Msx Format Single Side Floppy op PC
  • 159 views sinds 30-01-2008
  • wimpie007
  • Laatst online: 24-10 20:37
Hallo allemaal
Ik heb al gesearched maar kon er niets over vinden.
Ik heb gisteren mijn MSX met externe Single Side 3,5 inch floppy drive uit de kast getrokken. Nu moet ik een paar nieuwe diskettes formatteren. Ik heb al gevonden hoe je dat ongeveer zou moeten doen: format a: /1 de 1 is op ss formatteren
Please help me!
  • wimpie007
Ff een aanvulling,
Ik krijg dan de foutmelding dat de parameters are not compatible.
Help????
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon),
mount point, or volume name.
/FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS).
/V:label Specifies the volume label.
/Q Performs a quick format.
/C Files created on the new volume will be compressed by
default.
/X Forces the volume to dismount first if necessary. All opened
handles to the volume would no longer be valid.
/A:size Overrides the default allocation unit size. Default settings
are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K,
(128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K,
Note that the FAT and FAT32 files systems impose the
following restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526
FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that
the above requirements cannot be met using the specified
cluster size.
NTFS compression is not supported for allocation unit sizes
above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8).
/T:tracks Specifies the number of tracks per disk side.
/N:sectors Specifies the number of sectors per track.
/1 Formats a single side of a floppy disk.
/4 Formats a 5.25-inch 360K floppy disk in a
high-density drive.
/8 Formats eight sectors per track.
Sorry, te snel op verstuur gedrukt. Kheb griep... :(
Hier heb je alle opties voor format, daar moet je even mee experimenteren totdat je de juiste combinatie gevonden hebt.
  • wimpie007
Jo bedankt maar, deze opties had ik al maar hij zegt dat de parameters niet compatibel zijn, en jij weet ook zeker niet wat de standaard voor Msx 3,5 diskettes is he?
Maarre beterschap toegewenst en bedankt dat je toch ff kon reageren
Mazolos
Raymond
  • TFHfony
  • Laatst online: 10:39
TFHfony
Professional Weirdo
Je moet gewoon op je MSX in BASIC het volgende commando geven:
_format
of
call format
Hierna kan je gewoon op je MSX-je de floppy formateren. Dit is ook beter dan dit op de PC doen, want de bootsector die je PC op de floppy gooit laat je MSX-je crashen.
  • Eindbaas
  • Laatst online: 25-10 08:26
zie ook mijn reply in het Wie heeft z'n MSX nog....... topic :)
Wacht, ik maak de msx liefhebber/kenner even wakker
SWIIIIIEEEEEEEEEEEEEEEEEEEEEEEEEPPPPPPPPPP!!!!!
Ben benieuwd offie het gehoord heeft >:)
Op dinsdag 19 februari 2002 14:32 schreef Sepans het volgende:
  • GaMeOvEr
  • Laatst online: 17:07
GaMeOvEr
Is een hork.
Hoi wimpie007, gaarne verder gaan in je topic in OIC : [topic=416170] en voortaan niet meer crossposten ok ?
Aannames zijn fataal.
