This error message appears for one of the following reasons:
The CD Writer has problems writing on the CD-R/RW. Please resort to another brand mark of CD-R/RW. Please ask the vendor of your CD burner for recommended brands of CD-R/RW. You will also find information in problematic CD-R/RW.
The power supply of your computer is not providing enough power.
You are using an external device. Please check the power supply and for test purposes install the burner in the computer.
Numerous graphics cards require a lot of power. The same goes for numerous CPUs and some harddisks.
the mains cable or the plug is defective. Please use another plug cable for test purposes.
The computer vibrates to such an extent that the laser can not stay in the track. In particular if a CD-ROM drive is being used as the read drive.
The device has become hot
Only operate in cool conditions.
If you have one of the following CD Writer:
Grundig CDR100IPW, HP 4020, Kodak CDR240, Mitsubishi CDVR2X4, Mitsumi CD-R CR-2401TS, Philips CDD2000, Plasmon CDR4220, Plasmon RF4100, Plasmon RF4102, Wearnes CDR-432
or are using one of the following types of
HP 6020, Mitsubishi CDVR2X6, Mitsubishi CDVR, Philips CDD2600, Wearnes CDR-632P
, then it yould be a case of the well-known grease problem. In particular if the error has only been occurring recently. Other CD Writerare also affected, in which it may help to grease the axles with silicon grease (Warning: We don't guarantee anything!) Further information on this:
If your CD burner is in the first group:
http://village.flashnet.it/~fn023975/cdd2000.html (Information on how to fix the Philips CDD2000 'Spring problem')
Users report that firmware 1.25 reduces the problem.
If your CD burner is in the second group:
German:
http://www.geocities.com/SiliconValley/Bay/6893/fixg.htm
English:
http://www.geocities.com/SiliconValley/Bay/6893/fix.htm
The lens of the write laser is dirty.
the CD-R itself is not clean or is of bad quality. In particular if writing with 8x, conditions like this become noticeable.
If 80 minute CD-Rs are being used, then the cause can be that the track distance is too small, on the limit of the specification. It is possible that you are using a CD Writer , which has problems writing on these.
Older driver versions of the file CDR4VSD.VXD (driver from Easy CD) also cause the above mentioned error message
The error message can also occur if the CD Writer has not been set up correctly.
Please set the system settings as described in recommended settings .
One case is known in which the error message appeared after exchanging the mother board. After newly setting up the motherboard (including formatting), the problem was solved.
Or there is a hardware problem.
