; BIND data file for local loopback interface
web-freak.net.INSOA213.51.49.177 webmaster.web-freak.net. (
915373270
10800
3600
432000
38400 )
web-freak.net.INNS213.51.49.177
web-freak.net.IN MX 10web-freak.net.
web-freak.net.INA213.51.49.177
mail.A213.51.49.177
tijsA213.51.49.177
sanderA213.51.49.177
jeroentjeA213.51.49.177
www.web-freak.net.INCNAMEweb-freak.net.
ftp.web-freak.net.INCNAMEweb-freak.net.
mail.web-freak.net.38400INCNAMEmail.
// This is the primary configuration file for the BIND DNS server named.
// Please read /usr/share/doc/bind9/README.Debian for information on the
// structure of BIND configuration files in Debian, *BEFORE* you customize
// this configuration file.
options {
directory "/var/cache/bind";
// If there is a firewall between you and nameservers you want
// to talk to, you might need to uncomment the query-source
// directive below. Previous versions of BIND always asked
// questions using port 53, but BIND 8.1 and later use an unprivileged
// port by default.
// query-source address * port 53;
// If your ISP provided one or more IP addresses for stable
// nameservers, you probably want to use them as forwarders.
// Uncomment the following block, and insert the addresses replacing
// the all-0's placeholder.
// forwarders {
// 0.0.0.0;
auth-nxdomain no; # conform to RFC1035
// prime the server with knowledge of the root servers
zone "." {
type hint;
file "/etc/bind/db.root";
// be authoritative for the localhost forward and reverse zones, and for
// broadcast zones as per RFC 1912
zone "localhost" {
type master;
file "/etc/bind/db.local";
zone "127.in-addr.arpa" {
type master;
file "/etc/bind/db.127";
zone "0.in-addr.arpa" {
type master;
file "/etc/bind/db.0";
zone "255.in-addr.arpa" {
type master;
file "/etc/bind/db.255";
// add entries for other zones below here
zone "web-freak.net" {
type master;
file "/etc/bind/db.webfreak.net";
Ik heb hem nu zo staan maar helaas het werkt nog niet...
