[PHP] Ik heb ergens een instelling niet goed.
Hey ik krijg met bijna alles deze foutmelding:
Fatal error: Failed opening required 'lib.inc.php' (include_path='/usr/sausalito/ui/libPhp') in /home/users/cybershop/web/phpMyAdmin/index.php on line 3
Ligt dit aan het path, of heeft het met magic quotes te maken? Wie o wie kan me helpen en me vertellen wat ik niet goed heb. Thanks a lot.
Mijn phpinfo ziet er als volgt uit:
PHP Version 4.0.4
System Linux lease24.cobalt.com 2.2.16C7 #1 Fri Sep 8 15:58:03 PDT 2000 i586 unknown
Build Date Feb 27 2001
Configure Command './configure' '--prefix=/usr' '--with-apxs=/usr/sbin/apxs' '--with-gd' '--with-gettext' '--enable-safe-mode' '--with-config-file-path=/etc/httpd' '--with-exec-dir=/usr/bin' '--with-zlib' '--enable-magic-quotes' '--with-regex=system' '--with-ttf=/usr/lib/libttf.so' '--enable-track-vars' '--enable-xml' '--disable-debug' '--with-interbase=shared' '--with-mysql=shared' '--with-pgsql=shared' '--with-imap'
Server API Apache
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/httpd
ZEND_DEBUG disabled
Thread Safety disabled
This program makes use of the Zend scripting language engine:
Zend Engine v1.0.3, Copyright (c) 1998-2000 Zend Technologies
PHP 4.0 Credits
Configuration
PHP Core
Directive Local Value Master Value
allow_call_time_pass_reference
Off Off
allow_url_fopen
1 1
arg_separator
asp_tags
Off Off
auto_append_file
no value no value
auto_prepend_file
no value no value
browscap
no value no value
default_charset
no value no value
default_mimetype
text/html text/html
define_syslog_variables
Off Off
disable_functions
no value no value
display_errors
On On
display_startup_errors
Off Off
doc_root
no value no value
enable_dl
On On
error_append_string
Off Off
error_log
no value no value
error_prepend_string
Off Off
error_reporting
2039 2039
expose_php
On On
extension_dir
/usr/lib/apache/php /usr/lib/apache/php
file_uploads
1 1
gpc_order
GPC GPC
highlight.bg
#FFFFFF #FFFFFF
highlight.comment
#FF8000 #FF8000
highlight.default
#0000BB #0000BB
highlight.html
#000000 #000000
highlight.keyword
#007700 #007700
highlight.string
#DD0000 #DD0000
html_errors
On On
ignore_user_abort
Off Off
implicit_flush
Off Off
include_path
/usr/sausalito/ui/libPhp /usr/sausalito/ui/libPhp
log_errors
Off Off
magic_quotes_gpc
Off Off
magic_quotes_runtime
Off Off
magic_quotes_sybase
Off Off
max_execution_time
300 300
open_basedir
no value no value
output_buffering
Off Off
output_handler
no value no value
post_max_size
8M 8M
precision
14 14
register_argc_argv
Off Off
register_globals
On On
safe_mode
Off Off
safe_mode_exec_dir
no value no value
sendmail_from
me@localhost.com me@localhost.com
sendmail_path
/usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
short_open_tag
On On
SMTP
localhost localhost
sql.safe_mode
Off Off
track_errors
Off Off
upload_max_filesize
134217728 134217728
upload_tmp_dir
/home/tmp /home/tmp
user_dir
no value no value
variables_order
GPCS GPCS
y2k_compliance
Off Off
mysql
MySQL Support enabled
Active Persistent Links 0
Active Links 0
Client API version 3.23.22-beta
MYSQL_INCLUDE
MYSQL_LFLAGS
MYSQL_LIBS
mysql.allow_persistent
On On
mysql.default_host
no value no value
mysql.default_password
no value no value
mysql.default_port
no value no value
mysql.default_socket
no value no value
mysql.default_user
no value no value
mysql.max_links
Unlimited Unlimited
mysql.max_persistent
Unlimited Unlimited
zlib
ZLib Support enabled
'zlib:' fopen wrapper enabled
Compiled Version 1.1.3
Linked Version 1.1.3
xml
XML Support active
standard
Regex Library System library enabled
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.active
1 1
assert.bail
0 0
assert.callback
no value no value
assert.quiet_eval
0 0
assert.warning
1 1
safe_mode_allowed_env_vars
PHP_ PHP_
safe_mode_protected_env_vars
LD_LIBRARY_PATH LD_LIBRARY_PATH
session.use_trans_sid
1 1
session
Session Support enabled
session.auto_start
Off Off
session.cache_expire
180 180
session.cache_limiter
nocache nocache
session.cookie_domain
no value no value
session.cookie_lifetime
0 0
session.cookie_path
session.cookie_secure
Off Off
session.entropy_file
no value no value
session.entropy_length
0 0
session.gc_maxlifetime
1440 1440
session.gc_probability
1 1
session.name
PHPSESSID PHPSESSID
session.referer_check
no value no value
session.save_handler
files files
session.save_path
/tmp /tmp
session.serialize_handler
php php
session.use_cookies
On On
posix
Revision $Revision: 1.27 $
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 3.1 09-Feb-2000
imap
IMAP Support enabled
IMAP c-Client Version 4.1
gettext
GNU GetText Support enabled
gd
GD Support enabled
GD Version between 1.3 and 1.6.1
FreeType Support enabled
FreeType Linkage with TTF library
GIF Support enabled
apache
APACHE_INCLUDE
APACHE_TARGET
Apache Version Apache/1.3.12 Cobalt
Apache Release 10312100
Apache API Version 19990320
Hostname:Port qube3.cyberlynda:80
User/Group httpd(15)/11
Max Requests Per Child: 50000
Keep Alive: on
Max Per Connection: 0
Timeouts Connection: 300
Keep-Alive: 15
Server Root /etc/httpd
Loaded Modules mod_php4, mod_setenvif, mod_unique_id, mod_auth, mod_auth_pam, mod_access, mod_rewrite, mod_alias, mod_userdir, mod_actions, mod_imap, mod_asis, mod_cgi, mod_frontpage, mod_dir, mod_autoindex, mod_include, mod_status, mod_negotiation, mod_mime, mod_log_config, mod_define, mod_env, mod_ssl, mod_perl, mod_so, http_core
Apache Environment
Variable Value
DOCUMENT_ROOT /home/groups/home/web
HTTP_ACCEPT image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/vnd.ms-powerpoint, application/vnd.ms-excel, application/msword, */*
HTTP_ACCEPT_ENCODING gzip, deflate
HTTP_ACCEPT_LANGUAGE nl
HTTP_CONNECTION Keep-Alive
HTTP_HOST 10.6.18.1
HTTP_USER_AGENT Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; Q312461)
PATH /sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin
REMOTE_ADDR 10.6.18.38
REMOTE_PORT 1661
SCRIPT_FILENAME /home/users/cybershop/web/phpinfo.php
SCRIPT_URI http://qube3.cyberlynda/~cybershop/phpinfo.php
SCRIPT_URL /~cybershop/phpinfo.php
SERVER_ADDR 10.6.18.1
SERVER_ADMIN admin@qube3.cyberlynda
SERVER_NAME qube3.cyberlynda
SERVER_PORT 80
SERVER_SIGNATURE
SERVER_SOFTWARE Apache/1.3.12 Cobalt (Unix) PHP/4.0.4 mod_auth_pam/1.0a FrontPage/4.0.4.3 mod_ssl/2.6.6 OpenSSL/0.9.5a mod_perl/1.24
UNIQUE_ID PHI0ggoGEgEAAAyu46A
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.1
REQUEST_METHOD GET
QUERY_STRING
REQUEST_URI /~cybershop/phpinfo.php
SCRIPT_NAME /~cybershop/phpinfo.php
HTTP Headers Information
HTTP Request Headers
HTTP Request GET /~cybershop/phpinfo.php HTTP/1.1
Accept image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/vnd.ms-powerpoint, application/vnd.ms-excel, application/msword, */*
Accept-Encoding gzip, deflate
Accept-Language nl
Connection Keep-Alive
Host 10.6.18.1
User-Agent Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; Q312461)
HTTP Response Headers
Vary Host
X-Powered-By PHP/4.0.4
Keep-Alive timeout=15
Transfer-Encoding chunked
Content-Type text/html
Additional Modules
Environment
Variable Value
INIT_VERSION sysvinit-2.77
previous N
TERM linux
HOSTTYPE i386
CONSOLE /dev/null
HOME /
PREVLEVEL N
RUNLEVEL 3
SHELL /bin/bash
runlevel 3
OSTYPE Linux
SHLVL 2
ip off
_ /usr/sbin/httpd
PHP Variables
Variable Value
PHP_SELF /~cybershop/phpinfo.php
HTTP_SERVER_VARS["DOCUMENT_ROOT"] /home/groups/home/web
HTTP_SERVER_VARS["HTTP_ACCEPT"] image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/vnd.ms-powerpoint, application/vnd.ms-excel, application/msword, */*
HTTP_SERVER_VARS["HTTP_ACCEPT_ENCODING"] gzip, deflate
HTTP_SERVER_VARS["HTTP_ACCEPT_LANGUAGE"] nl
HTTP_SERVER_VARS["HTTP_CONNECTION"] Keep-Alive
HTTP_SERVER_VARS["HTTP_HOST"] 10.6.18.1
HTTP_SERVER_VARS["HTTP_USER_AGENT"] Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; Q312461)
HTTP_SERVER_VARS["PATH"] /sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin
HTTP_SERVER_VARS["REMOTE_ADDR"] 10.6.18.38
HTTP_SERVER_VARS["REMOTE_PORT"] 1661
HTTP_SERVER_VARS["SCRIPT_FILENAME"] /home/users/cybershop/web/phpinfo.php
HTTP_SERVER_VARS["SCRIPT_URI"] http://qube3.cyberlynda/~cybershop/phpinfo.php
HTTP_SERVER_VARS["SCRIPT_URL"] /~cybershop/phpinfo.php
HTTP_SERVER_VARS["SERVER_ADDR"] 10.6.18.1
HTTP_SERVER_VARS["SERVER_ADMIN"] admin@qube3.cyberlynda
HTTP_SERVER_VARS["SERVER_NAME"] qube3.cyberlynda
HTTP_SERVER_VARS["SERVER_PORT"] 80
HTTP_SERVER_VARS["SERVER_SIGNATURE"]
HTTP_SERVER_VARS["SERVER_SOFTWARE"] Apache/1.3.12 Cobalt (Unix) PHP/4.0.4 mod_auth_pam/1.0a FrontPage/4.0.4.3 mod_ssl/2.6.6 OpenSSL/0.9.5a mod_perl/1.24
HTTP_SERVER_VARS["UNIQUE_ID"] PHI0ggoGEgEAAAyu46A
HTTP_SERVER_VARS["GATEWAY_INTERFACE"] CGI/1.1
HTTP_SERVER_VARS["SERVER_PROTOCOL"] HTTP/1.1
HTTP_SERVER_VARS["REQUEST_METHOD"] GET
HTTP_SERVER_VARS["QUERY_STRING"]
HTTP_SERVER_VARS["REQUEST_URI"] /~cybershop/phpinfo.php
HTTP_SERVER_VARS["SCRIPT_NAME"] /~cybershop/phpinfo.php
HTTP_SERVER_VARS["PATH_TRANSLATED"] /home/users/cybershop/web/phpinfo.php
HTTP_SERVER_VARS["PHP_SELF"] /~cybershop/phpinfo.php
PHP License
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net.
  • oZy
  • Laatst online: 21:16
oZy
lees anders de readme van phpmyadmin even.. :Z
en voor de rest: zie sig.
  • Glimi
Glimi
Designer Drugs
(overleden)
Hmmz lijkt mij gewoon dat PhpMyAdmin zijn inc filetje niet goed heeft staan. Kijk eens of hij daar staat en of de rechten goed staan (world readable)
Nog wat extra's: Dit topic hoort hier niet echt thuis geloof ik. Configuratie problemen kun je beter in NOS ( http://gathering.tweakers.net/listtopics.php/23 )stellen, daar zijn mensen die er meer van af weten. Plus dat het niet fijn is om je PHPinfo zo neer te kwakken. Geef dan de URL waar we hem kunnen vinden, maar zoals hij nu er staat zal _niemand_ het doorlezen. Om dit topic te verplaatsen moet je het ff vragen in SU ( http://gathering.tweakers.net/listtopics.php/26 )
Sorry van die phpinfo. Ik denk echt dat ik hier moet wezen. Het probleem doet zich namelijk niet alleen voor bij phpmysqladmin, maar bij alles wat ik probeer te doen. Dus ik denk dat het path niet helemaal lekker is.
1) haal die phpinfo weg, desnoods plaats je een url, maar denk niet dat we die nodig hebben
2) plak hier je code waar je iets probeert te includen (of requiren)
  • MikeN
  • Laatst online: 13-09 17:41
Je moet in php.ini even de . (een losse punt dus) in je include path opnemen. Verder hoort dit niet in PW eerder in NOS of SA en dan nog is dit vast wel op de site van PhpMyAdmin te vinden.
  • oZy
oZy
heeft er hier nog nooit iemand met phpMyAdmin gewerkt ofzo? :?
tommie: kijk in je phpmyadmin dir, open inc.config.php (ofzo) en verander de variable naar de absolute path!! staat ook duidelijk in de readme dat je dit eerst moet doen voordat het werkt.
Lees dus voortaan eerst even de readme / install.txt / docs etc van het script / programma wat je wilt installeren.
  • MikeN
Hij gaf aan dat hij het probleem vaker had, als hij die punt in z'n include path zet, is het voortaan opgelost.
