<@$2>$3forward to ${ms}
R$+$#local $:$1local names'
### Ruleset 95 -- canonify mailer:[user@]host syntax to triple###
S95
R< > $*$@ $1strip off null relay
R< error : $- $+ > $*$#error $@ $(dequote $1 $) $: $2
R< local : $* > $*$>CanonLocal < $1 > $2
R< $- : $+ @ $+ > $*<$*>$*$# $1 $@ $3 $: $2<@$3>use literal user
R< $- : $+ > $*$# $1 $@ $2 $: $3try qualified mailer
R< $=w > $*$@ $2delete local host
R< $+ > $*$#relay $@ $1 $: $2use unqualified mailer
### Ruleset CanonLocal -- canonify local: syntax###
SCanonLocal
# strip trailing dot from any host name that may appear
R< $* > $* < @ $* . >$: < $1 > $2 < @ $3 >
# handle local: syntax -- use old user, either with or without host
R< > $* < @ $* > $*$#local $@ $1@$2 $: $1
R< > $+$#local $@ $1 $: $1
# handle local:user@host syntax -- ignore host part
R< $+ @ $+ > $* < @ $* >$: < $1 > $3 < @ $4 >
# handle local:user syntax
R< $+ > $* <@ $* > $*$#local $@ $2@$3 $: $1
R< $+ > $* $#local $@ $2 $: $1
### Ruleset 93 -- convert header names to masqueraded form###
S93
# special case the users that should be exposed
R$=E < @ *LOCAL* >$@ $1 < @ $j . >leave exposed
R$=E < @ $=M . >$@ $1 < @ $2 . >
R$=E < @ $=w . >$@ $1 < @ $2 . >
# handle domain-specific masquerading
R$* < @ $=M . > $*$: $1 < @ $2 . @ $M > $3convert masqueraded doms
R$* < @ $=w . > $*$: $1 < @ $2 . @ $M > $3
R$* < @ *LOCAL* > $*$: $1 < @ $j . @ $M > $2
R$* < @ $+ @ > $*$: $1 < @ $2 > $3$M is null
R$* < @ $+ @ $+ > $*$: $1 < @ $3 . > $4$M is not null
### Ruleset 94 -- convert envelope names to masqueraded form###
S94
R$* < @ *LOCAL* > $*$: $1 < @ $j . > $2
### Ruleset 98 -- local part of ruleset zero (can be null)###
S98
# addresses sent to foo@host.REDIRECT will give a 551 error code
R$* < @ $+ .REDIRECT. >$: $1 < @ $2 . REDIRECT . > < ${opMode} >
R$* < @ $+ .REDIRECT. > <i>$: $1 < @ $2 . REDIRECT. >
R$* < @ $+ .REDIRECT. > < $- >$# error $@ 5.1.1 $: "551 User has moved; please try " <$1@$2>
### ParseRecipient --Strip off hosts in $=R as well as possibly
###$* $=m or the access database.
###Check user portion for host separators.
###Parameters:
###$1 -- full recipient address
###Returns:
###parsed, non-local-relaying address
SParseRecipient
R$*$: <?> $>Parse0 $>3 $1
R<?> $* < @ $* . ><?> $1 < @ $2 >strip trailing dots
R<?> $- < @ $* >$: <?> $(dequote $1 $) < @ $2 >dequote local part
# if no $=O character, no host in the user portion, we are done
R<?> $* $=O $* < @ $* >$: <NO> $1 $2 $3 < @ $4>
R<?> $*$@ $1
# if we relay, check username portion for user%host so host can be checked also
R<NO> $* < @ $* $=m >$: <RELAY> $1 < @ $2 $3 >
R<NO> $* < @ $* $=R >$: <RELAY> $1 < @ $2 $3 >
R<RELAY> $* < @ $* >$@ $>ParseRecipient $1
R<$-> $*$@ $2
### check_relay -- check hostname/address on SMTP startup
SLocal_check_relay
Scheck_relay
R$*$: $1 $| $>"Local_check_relay" $1
R$* $| $* $| $#$*$#$3
R$* $| $* $| $*$@ $>"Basic_check_relay" $1 $| $2
SBasic_check_relay
# check for deferred delivery mode
R$*$: < ${deliveryMode} > $1
R< d > $*$@ deferred
R< $* > $*$: $2
### check_mail -- check SMTP `MAIL FROM:' command argument
SLocal_check_mail
Scheck_mail
R$*$: $1 $| $>"Local_check_mail" $1
R$* $| $#$*$#$2
R$* $| $*$@ $>"Basic_check_mail" $1
SBasic_check_mail
R< $* > $*$: $2
R<>$@ <OK>
R$*$: <?> $>Parse0 $>3 $1make domain canonical
R<?> $* < @ $+ . > $*<?> $1 < @ $2 > $3strip trailing dots
# handle non-DNS hostnames (*.bitnet, *.decnet, *.uucp, etc)
R<?> $* < $* $=P > $*$: <OK> $1 < @ $2 $3 > $4
R<?> $* < @ $+ > $*$: <OK> $1 < @ $2 > $3... unresolvable OK
# check results
R<?> $*$@ <OK>
R<OK> $*$@ <OK>
R<TEMP> $*$#error $@ 4.1.8 $: "451 Sender domain must resolve"
R<PERM> $*$#error $@ 5.1.8 $: "501 Sender domain must exist"
### check_rcpt -- check SMTP `RCPT TO:' command argument
SLocal_check_rcpt
Scheck_rcpt
R$*$: $1 $| $>"Local_check_rcpt" $1
R$* $| $#$*$#$2
R$* $| $*$@ $>"Basic_check_rcpt" $1
SBasic_check_rcpt
R< $* > $*$: $2
R$*$: $>ParseRecipient $1strip relayable hosts
# anything terminating locally is ok
R$+ < @ $* $=m >$@ OK
R$+ < @ $=w >$@ OK
R$+ < @ $* $=R >$@ OK
# check for local user (i.e. unqualified address)
R$*$: <?> $1
R<?> $+ < @ $+ >$: <REMOTE> $1 < @ $2 >
# local user is ok
R<?> $+$@ OK
R<$+> $*$: $2
# anything originating locally is ok
R$*$: <?> $&{client_name}
# check if bracketed IP address (forward lookup != reverse lookup)
R<?> [$+]$: <BAD> [$1]
R<?> $* $~P $: <?> $[ $1 $2 $]
R<$-> $*$: $2
R$* .$1strip trailing dots
R$@$@ OK
R$* $=m$@ OK
R$=w$@ OK
R$* $=R$@ OK
# check IP address
R$*$: $&{client_addr}
R$@$@ OKoriginated locally
R0$@ OKoriginated locally
R$=R $*$@ OKrelayable IP address
R$*$: [ $1 ]put brackets around it...
R$=w$@ OK... and see if it is local
# anything else is bogus
R$*$#error $@ 5.7.1 $: "550 Relaying denied"
#####MAILER DEFINITIONS
### Local and Program Mailer specification ###
##### @(#)local.m48.30 (Berkeley) 6/30/98 #####
Mlocal,P=/usr/lib/mail.local, F=lsDFMAw5:/|@qfSmn9, S=10/30, R=20/40,
T=DNS/RFC822/X-Unix,
A=mail.local -d $u
Mprog,P=/bin/sh, F=lsDFMoqeu9, S=10/30, R=20/40, D=$z:/,
T=X-Unix,
A=sh -c $u
# Envelope sender rewriting
S10
R<@>$nerrors to mailer-daemon
R@ <@ $*>$ntemporarily bypass Sun bogosity
R$+$: $>50 $1add local domain if needed
R$*$: $>94 $1do masquerading
# Envelope recipient rewriting
S20
R$+ < @ $* >$: $1strip host part
# Header sender rewriting
S30
R$*$: $>93 $1do masquerading
# Header recipient rewriting
S40
# Common code to add local domain name (only if always-add-domain)
S50
### SMTP Mailer specification ###
##### @(#)smtp.m48.33+1.4 (Berkeley+Sun) 01/30/98 #####
Msmtp,P=[IPC], F=mDFMuX, S=11/31, R=21, E=\r\n, L=990,
T=DNS/RFC822/SMTP,
A=IPC $h
Mesmtp,P=[IPC], F=mDFMuXa, S=11/31, R=21, E=\r\n, L=990,
T=DNS/RFC822/SMTP,
A=IPC $h
Msmtp8,P=[IPC], F=mDFMuX8, S=11/31, R=21, E=\r\n, L=990,
T=DNS/RFC822/SMTP,
A=IPC $h
Mrelay,P=[IPC], F=mDFMuXa8, S=11/31, R=61, E=\r\n, L=2040,
T=DNS/RFC822/SMTP,
A=IPC $h
# envelope sender rewriting
S11
R$+$: $>51 $1sender/recipient common
R$* :; <@>$@list:; special case
R$*$: $>61 $1qualify unqual'ed names
R$+$: $>94 $1do masquerading
R$+ < @ $=w . >$: $>96 $1 < @ ${ms} >change to mail server
# envelope recipient rewriting --
# also header recipient if not masquerading recipients
S21
R$+$: $>61 $1qualify unqual'ed names
# header sender and masquerading header recipient rewriting
S31
R:; <@>$@list:; special case
# do special header rewriting
R$* <@> $*$@ $1 <@> $2pass null host through
R< @ $* > $*$@ < @ $1 > $2pass route-addr through
R$+$: $>93 $1do masquerading
# convert pseudo-domain addresses to real domain addresses
S51
# pass <route-addr>s through
R< @ $+ > $*$@ < @ $1 > $2resolve <route-addr>
# output fake domains as user%fake@relay
# do UUCP heuristics; note that these are shared with UUCP mailers
R$+ < @ $+ .UUCP. >$: < $2 ! > $1convert to UUCP form
R$+ < @ $* > $*$@ $1 < @ $2 > $3not UUCP form
# leave these in .UUCP form to avoid further tampering
R< $&h ! > $- ! $+$@ $2 < @ $1 .UUCP. >
R< $&h ! > $-.$+ ! $+$@ $3 < @ $1.$2 >
R< $&h ! > $+$@ $1 < @ $&h .UUCP. >
R< $+ ! > $+$: $1 ! $2 < @ $Y >use UUCP_RELAY
R$+ < @ $+ : $+ >$@ $1 < @ $3 >strip mailer: part
R$+ < @ >$: $1 < @ *LOCAL* >if no UUCP_RELAY
# common sender and masquerading recipient rewriting
S61
R$* < @ $* > $*$@ $1 < @ $2 > $3already fully qualified
R$+$@ $1 < @ *LOCAL* >add local qualification
# relay mailer header masquerading recipient rewriting
S71
R$+$: $>61 $1
R$+$: $>93 $1
root: x@y
.forward in /
root: x@y
sendmail.cf
V8/Sun
# local info #
Cwlocalhost
#Dj$w.Foo.COM
CP.
#DSmailhost.$m
DSserverY.$m
CO @ % !
C..
C[[
DR
DH
# dequoting map
Kdequote dequote
#CL root
CE root
DM
DnMAILER-DAEMON
CPREDIRECT
DZ8.9.1
# Options #
O AliasWait=10
O MinFreeBlocks=100
O BlankSub=.
# error mode
#O ErrorMode=print
#O SaveFromLine
O TempFileMode=0600
#O MatchGECOS
# maximum hop count
#O MaxHopCount=17
#O IgnoreDots
O UseErrorsTo=False
# log level
O LogLevel=9
#O MeToo
# privacy flags
# queue directory
#O Timeout.helo=5m
#O Timeout.mail=10m
#O Timeout.rcpt=1h
#O Timeout.rset=5m
#O Timeout.quit=2m
#O Timeout.misc=2m
#O DontPruneRoutes
O SuperSafe=True
# status file
#O TimeZoneSpec=
# fallback MX host
#O TryNullMXList
#O QueueLA=8
#O RefuseLA=12
#O ForkEachJob
# work class factor
#O ClassFactor=1800
# work time factor
#O MinQueueAge=30m
#O DialDelay=10s
#O ColonOkInAddr
#O DontExpandCnames
#O MustQuoteChars=.
#O DontInitGroups
O RemoteMode=
Pfirst-class=0
Plist=-30
Pbulk=-60
Pjunk=-100
# Trusted users #
Troot
Tdaemon
Tuucp
for $u; $|;
$.$b
H?D?Resent-Date: $a
H?D?Date: $a
H?x?Full-Name: $x
# HPosted-Date: $a
S3
R$@$@ <@>
R$* <@>$: $1unmark
R$@$@ :; <@>
R$*$@ $>96 $1
S96
S4
S97
R$*$: $>3 $1
R$*$@ $>0 $1
S0
SParse0
R$*$: <> $1
R<> $*$1
SParse1
S5
R$+$: <> $1
S33
R$+ < @ $=w . >$1
S95
SCanonLocal
S93
S94
S98
###Parameters:
###Returns:
SParseRecipient
R<?> $*$@ $1
R<$-> $*$@ $2
SLocal_check_relay
Scheck_relay
SBasic_check_relay
R< $* > $*$: $2
SLocal_check_mail
Scheck_mail
R$* $| $#$*$#$2
SBasic_check_mail
R< $* > $*$: $2
R<>$@ <OK>
# check results
R<?> $*$@ <OK>
R<OK> $*$@ <OK>
SLocal_check_rcpt
Scheck_rcpt
R$* $| $#$*$#$2
SBasic_check_rcpt
R< $* > $*$: $2
R$+ < @ $=w >$@ OK
R$*$: <?> $1
# local user is ok
R<?> $+$@ OK
R<$+> $*$: $2
R<$-> $*$: $2
R$@$@ OK
R$* $=m$@ OK
R$=w$@ OK
R$* $=R$@ OK
# check IP address
A=mail.local -d $u
T=X-Unix,
A=sh -c $u
S10
S20
S30
S40
S50
T=DNS/RFC822/SMTP,
A=IPC $h
T=DNS/RFC822/SMTP,
A=IPC $h
T=DNS/RFC822/SMTP,
A=IPC $h
T=DNS/RFC822/SMTP,
A=IPC $h
S11
S21
S31
S51
S61
S71
R$+$: $>61 $1
R$+$: $>93 $1
ik heb gevonden dat .forward niet altijd werkt bij lokaal verzonden mail. Wel bij wat extern binnen komt via de smtp daemon. een oplossing heb ik nog niet...
root: user@domeinsolaris 7 (sparc) en sendmail 8.9.3
een ander mail prog is geen optie
(en ja ik heb search gebruikt/.....)
Mijn bedoeling is alle mail voor root naar een mailbox x@y op een andere machine te krijgen. Ik kan mail naar het betreffende adres "x@y" sturen vanaf de mailbox van root.
De DS entry in sendmail.cf is dus goed.
in /etc/aliases
Probeer anders newaliases te starten. Misschien dat er iets fout gaat bij de update
signature has expired
newaliases heb ik al gedaan evanals sendmail stop/start
[edit]
het werkt ineens
bedankt zover: topic kan dicht
[edit]
Waarschijnlijk door deze regel:
O AliasWait=10
O AliasWait=10
Idd.. Bij sendmail 8.12.x moet je met de hand rebuilden (ivm DOS)Waarschijnlijk door deze regel:
O AliasWait=10
