COOL!!! ICEHOLE.. super mooie fan adapter
  • 36 views sinds 30-01-2008
http://www.plycon.com/icehole.htm
Afbeeldingslocatie: http://www.plycon.com/icehole2.jpg
Afbeeldingslocatie: http://tweakers.net/ext/i.dsp/1006798724.jpg
Afbeeldingslocatie: http://tweakers.net/ext/i.dsp/1006798725.jpg
ICEHOLE 80mm to 60mm Fan Adapter
As with all fan adapters - it lets you use a bigger fan than you normally could on your heatsink. The difference? This one is way cool. ;-)
$39.99
An 80mm to 60mm Adapter unlike the others on the market. What sets the ICEHOLE apart? The primary differences are the variable fan voltage options and the cool LEDs embedded inside the adapter.
It is a low profile adapter (at only 14.50mm High), but the other features make it a pretty neat gadget.
The ICEHOLE features a power connector for attachment to your motherboard (via a 3 pin to 3 pin connector, or a 4 pin molex connector). If you use the 3 pin to 3 pin adapter, you can monitor the RPMs of the fan used (provided the fan supports that option). The ICEHOLE comes with the necessary adapters for both options. The Adapter also has a second 3 pin connector for use with the 80mm fan you're going to be using. 3 Dip switches let you select the voltage going to the fan to alter the fan's speed (normal (12v), medium, and low). (Be sure to only change fan speed while the computer is off to be safe...)
The ICEHOLE also lets you select the colors of the LEDS with Dip switches. It comes with blue, red, and green LEDS. You can mix and match them. This feature is basically only useful for those with window modifications to help show off the internal equipment in your case. No doubt about it - it does look cool in the dark. ;-)
Dimensions:
14.50mm H x 102mm L x 86.30mm W
/me vind dit SUPER STOER! :9~ :9~
2 plaatjes toegevoegd
  • Rollerjooster
  • Laatst online: 08-05 11:48
Rollerjooster
OhNoNotHim
Zeer zeer zeer cool. Tikje prijzig wel.
Forza Mucca!
Op maandag 25 februari 2002 00:37 schreef Rollerjooster het volgende:
wel aan de ZEER prijzige kant, jammergenoeg
  • Jimster
  • Laatst online: 21:44
Bij freezinghardware hebben ze em. Kost € 55,-
  • JT
  • Laatst online: 00:03
JT
VETAK y0
100 piek ? Daar haal ik 3 papst fans voor...
Enneh, deze is er al een tijdje.
Ecodan warmtepomp
moet zelf toch wel te maken zijn??
een dikke plaat plexiglas, beetje zagen/slijpen/schuren, gaatjes boren voor de leds, en voila!
Een glowpad/60-80 adapter :D
  • 0siris
  • Laatst online: 13-09 19:02
ik heb dat ding hier al eens zitten afzeiken... en er een mooie -1 flamebait voor gekregen. Tja, nu ik het weer zie....vinnik het WEER een lelijk ding ;)
ach...in een volgend leven lach je er om!
  • Rollerjooster
Rollerjooster
OhNoNotHim
Op maandag 25 februari 2002 00:40 schreef KingOfDos het volgende:
Het was ook nogal eufemistisch uitgedrukt :7
Voor de OCMer met budget is dit toch wel een goeie aanwinst, non?
Forza Mucca!
Op maandag 25 februari 2002 00:45 schreef Rollerjooster het volgende:
zeker wel COOLE aanwinst.
moet zelf te maken zijn.
ik zal morgen ff iets maken(plexiglas polijsten)
  • Rollerjooster
Rollerjooster
OhNoNotHim
ben benieuwd.
PICS!
Forza Mucca!
Dit is niet nieuw hoor. Ik heb daar al meerder topics over gezien :)
  • max
max
a.k.a. Bezwaarbaard
WTF!! Ik ga echt geen €40,- voor een disco neertellen hoor!
Kheb er trouwens ook geen nodig...die Alpha 8045 is stil genoeg. *D
Bald by design, beard by choice.
Inzien dat je iets niet weet, is belangrijker dan alles weten.
Op maandag 25 februari 2002 00:55 schreef Fire_escape het volgende:
ik ook niet echt, maar mischien ;)
denk dat ik er zelf eentje maak. iets met ideetje's uit dat ding.
  • The System
  • Laatst online: 03-09 11:20
ziet echt lelijk en lomp uit... dan liever 1 kleur.
ook erg duur..
wat een brakke topictitel zeg |:( mag best minder
Hebben we pas 3x voorbij zien komen....
Ik vind m ONTzettend lelijk, maar dat kan aan mij liggen.
  • Daan
  • Laatst online: 07:56
Sorry is al eens langsgeweest :)
