zo heb ik probleem 1 van de baan komt meteen de tweede al kijken.
Zou er aub iemand zijn die mij kan vertellen hoe ik target main kan aangeven zodat de links uit 't menu naar main gaan.
Alvast bedankt,
Maurice
// The following line is critical for menu operation, and must appear only once.
menunum=0;menus=new Array();_d=document;function addmenu(){menunum++;menus[menunum]=menu;}function dumpmenus(){mt="<script language=javascript>";for(a=1;a<menus.length;a++){mt+=" menu"+a+"=menus["+a+"];"}mt+="<\/script>";_d.write(mt)}
//Please leave the above line intact
// Editable properties START here //
timegap=500
followspeed=5
followrate=40
suboffset_top=10;
suboffset_left=10;
effect = "fade(duration=0.3);Shadow(color='#777777', Direction=135, Strength=6)"
hlp=[ // hlp is an array of properties you can have as many property arrays as you need
"666666", // Off Font Color
"ffffff", // Off Back Color
"000000", // On Font Color
"ff9933", // On Back Color
"666666", // Border Color
12, // Font Size
"normal", // Font Style
"normal", // Font Weight
"arial, helvetica", // Font
3, // Padding
"img/arrow.gif", // Sub Menu Image
, // 3D Border & Separator
"cccccc", // 3D High Color
"000000" // 3D Low Color
hlp1=["666666","cccccc","000000","0000CC","666666",14,"italic","normal","verdana,helvetica",5,"img/arrow.gif",,"cccccc","000000"]
hlp2=["666666","aaaaaa","000000","0000CC","666666",12,"normal","normal","comic sans ms,verdana,helvetica",3,"img/arrow.gif",,"cccccc","000000"]
hlp3=["ffffff","999999","000000","0000CC","666666",12,"normal","normal","comic sans ms,verdana,helvetica",3,"img/arrow.gif",,"cccccc","000000"]
hlp4=["ffffff","cccccc","000000","0000CC","666666",12,"normal","normal","comic sans ms,verdana,helvetica",3,"img/arrow.gif",,"cccccc","000000"]
hlp5=["ffffff","000000","000000","0000CC","666666",12,"normal","normal","comic sans ms,verdana,helvetica",3,"img/white_arrow.gif",,"cccccc","000000"]
addmenu(menu=["menu8", // this is the array that contains your menu properties and details
40, // Top
10, // left
100, // Width
1, // Border Width
"", // Screen Position - here you can use "center;middle;right"
hlp5, // Properties Array - as above
1, // Always Visible - allows the menu item to be visible at all time
"left", // Alignment - sets the menu elements alignment, HTML values are valid here
effect, // Filter - Text variable for setting transitional effects on menu activation
1, // Follow Scrolling - Tells this menu item to follow the user down the screen
, // Horizontal Menu - Tells the menu to be horizontal instead of top to bottom style
, // Keep Alive - Keeps the menu visible until the user moves over another menu or clicks elsewhere
,,,,,,,, // Reserved
, // Reserved
"Index","show-menu=menu9",,,0,
"Menu 1","show-menu=menu10",,,0,
"Portfolio","show-menu=menu12",,,0,
"Feedback","show-menu=menu13",,,1
addmenu(menu=["menu9",
,,180,1,"",hlp5,,,effect,,,,,,,,,,,,,
"Catching That Mouse","/javascript/rightclick/",,,1,
"Finding Out Image Properties","/javascript/imagesize",,,1,
"Fancy Time Script","/javascript/time",,,1,
"Form Elements","/javascript/forms/elements.php",,,1,
"Banner Ads","/javascript/banners",,,1,
"Capture Screen Properties","/javascript/screen",,,1,
"Color Picker","/javascript/colorpicker",,,1
addmenu(menu=["menu10",
,,75,1,"",hlp5,,,effect,,,,,,,,,,,,,
"Home Page","/menu",,,1,
"Samples","show-menu=menu11",,,1,
"FAQ","/menu/faq.php",,,1
addmenu(menu=["menu11",
,,160,1,"",hlp5,,,effect,,,,,,,,,,,,,
"Nice & Simple","/menu/easy_sample.php",,,1,
"Using Images","/menu/images_sample.php",,,1,
"Following you as you scroll","/menu/scrolling_sample.php",,,1,
"Sub Menus All Around","/menu/submenus_sample.php",,,1,
"Diferent Colored Menus","/menu/multicolor_sample.php",,,1,
"Menus With Multiple Properties","/menu/multiprop_sample.php",,,1,
"Always There","/menu/always_sample.php",,,1
addmenu(menu=["menu12",
"Soos Website","http://.web1000.com",,,1,
"Bangin Hardcore","http://www.core.tk",,,1
addmenu(menu=["menu13",
"Scan a web Server","/probe.php",,,1,
"Dmaon Name Lookup","/whois.php",,,1
// Editable properties END here //
dumpmenus() // This must be the last line in this file
Alvast bedankt,
Maurice
timegap=500
followspeed=5
followrate=40
suboffset_top=10;
suboffset_left=10;
12, // Font Size
3, // Padding
40, // Top
10, // left
100, // Width
1, // Border Width
, // Reserved
