[Smoothwall] [ISDN] [@work] Inbellen lukt niet
  • thomaske
  • Laatst online: 14-07 14:28
thomaske
Hallo!
Ik heb het volgende probleem: Ik kan met Smoothwall (linux router) niet inbellen naar @work (met ISDN). Terwijl @work wel werkt op w2k en ik met smootwall wel naar andere ISP's in kan bellen.
Als ik de log (/var/log/messages) erop nazoek zie ik het volgende bij een gelukte verbinding:
Feb 18 20:45:49 margot kernel: ippp0: dialing 1 31*********...
Feb 18 20:45:50 margot kernel: isdn_net: ippp0 connected
Feb 18 20:45:50 margot ipppd[4611]: Local number: 31*********, Remote number: 31*********, Type: outgoing
Feb 18 20:45:50 margot ipppd[4611]: PHASE_WAIT -> PHASE_ESTABLISHED, ifunit: 0, linkunit: 0, fd: 7
Feb 18 20:45:51 margot ipppd[4611]: Remote message:
Feb 18 20:45:51 margot ipppd[4611]: MPPP negotiation, He: No We: No
Feb 18 20:45:51 margot ipppd[4611]: CCP enabled! Trying CCP.
Feb 18 20:45:51 margot ipppd[4611]: CCP: got ccp-unit 0 for link 0 (protocol: 0x80fd)
Feb 18 20:45:51 margot ipppd[4611]: ccp_resetci!
Feb 18 20:45:51 margot ipppd[4611]: local  IP address 62.21.137.182
Feb 18 20:45:51 margot ipppd[4611]: remote IP address 62.21.128.42
Feb 18 20:45:52 margot smoothwall: PPP has gone up on ippp0
en ik zie dit bij de verbinding naar @work:
Feb 18 20:03:44 margot kernel: ippp0: dialing 1 31*********...
Feb 18 20:03:48 margot kernel: isdn_net: ippp0 connected
Feb 18 20:03:48 margot ipppd[4266]: Local number: 31*********, Remote number: 31*********, Type: outgoing
Feb 18 20:03:48 margot ipppd[4266]: PHASE_WAIT -> PHASE_ESTABLISHED, ifunit: 0, linkunit: 0, fd: 7
Feb 18 20:03:49 margot kernel: ippp0: remote hangup
Feb 18 20:03:49 margot kernel: ippp0: Chargesum is 0
Feb 18 20:03:49 margot ipppd[4266]: Modem hangup
Feb 18 20:03:49 margot ipppd[4266]: Connection terminated.
Feb 18 20:03:49 margot ipppd[4266]: taking down PHASE_DEAD link 0, linkunit: 0
Feb 18 20:03:49 margot ipppd[4266]: closing fd 7 from unit 0
Feb 18 20:03:49 margot ipppd[4266]: link 0 closed , linkunit: 0
Feb 18 20:03:49 margot ipppd[4266]: reinit_unit: 0
Feb 18 20:03:49 margot ipppd[4266]: Connect[0]: /dev/ippp0, fd: 7
Het ligt niet aan de user/pass, wanneer ik deze namelijk verander krijg ik daarover een foutmelding. Weet iemand waar het aan kan liggen?
Brusselmans: "Continuïteit bestaat niet, tenzij in zinloze vorm. Iets wat continu is, is obsessief, dus ziekelijk, dus oninteressant, dus zinloos."
  • active2
  • Laatst online: 17-07 21:56
active2
Google is your friend
Heb je misschien ook nog wat meldingen van je firewall?
Ik bedoel dus:
De meldingen die zeggen dat je firewall wat geblokt heeft! :)
Google, Het mirakel van de 21e eeuw!!!!
  • thomaske
thomaske
Er komen geen meldingen in de log voorbij mbt de firewall. Maar heeft dat iets te maken met het inbellen dan?
Staat je MSN / EAZ wel goed?
  • thomaske
thomaske
Jep, en alles al geprobeerd. met 31, zonder 31 etc
  • xychix
  • Laatst online: 03-12-2025
xychix
FreeBSD Rules !
je moet je telefoonnummer ZONDER netnummer invoeren.
en probeeer eens hetzelfde nr op te geven als je op het formulier als cli nummer hebt ingevuld.....
welk nummer heb je als cli nummer opgegeven ??? dit MOET het HOOFDNUMMER zijn en niet een van de 4 waarmee jij in wilt kunnen bellen !!
alsdus een @work medewerker stond er in isdn header pakketjes een FROM nummer (1 van de 4) en een CLI nummer (1 van de 1 !!!! dwz. het hoofd nummer = het nummmer dat je ook al had VOOR dat je isdn had !!) misschien ligt het daaraan ?
(WAAROM BEN IK NOG NIET AANSLUITEN!!! ik zou eind vorigeweek een password ontvangen)
Every failure offers you a new opportunity! | Lokatie database|GoT - Notepad
  • thomaske
thomaske
Hmm, eindelijk werkt het.. weet eigenlijk niet waarom, heb namelijk constant aan alle instellingen lopen kutten ;)
Moet je gewoon even bellen en dan voor Sales kiezen, maken ze het gelijk voor je in orde!
