ik heb heb nu net dante socks geïnstalleerd op mn debian server. maar als ik hem dan draai en op mn windows machine msn via socks 5 wil starten, dan doetie t niet. msn zegt dan dattie probs heeft met de internet verbinding.
dante zegt dan in debugging mode:
mn config is dit:Feb 25 20:30:44 sockd[1915]: freedescriptors(end): 1019/1024
Feb 25 20:30:44 sockd[1912]: freedescriptors(end): 1002/1024
Feb 25 20:30:44 sockd[1922]: created new requestchild
Feb 25 20:30:44 sockd[1922]: freedescriptors(start): 1019/1024
Feb 25 20:30:44 sockd[1923]: created new iochild
Feb 25 20:30:45 sockd[1912]: got accept(): 192.168.0.3.1121
Feb 25 20:30:45 sockd[1913]: accessmatch(): method: none, 192.168.0.3.1121 -> 192.168.0.1.1080
Feb 25 20:30:45 sockd[1913]: addressmatch(): address: 192.168.0.0/24, tcp: 0, udp : 0, op: none, end: 0, 192.168.0.3.1121, tcp, 0
Feb 25 20:30:45 sockd[1913]: addressmatch(): address: 0.0.0.0/0, tcp: 0, udp : 0, op: none, end: 0, 192.168.0.1.1080, tcp, 0
Feb 25 20:30:45 sockd[1913]: pass(1): tcp/accept [: 192.168.0.3.1121 -> 192.168.0.1.1080
Feb 25 20:30:45 sockd[1913]: recv_methods(): sending authentication reply: VER:5 METHOD: 0
Feb 25 20:30:45 sockd[1913]: sending request to mother
Feb 25 20:30:45 sockd[1912]: freedescriptors(start): 98/1024
Feb 25 20:30:45 sockd[1915]: received request: VER: 5 CMD: 1 FLAG: 0 ATYP: 1 address: 64.4.13.17.1863
Feb 25 20:30:45 sockd[1915]: socks_seteuid(): old: 0, new: 0
Feb 25 20:30:45 sockd[1915]: socks_reseteuid(): current: 0, new: 0
Feb 25 20:30:45 sockd[1915]: getifa(): send() to netlink failed: Connection refused (errno = 111)
Feb 25 20:30:45 sockd[1915]: freedescriptors(end): 1019/1024
Feb 25 20:30:45 sockd[1912]: freedescriptors(end): 998/1024
iemand die weet wat dr anders moet?? of werkt msn ook al niet via dit??internal: eth0 port = 1080
external: ppp0
method: none
user.privileged: root
user.notprivileged: root
logoutput: stderr
client pass {
log: connect disconnect
pass {
command: bind
pass {
command: connect udpassociate
pass {
command: bindreply udpreply
log: connect error
block {
log: connect error
Officiëel bikkel'n in #bikkels
Campzone Veld C FieldAdmin
De Veld C site!
