[PHP] Thumbnailer
  • kaandorp
  • Laatst online: 03-09 22:36
Ik heb vanmiddag eens even zitten stoeien met PHP en vroeg me af of onderstaande script een beetje goed in elkaar zit.
Ik heb hier niet de mogelijkheid om te testen, maar dat is ook niet echt de vraag. Mijn vraag is meer of ik dingen efficienter zou kunnen doen.
Hebben jullie hier nog op of aanmerkingen?
Misschien dat iemand het makkelijk vind om te gebruiken.
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
# script usage: Just calling image.php without any variables display's an error
# Calling the script with a filename (.jpg) returns the image exactly how it is
# Calling the script with a filename, width and height will resize the original image
# save it to the media dir with a prefix of the width and height an display it
switch ($type) {
    case (!isset($type))
        #Output the original image
        GenJPG();
    case ($type == "small")
        # Output a thumbnail (200 x 150)
        GenJPG(200,150);
    case ($type == "medium")
        # Output a medium sized image (800 x 600)
        GenJPG(800,600);
function GenJPG($ImgWidth, $ImgHeight, $filename) {
# Function to generate new images based on existing images. Only with a different size.
$SmallDir = "media/200150/"; # Directory that contains the small images
$MediumDir = "media/800600/"; # Directory that contains the medium images
    if ((!isset($filename))) {
        #No filename specified
        echo "ERROR: Filename not specified!";
    } else {
        #Filename specified
        if (!isset($ImgWidth) or !isset($ImgHeight)) {
            #ImgWidth or ImgHeight is not set, so display the original image.
            Header("Content-type: image/jpeg");
            $im = ImageCreateFromJPEG("media/".$filename);
            ImageJPEG($im,'',90);
            ImageDestroy($im);
        } else {
            #ImgWidth and ImgHeight is set, so check if there is allready a file with the right size
            #Or else generate a new image with new dimensions and save it to the appropiate folder.
            #Finally display it.
            if (is_file("media/".$ImgWidth.$ImgHeight."-".$filename) {
                #File allready exists. So display it right away.
                $im = ImageCreateFromJPEG("media/".$ImgWidth.$ImgHeight."-".$filename);
                ImageDestroy($im);
            } else {
                #BLAAT!
                $im = ImageCreateFromJpeg("media/".$filename);
                $im_tmp = ImageCreate($ImgWidth, $ImgHeight);
                imagecopyresized($im_tmp, $im, 0, 0, 0, 0, $ImgWidth, $ImgHeight, imagesx("media/".$filename), imagesy("media/".$filename))
                imagejpeg($im_tmp, "media/".$ImgWidth.$ImgHeight."-".$filename, 90)
                imagejpeg($im_tmp,'', 90)
                imagedestroy($im)
  • Grum
PHP:
error_reporting(E_ALL);
if(!isset($filename)) die('filename ?!');
if(!isset($type))     $type = '';
switch ($type) {
    case 'small':          # Output a thumbnail (200 x 150)
        GenJPG($filename, 200, 150);
        break;
    case 'medium':         # Output a medium sized image (800 x 600)
        GenJPG($filename, 800, 600);
        break;
    default:               # Output original image
        GenJPG($filename);
de rest komt zo in een edit :P
en zoals beloofd (ongetest, korter, minder foutjes)
PHP:
function GenJPG($inFileName, $inWidth = 0, $inHeight = 0)
    if (!$inWidth || !$inHeight)
        $theImage = ImageCreateFromJPEG("media/$inFileName");
    else
        if (is_file("media/$ImgWidth$ImgHeight-$inFileName"))
            $theImage = ImageCreateFromJPEG("media/$ImgWidth$ImgHeight-$inFileName");
        else
            $tmpImage = ImageCreateFromJPEG("media/$inFileName");
            $theImage = ImageCreate($ImgWidth, $ImgHeight);
            ImageCopyResized($theImage, $tmpImage, 0, 0, 0, 0, $inWidth, $inHeight, ImageSX("media/$inFileName"), ImageSY("media/$inFileName"));
            ImageDestroy($tmpImage);
            ImageJPEG($theImage, "media/$ImgWidth$ImgHeight-$inFileName", 90);
    ImageJPEG($theImage,'', 90);
    ImageDestroy($theImage);
  • kaandorp
Heb het bijna voor elkaar...
Heb nu dit:
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
if(!isset($type)) {
    $type = '';
    switch ($type) {
            break;
            break;
            GenJPG($filename);
function GenJPG($inFilename, $inWidth = 0, $inHeight = 0) {
    if (!$inWidth || !$inHeight) {
        $theImage = ImageCreateFromJPEG("media/$inFilename");
        } else {
            if (is_file("media/$inWidth$inHeight-$inFilename")) {
                $theImage = ImageCreateFromJPEG("media/$inWidth$inHeight-$inFilename");
            } else {
                $tmpImage = ImageCreateFromJPEG("media/$inFilename");
                $theImage = ImageCreate($inWidth, $inHeight);
                ImageCopyResized($theImage, $tmpImage, 0, 0, 0, 0, $inWidth, $inHeight, ImageSX("media/$inFilename"), ImageSY("media/$inFilename"));
                ImageJPEG($theImage, "media/".$inWidth.$inHeight."-".$inFilename, 90);
Het enige probleem is nu dat hij dit geeft:
Warning: Supplied argument is not a valid Image resource in C:\Inetpub\wwwroot\image.php on line 31
Warning: Supplied argument is not a valid Image resource in C:\Inetpub\wwwroot\image.php on line 32
Warning: Cannot add header information - headers already sent by (output started at C:\Inetpub\wwwroot\image.php:29) in C:\Inetpub\wwwroot\image.php on line 36
ÿØÿàJFIFÿþ;CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 90 ÿÛC     ÿÛC   ÿÀÈ"ÿÄ ÿĵ}!1AQa"q2¡#B±ÁRÑð$3br %&'()*456789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz¢£€¥Ŝ§š©ª²³Žµ¶·ž¹ºÂÃÄÅÆÇÈÉÊÒÓÔÕÖרÙÚáâãäåæçèéêñòóôõö÷øùúÿÄ ÿĵw!1AQaq"2B¡±Á #3RðbrÑ $4á%ñ&'()*56789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz¢£€¥Ŝ§š©ª²³Žµ¶·ž¹ºÂÃÄÅÆÇÈÉÊÒÓÔÕÖרÙÚâãäåæçèéêòóôõö÷øùúÿÚ ?üª¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(¢(ÿÙ
  • Grum
* Grum pakt zijn glazen bol en ziet automagisch wat line 31 is
Ik heb gewoon gepakt wat jij had gecode, gepoogd de logica erin te zien (dat deels gedaan) en dat 'hercode' op 'mijn' manier.
Maareuh die error wijst op dat er IETS fout is met het openen/aanmaken van een image.
IEK! - eventjes voor jij de source pakte heb vond ik nog een foutje (of wat ;) ) dus je moet ff overnieuw de source pakken :P )
[edit2]ik vond nog een foutje ;)[/edit]
  • kaandorp
Het is de regel:
Ik snap het niet... De inhoud van $tmpImage is: Resource id #1
Dus dat zal wel goed zijn. Hij maakt wel een nieuwe file aan. Maar die is gewoon zwart. Erg vaag...
  • Grum
zoals ik dus zei .. pak m'n code nog es ;)
  • kaandorp
Nope... Maakt niks uit... Doet helemaal niks
Zelfde error.. Kutzooi.
Crewl... ff topic onthouden :) is altijd handig...maaruh ik krijg nog steeds GD2 niet aan de praat... dus kan ik ook niet thumbnailen :{
  • kaandorp
Hmz.. Post daar ff een nieuw topic over dan. Dan kunnen we je daar misschien mee helpen.
Ben bang dat de mods hem weer sluiten als je off-topic gaat.
  • Grum
nou
of
of
gaat fout .. nu kan je zelf toch wel uitzoeken welke dat is ?
  • kaandorp
Wat er fout gaat is niet zo moeilijk. ImageCopyResized gaat fout omdat het blijkbaar in ImageCreateFromJPEG al fout gaat. Er worden namelijk wel zwarte plaatjes aangemaakt, dus ImageCreate gaat wel goed.
De vraag is echter.. WAAROM gaat het fout. En ik zou het niet weten. Alles ziet er goed uit.
  • kaandorp
Heb ik weer... Ik snap er echt geen hol van. Mijn script is niks anders dan andere resize-scripts. Heb alles al 10 keer nagelopen, maar kan de fout niet vinden.
  • Grum
bestaat: media/$inFilename ? :P
  • kaandorp
Ja... Ook als ik de pagina refresh komt er netjes de thumbnail te staan. Alleen niet de echte, maar een zwart vlak van 200 x 150.
  • Grum
:? (ik volg je even niet)
  • kaandorp
Oke.. Let op... Als ik de pagina aanroep dan geeft ie bovenstaande foutmelding dat $tmpImage geen geldige Image Source is. Echter hij creert wel een nieuwe image van 200 x 150 en maakt die gewoon helemaal zwart. Als ik dan de pagina refresh krijg ik i.p.v. foutmeldingen een zwart blok van 200 x 150 te zien. Dus dat is op zich goed, maar als $tmpImage nou een geldige Image Source zou zijn, dan zou ik geen errors krijgen en zou gewoon mijn JPEG verkleind worden i.p.v. een zwart gat.
  • Grum
en je weet meer dan 500% zeker dat media/$inFilename bestaat ?
  • kaandorp
Hmz. Zal vanavond eens een script maken zodat ik het zeker weet. Dan zet ik gewoon het volledige pad er in.
[EDIT]
O ja... Wat ik ook nog had gevonden...
ImageSX
(PHP 3, PHP 4 >= 4.0.0)
ImageSX -- Get image width
Description
int imagesx ( int im)
ImageSX() returns the width of the image identified by im.
En in mijn script staat er gewoon een verwijzing naar een file als identifier. Das dus nie goed. Wellicht dat daar die error vandaan komt.
  • Lurge
Lurge
ActueleWind
Volgens mij krijg je bij deze thumbs problemen als je fotos upload die een heel ander formaat zijn (stuk breder of langer) dan worden ze bij jou helemaal uit z'n verband gerukt volgens mij. Of je moet altijd dezelfde soort fotos gebruiken en geen staande fotos.
Anders word alles heel breeed enzo :)
ActueleWind
  • kaandorp
In de eerste instantie komen alle foto's rechtstreeks uit mijn digicam en zijn de afmetingen dus gelijk. In een later stadium wil ik ook de mogelijkheid creeren om de foto's te roteren.
  • Grum
daar kwam die error dus indeed vandaan ... maar aangezien ik geen zin had om alles na te gaan zitten kijken (heb wel een beetje vertrouwen in de mede-gotter ;) ) ben ik dat niet tegen gekomen.
  • crisp
crisp
Devver
Pixelated
Ik had ook wat problemen met GD2 en ImageCopyResized. Dit heb ik op kunnen lossen door ImageCreate te vervangen door ImageCreateTrueColor en ImageCopyResized te vervangen door ImageCopyResampled.
Dit geeft sowieso mooiere thumbs...
Intentionally left blank
  • Joto
  • Laatst online: 11-09 15:14
voor het maken va thumbs, waar de afmetingen goed van zijn doe ik
PHP:
29
30
31
32
33
function ResizePic($SourcePath,$DestPath,$W,$H,$S,$T) {
// $W = Desired Width of PIC out if 0 aspect ratio will be kept    ( $H must be set )
// $H = Desired Height of PIC out if 0 aspect ratio will be kept  ( $W must be set )
// $S = Desired Scale of PIC out 1= 100% .5 = 50% 1.5 = 150% ( over rules $W and $H)
// $T = Desired Thumb of PIC out ( over rules $W and $H and $S)
    $Extent = strtolower( strrchr ( $SourcePath, "."));
    if ($Extent ==".jpg"){$ImIn    = ImageCreateFromJPEG  ($SourcePath);}
    if ($Extent ==".png"){$ImIn    = ImageCreateFromPNG   ($SourcePath);}
    $WI=ImageSX($ImIn);
    $HI=ImageSY($ImIn);
    if ((isset($T)) and (!$T==0)){
        if ($WI>$HI){$W=$T;$H=0;}
        if ($HI>$WI){$H=$T;$W=0;}
        $S=0;
    if ((isset($S)) and (!$S==0)){
        if ($S>4){$S=4;}
        $W=$S*$WI; $H=$S*$HI;
    if ((!isset($H)) or ($H==0))    {$H=round($W/$WI*$HI);}
    if ((!isset($W)) or ($W==0))    {$W=round($H/$HI*$WI);}
    if ($W>3001){$W=200;}
    if ($H>3001){$H=200;}
    $ImOut    = ImageCreate($W,$H);
    ImageCopyResized($ImOut,$ImIn,0,0,0,0,$W,$H,$WI,$HI);
    ImageJPEG ($ImOut,$DestPath);
    ImageDestroy($ImIn);
    ImageDestroy($ImOut);
http://joto.yi.org/pics/?source=true
1+1+1 = 1
  • Grum
ik weet het ik weet het dat ik er nix van mag zeggen .. maar ik heb nu een handvol asprines nodig na et bekijken van die code :)
sorry :+
Voor wat 'uitleg' waarom: [topic=424102/1/25]
