Ik heb nu een aantal dingen geprobeerd om KDE aan de praat te krijgen. Onder andere:
export DISPLAY=0:0
switchdesk
maar dan krijg ik de foutmelding:
cannot connect to X server 0:0
Als ik XFree86 start krijg ik nog steeds het grijze scherm met de X mouse pointer en verder niets
Dit is als root
Na inloggen als gebruiker en dan XFree86 starten geeft de foutmelding:
Fatal server error
Cannot open log file "/var/log/XFree86.0.log
Hieronder de log file en mijn XFree86Config-4 en
XFree86Config.
Ik geef de moed nog niet op.
XFree86.0.log
XFree86 Version 4.1.0 (Red Hat Linux release: 4.1.0-3) / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 2 June 2001
(==) ServerLayout "XFree86 Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Generic Extended Super VGA, 800x600 @ 60 Hz, 640x480 @ 72 Hz"
(**) | |-->Device "S3 Trio64 (generic)"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(**) Option "XkbLayout" "us"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) LoadModule: "vesa"
(II) Loading /usr/X11R6/lib/modules/drivers/vesa_drv.o
(II) Module vesa: vendor="The XFree86 Project"
compiled for 4.1.0, module version = 1.0.0
Module class: XFree86 Video Driver
ABI class: XFree86 Video Driver, version 0.4
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.2
(II) v4l driver for Video4Linux
(II) VESA: driver for VESA chipsets: vesa
(II) Primary Device is: PCI 00:10:0
(--) Assigning device section with no busID to primary device
(--) Chipset vesa found
(II) Setting vga for screen 0.
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) VESA(0): Primary V_BIOS segment is: 0xc000
(II) VESA(0): VESA BIOS detected
(II) VESA(0): VESA VBE Version 1.2
(II) VESA(0): VESA VBE Total Mem: 2048 kB
(II) VESA(0): VESA VBE OEM: S3 Incorporated. Trio64V+
(**) VESA(0): Depth 16, (--) framebuffer bpp 16
(==) VESA(0): RGB weight 565
(==) VESA(0): Default visual is TrueColor
(==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
(==) VESA(0): DPI set to (75, 75)
(II) VESA(0): Searching for matching VESA mode(s):
Total Memory: 32 64Kb banks (2M)
(--) VESA(0): Virtual size is 800x600 (pitch 800)
(**) VESA(0): Default mode "800x600"
(**) VESA(0): Default mode "640x480"
(**) VESA(0): Using "Shadow Framebuffer"
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
ABI class: XFree86 ANSI C Emulation, version 0.1
Symbol xf86InterpretEDID from module /usr/X11R6/lib/modules/libvbe.a is unresolved!
(II) do I need RAC? No, I don't.
(==) VESA(0): Backing store disabled
(**) Option "dpms"
(**) VESA(0): DPMS enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(**) Option "Protocol" "Microsoft"
(**) Mouse0: Protocol: "Microsoft"
(**) Option "CorePointer"
(**) Mouse0: Core Pointer
(**) Option "Device" "/dev/mouse"
(**) Option "BaudRate" "1200"
(**) Option "StopBits" "1"
(**) Option "DataBits" "7"
(**) Option "Parity" "None"
(**) Option "Vmin" "1"
(**) Option "Vtime" "0"
(**) Option "FlowControl" "None"
(==) Mouse0: Buttons: 3
(**) Option "Emulate3Buttons" "off"
(**) Option "ZAxisMapping" "4 5"
(**) Mouse0: ZAxisMapping: buttons 4 and 5
(**) Mouse0: BaudRate: 1200
(II) Keyboard "Keyboard0" handled by legacy driver
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(II) Open APM successful
XFree86Config
# File generated by XConfigurator.
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
# Files section. This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
RgbPath"/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
FontPath "unix/:7100"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received. This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
#NoTrapSignals
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
#DontZap
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences. This allows clients to receive these key events.
#DontZoom
EndSection
# Input devices
# Keyboard section
Section "Keyboard"
Protocol "Standard"
# when using XQUEUE, comment out the above line, and uncomment the
# following line
#Protocol "Xqueue"
AutoRepeat 500 5
# Let the server do the NumLock processing. This should only be
# required when using pre-R6 clients
#ServerNumLock
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#Xleds 1 2 3
#To set the LeftAlt to Meta, RightAlt key to ModeShift,
#RightCtl key to Compose, and ScrollLock key to ModeLock:
LeftAlt Meta
RightAlt Meta
ScrollLock Compose
RightCtl Control
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# XkbDisable
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a non-U.S.
# keyboard, you will probably want to use:
# XkbModel "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
# XkbModel "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# XkbLayout "de"
# or:
# XkbLayout "de"
# XkbVariant "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# XkbOptions "ctrl:swapcaps"
# These are the default XKB settings for XFree86
# XkbRules "xfree86"
# XkbModel "pc101"
# XkbLayout "us"
# XkbVariant ""
# XkbOptions ""
XkbKeycodes "xfree86"
XkbTypes "default"
XkbCompat "default"
XkbSymbols "us(pc101)"
XkbGeometry "pc"
XkbRules "xfree86"
XkbModel "pc101"
XkbLayout "us"
EndSection
# Pointer section
Section "Pointer"
Protocol "Microsoft"
Device "/dev/mouse"
ZAxisMapping 4 5
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Protocol"Xqueue"
# Baudrate and SampleRate are only for some Logitech mice
# BaudRate9600
# SampleRate150
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
# Emulate3Buttons
# Emulate3Timeout 50
# ChordMiddle is an option for some 3-button Logitech mice
# ChordMiddle
EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
Identifier "Generic Extended Super VGA, 800x600 @ 60 Hz, 640x480 @ 72 Hz"
VendorName "Unknown"
ModelName "Unknown"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
HorizSync 31.5-37.9
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
VertRefresh 50-70
# Modes can be specified in two formats. A compact one-line format, or
# a multi-line format.
# These two are equivalent
# ModeLine "1024x768i" 45 1024 1048 1208 1264 768 776 784 817 Interlace
# Mode "1024x768i"
# DotClock45
# HTimings1024 1048 1208 1264
# VTimings768 776 784 817
# Flags"Interlace"
# EndMode
# This is a set of standard mode timings. Modes that are out of monitor spec
# are automatically deleted by the server (provided the HorizSync and
# VertRefresh lines are correct), so there's no immediate need to
# delete mode timings (unless particular mode timings don't work on your
# monitor). With these modes, the best standard mode that your monitor
# and video card can support for a given resolution is automatically
# used.
# 512x384 @ 78 Hz, 31.50 kHz hsync
Modeline "512x384" 20.160 512 528 592 640 384 385 388 404 -HSync -VSync
# 512x384 @ 85 Hz, 34.38 kHz hsync
Modeline "512x384" 22 512 528 592 640 384 385 388 404 -HSync -VSync
# 640x400 @ 70 Hz, 31.5 kHz hsync
Modeline "640x400" 25.175 640 664 760 800 400 409 411 450
# 640x400 @ 85 Hz, 37.86 kHz hsync
Modeline "640x400" 31.5 640 672 736 832 400 401 404 445 -HSync +VSync
# 640x480 @ 100 Hz, 53.01 kHz hsync
Modeline "640x480" 45.8 640 672 768 864 480 488 494 530 -HSync -VSync
# 640x480 @ 60 Hz, 31.5 kHz hsync
Modeline "640x480" 25.175 640 664 760 800 480 491 493 525
# 640x480 @ 72 Hz, 36.5 kHz hsync
Modeline "640x480" 31.5 640 680 720 864 480 488 491 521
# 640x480 @ 75 Hz, 37.50 kHz hsync
ModeLine "640x480" 31.5 640 656 720 840 480 481 484 500 -HSync -VSync
# 640x480 @ 85 Hz, 43.27 kHz hsync
Modeline "640x480" 36 640 696 752 832 480 481 484 509 -HSync -VSync
# 800x600 @ 100 Hz, 64.02 kHz hsync
Modeline "800x600" 69.65 800 864 928 1088 600 604 610 640 -HSync -VSync
# 800x600 @ 56 Hz, 35.15 kHz hsync
ModeLine "800x600" 36 800 824 896 1024 600 601 603 625
# 800x600 @ 60 Hz, 37.8 kHz hsync
Modeline "800x600" 40 800 840 968 1056 600 601 605 628 +hsync +vsync
# 800x600 @ 72 Hz, 48.0 kHz hsync
Modeline "800x600" 50 800 856 976 1040 600 637 643 666 +hsync +vsync
# 800x600 @ 85 Hz, 55.84 kHz hsync
Modeline "800x600" 60.75 800 864 928 1088 600 616 621 657 -HSync -VSync
# 1024x480 for certain Vaios
Modeline "1024x480" 65 1024 1032 1176 1344 480 491 493 525 -HSync -VSync
# 1024x768 @ 100Hz, 80.21 kHz hsync
Modeline "1024x768" 115.5 1024 1056 1248 1440 768 771 781 802 -HSync -VSync
# 1024x768 @ 60 Hz, 48.4 kHz hsync
Modeline "1024x768" 65 1024 1032 1176 1344 768 771 777 806 -hsync -vsync
# 1024x768 @ 70 Hz, 56.5 kHz hsync
Modeline "1024x768" 75 1024 1048 1184 1328 768 771 777 806 -hsync -vsync
# 1024x768 @ 76 Hz, 62.5 kHz hsync
Modeline "1024x768" 85 1024 1032 1152 1360 768 784 787 823
# 1024x768 @ 85 Hz, 70.24 kHz hsync
Modeline "1024x768" 98.9 1024 1056 1216 1408 768 782 788 822 -HSync -VSync
# 1152x864 @ 100 Hz, 89.62 kHz hsync
Modeline "1152x864" 137.65 1152 1184 1312 1536 864 866 885 902 -HSync -VSync
# 1152x864 @ 60 Hz, 53.5 kHz hsync
Modeline "1152x864" 89.9 1152 1216 1472 1680 864 868 876 892 -HSync -VSync
# 1152x864 @ 70 Hz, 62.4 kHz hsync
Modeline "1152x864" 92 1152 1208 1368 1474 864 865 875 895
# 1152x864 @ 78 Hz, 70.8 kHz hsync
Modeline "1152x864" 110 1152 1240 1324 1552 864 864 876 908
# 1152x864 @ 84 Hz, 76.0 kHz hsync
Modeline "1152x864" 135 1152 1464 1592 1776 864 864 876 908
# 1280x960 @ 60 HzModeline "1280x960" 108 1280 1376 1488 1800 960 961 964 1000 +HSync +VSync
# 1280x960 @ 85 HzModeline "1280x960" 148.5 1280 1344 1504 1728 960 961 964 1011 +HSync +VSync
# 1280x1024 @ 100 Hz, 107.16 kHz hsync
Modeline "1280x1024" 181.75 1280 1312 1440 1696 1024 1031 1046 1072 -HSync -VSync
# 1280x1024 @ 61 Hz, 64.2 kHz hsync
Modeline "1280x1024" 110 1280 1328 1512 1712 1024 1025 1028 1054
# 1280x1024 @ 70 Hz, 74.59 kHz hsync
Modeline "1280x1024" 126.5 1280 1312 1472 1696 1024 1032 1040 1068 -HSync -VSync
# 1280x1024 @ 74 Hz, 78.85 kHz hsync
Modeline "1280x1024" 135 1280 1312 1456 1712 1024 1027 1030 1064
# 1280x1024 @ 76 Hz, 81.13 kHz hsync
Modeline "1280x1024" 135 1280 1312 1416 1664 1024 1027 1030 1064
# 1280x1024 @ 85 Hz, 91.15 kHz hsync
Modeline "1280x1024" 157.5 1280 1344 1504 1728 1024 1025 1028 1072 +HSync +VSync
# 1400x1050 @ 60Hz, 65.8 kHz hsync
Modeline "1400x1050" 129 1400 1464 1656 1960 1050 1051 1054 1100 +HSync +VSync
# 1400x1050 @ 70Hz, 76.8 kHz hsync
Modeline "1400x1050" 151 1400 1464 1656 1960 1050 1051 1054 1100 +HSync +VSync
# 1400x1050 @ 75Hz, 82.3 kHz hsync
Modeline "1400x1050" 162 1400 1464 1656 1960 1050 1051 1054 1100 +HSync +VSync
# 1400x1050 @ 85Hz, 93.2 kHz hsync
Modeline "1400x1050" 184 1400 1464 1656 1960 1050 1051 1054 1100 +HSync +VSync
# 1600x1200 @ 60Hz, 75.00 kHz hsync
Modeline "1600x1200" 162 1600 1664 1856 2160 1200 1201 1204 1250 +HSync +VSync
# 1600x1200 @ 70 Hz, 87.50 kHz hsync
Modeline "1600x1200" 189 1600 1664 1856 2160 1200 1201 1204 1250 -HSync -VSync
# 1600x1200 @ 75 Hz, 93.75 kHz hsync
Modeline "1600x1200" 202.5 1600 1664 1856 2160 1200 1201 1204 1250 +HSync +VSync
# 1600x1200 @ 85 Hz, 105.77 kHz hsync
Modeline "1600x1200" 220 1600 1616 1808 2080 1200 1204 1207 1244 +HSync +VSync
# 1800x1440 @ 64Hz, 96.15 kHz hsync
ModeLine "1800X1440" 230 1800 1896 2088 2392 1440 1441 1444 1490 +HSync +VSync
# 1800x1440 @ 70Hz, 104.52 kHz hsync
ModeLine "1800X1440" 250 1800 1896 2088 2392 1440 1441 1444 1490 +HSync +VSync
# Low-res Doublescan modes
# If your chipset does not support doublescan, you get a 'squashed'
# resolution like 320x400.
# 320x200 @ 70 Hz, 31.5 kHz hsync, 8:5 aspect ratio
Modeline "320x200" 12.588 320 336 384 400 200 204 205 225 Doublescan
# 320x240 @ 60 Hz, 31.5 kHz hsync, 4:3 aspect ratio
Modeline "320x240" 12.588 320 336 384 400 240 245 246 262 Doublescan
# 320x240 @ 72 Hz, 36.5 kHz hsync
Modeline "320x240" 15.750 320 336 384 400 240 244 246 262 Doublescan
# 400x300 @ 56 Hz, 35.2 kHz hsync, 4:3 aspect ratio
ModeLine "400x300" 18 400 416 448 512 300 301 302 312 Doublescan
# 400x300 @ 60 Hz, 37.8 kHz hsync
Modeline "400x300" 20 400 416 480 528 300 301 303 314 Doublescan
# 400x300 @ 72 Hz, 48.0 kHz hsync
Modeline "400x300" 25 400 424 488 520 300 319 322 333 Doublescan
# 480x300 @ 56 Hz, 35.2 kHz hsync, 8:5 aspect ratio
ModeLine "480x300" 21.656 480 496 536 616 300 301 302 312 Doublescan
# 480x300 @ 60 Hz, 37.8 kHz hsync
Modeline "480x300" 23.890 480 496 576 632 300 301 303 314 Doublescan
# 480x300 @ 63 Hz, 39.6 kHz hsync
Modeline "480x300" 25 480 496 576 632 300 301 303 314 Doublescan
# 480x300 @ 72 Hz, 48.0 kHz hsync
Modeline "480x300" 29.952 480 504 584 624 300 319 322 333 Doublescan
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
Identifier "Generic VGA"
BoardName "Unknown"
Chipset "generic"
# VideoRam 256
# Clocks 25.2 28.3
EndSection
# Device configured by Xconfigurator:
Section "Device"
Identifier "S3 Trio64 (generic)"
BoardName "Unknown"
#VideoRam 2048
# Use Option "nolinear" if the server doesn't start up correctly
# (this avoids the linear framebuffer probe). If that fails try
# option "nomemaccess".
# Refer to /usr/X11R6/lib/doc/README.S3, and the XF86_S3 man page.
# Insert Clocks lines here if appropriate
EndSection
# Screen sections
# The Colour SVGA server
Section "Screen"
Driver "svga"
Device "Generic VGA"
#Device "S3 Trio64 (generic)"
Subsection "Display"
Depth 8
#Modes (null)
ViewPort 0 0
EndSubsection
EndSection
# The 16-color VGA server
Section "Screen"
Driver "vga16"
Modes "640x480" "800x600"
ViewPort 0 0
EndSubsection
EndSection
# The Mono server
Section "Screen"
Driver "vga2"
ViewPort 0 0
EndSubsection
EndSection
# The accelerated servers (S3, Mach32, Mach8, 8514, P9000, AGX, W32, Mach64
# I128, and S3V)
Section "Screen"
Driver "accel"
DefaultColorDepth 16
Depth 16
Modes "800x600" "640x480"
ViewPort 0 0
EndSubsection
Depth 24
ViewPort 0 0
EndSubsection
Depth 32
ViewPort 0 0
EndSubsection
EndSection
XFree86Config-4
# XFree86 4.0 configuration generated by Xconfigurator
Section "ServerLayout"
Identifier "XFree86 Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
# By default, Red Hat Linux 6.0 and later use xfs
Section "Files"
EndSection
# Module loading section
Section "Module"
Load "dbe"# Double-buffering
Load "GLcore"# OpenGL support
Load "dri"# Direct rendering infrastructure
Load "glx"# OpenGL X protocol interface
Load "extmod"# Misc. required extensions
Load "v4l"# Video4Linux
# Load "pex5"# PHIGS for X 3D environment (obsolete)
# Load "record"# X event recorder
# Load "xie"# X Image Extension (obsolete)
# You only need the following two modules if you do not use xfs.
# Load "freetype" # TrueType font handler
# Load "type1"# Adobe Type 1 font handler
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
Option "XkbLayout""us"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Section "Monitor"
ModelName "Unknown"
HorizSync 30-48
VertRefresh 50-90
Option "dpms"
EndSection
Section "Device"
Driver "vesa"
BoardName "Unknown"
EndSection
Section "Device"
Identifier "Linux Frame Buffer"
Driver "fbdev"
BoardName "Unknown"
EndSection
Section "Screen"
Identifier "Screen0"
DefaultDepth 16
Depth 24
EndSubSection
Depth 16
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
