Logitech mouseware drivers.Logitech reactie.
Ik heb logitech een mail gestuurd over hun mouseware drivers.
Dit is me Mailtje:
have troubles with The Mouseware software under Games. I bought a Dual
optical but i can't use your mouseware software, because under games the
scrollwheel and the 4th button doesn,t work. Can't u fix this. The new
Microsoft software i used before was fantastic. Can't u ad a profile map
for executbles. So u can make a profile for executables for you mouse. Or
fix the Scrollwheel and 4th mouse button fix for windows XP.
I hope you will do this cause a lot of people are waiting for the
solution. You produce the best mices there are but the software is crappy.
I hope u will contact me maybe i can test you new mouseware so we can fix
these problems.
Dit is de reactie van logitech erop:
Thank you for using Logitech's Electronic Technical Support. My name is Brian. The following information addresses your original question. You may wish to print this out and/or save this on your computer.
It may be necessary to run the mouse off of Logitech Mouse driver support only, without the additional support of Logitech MouseWare. To do this, simply have Logitech MouseWare installed on your computer. Then before you start the game, turn off MouseWare.
To do this hit <ctrl>, <alt>, and <del>, and end the EM_EXEC.EXE process. This will disable the Logitech MouseWare, and in the game you will be able to assign functions to additional buttons and the scroll wheel.
Dit is mijn reactie op logitechs reactie:
Hello Brian,
Could logitech not program a descent mouse driver such as microsft intelli
soft for their Intelli mouses, they can deliver dedicated mouse drivers so
why can't you???
By closing your mouse driver is not a solution. It is just a way to go
around it and not facing the problem
Snappen jullie wat ik bedoel volgens mij heeft logitech iets te weinig software programmeurs aangenomen, want ze leveren maar half werk, terwijl logitech de naam heeft om zijn muizen mogen ze ze onderhad ook wel eens goede drivers op de markt brengen aangezien een muis toch redelijk vaak gebruikt wordt als je achet je pc zit.
  • Korn21
  • Laatst online: 02-03-2017
Ik heb een Logitech Trackman Marble FX. Uitstekend ding en doet het na al die jaren nog uitstekend en daarnaast is dat ding 'superscherp'! De drivers zijn ook ok!
|Specs|
  • Tobias
  • Laatst online: 06:01
daar hebben ze bij logitech al een patch voor gemaakt:
http://www.logitech.com/cf/support/mousefiles_w98.cfm
"So long, coffin stuffers!" (Bender wrecks his car) "Eeeh, could one of you coffin stuffers please carry me?"
  • BaatZ
  • Laatst online: 27-08 15:57
BaatZ
Prullenbakker :?
vind ik een stomme reactie.
als je wat beter op de site kijkt, kom je een ZEER GOED PASSENDE PERMANENTE OPLOSSING tegen, namelijk een registry fix.
ik zal je ff helpen...
druk start-->run(uitvoeren)
typ in:
regedit
ga naar
HKEY_LOCAL_MACHINE\software\logitech\mouseware\currentversion\technical
zorg ervoor dat de betreffende keys er zo uitzien:
"MouseHookDllEnable"="0"
"WheelMsgToVmouse"="0"
je muis zal werken.
er is ook een executable regpatch te downloaden op de logitech site...
Afbeeldingslocatie: http://tweakers.net/~crew/Exirion/pics/utfs.gif
BaatZ. Want niet álles kan lekker zijn.
jah maar zoiezo als je drivers uitbrengt ga je geen regisrty fix ervoor uitbrengen, zorg gewoon dat als je drivers maakt, dat deze ook werken. Kijk naar de intelli soft van microsoft die werkt perfect.
Op dinsdag 19 februari 2002 22:56 schreef X-Master het volgende:
Als je microsoft nou zo fantastisch vind koop dan gewoon een microsoft muis :+
Op woensdag 20 februari 2002 08:40 schreef Bandiet het volgende:
Jah ik heb al een explorer versie 1, hun software is goed maar die van logitech dual optical is iets nauwkeuriger en ligt fijner in de hand. Ik verwacht gewoon van logitech dat ze fatsoenlijke drivers produceren. Het is toch gewoon weg slecht dat die drivers nie goed ontwikkeld zijn als je muizen produceert.
  • Sjah
  • Laatst online: 13:29
haha dit doet me denken aan de reactie die ik kreeg van relisys, maker van mijn scanner.
die werkte niemeer. ik taiwain mailen, krijg ik mailtje terug:
Dear Sir, we advice you to format c: and reinstall your Windows operating system. >:)
