cobalt raq4 server en MySQL
Aangenaam,
Meph is de naam en ben een zware unix newby :?
Zojuist op een cobalt (managed host webserver) mysql geinstalleerd zodat ik een php forumpje kan installeren.
Na heel wat gekloot heb ik volgens mij mijn MySQL op deze server een beetje naar de klote geholpen.
Als ik nu via phpmyadmin op users klik zie ik het volgende:
________________________________________________________
Warning: Supplied argument is not a valid MySQL result resource in /home/sites/home/web/phpmyadmin/user_details.php on line 970
Warning: Cannot add header information - headers already sent by (output started at /home/sites/home/web/phpmyadmin/user_details.php:970) in /home/sites/home/web/phpmyadmin/libraries/ob.lib.php on line 53
Warning: Cannot add header information - headers already sent by (output started at /home/sites/home/web/phpmyadmin/user_details.php:970) in /home/sites/home/web/phpmyadmin/header.inc.php on line 23
Warning: Cannot add header information - headers already sent by (output started at /home/sites/home/web/phpmyadmin/user_details.php:970) in /home/sites/home/web/phpmyadmin/header.inc.php on line 24
Warning: Cannot add header information - headers already sent by (output started at /home/sites/home/web/phpmyadmin/user_details.php:970) in /home/sites/home/web/phpmyadmin/header.inc.php on line 25
Warning: Cannot add header information - headers already sent by (output started at /home/sites/home/web/phpmyadmin/user_details.php:970) in /home/sites/home/web/phpmyadmin/header.inc.php on line 26
Warning: Cannot add header information - headers already sent by (output started at /home/sites/home/web/phpmyadmin/user_details.php:970) in /home/sites/home/web/phpmyadmin/header.inc.php on line 27
Warning: Cannot add header information - headers already sent by (output started at /home/sites/home/web/phpmyadmin/user_details.php:970) in /home/sites/home/web/phpmyadmin/header.inc.php on line 29
Any host - Any user
Error
MySQL said:
No user(s) found.
Nu heb ik MySQL gedeinstalleerd, en een andere versie geinstalleerd.
uiteraard zij hij tijdens deze installatie dat er nog wat mysql data op de cobalt stond welke hij niet aan ging passen.
Na het installeren van MySQL moet ik altijd het volgende ingeven:
mysqladmin -uroot -pcobalt-mysql password NEW-PASSWORD
om een nieuw wachtwoord aan te maken voor de rootuser van MySQL.
wanneer ik dat commando ingeef krijg ik de volgende foutmelding:
mysqladmin: connect to server at 'localhost' failed
error: 'Access denied for user: 'root@localhost' (Using password: YES)'
Hoe kan ik dit probleem oplossen zodat ik weer gewoon een database-je kan aanmaken met een usertje voor mij forumpke?
GreetZ
Als je MySQL opnieuw installeerd gebruikt hij standaard voor 'root' een blanco password. Geloof ik.. :)
normaal wel
en met mysqladmin -uroot -pcobalt-mysql password NEW-PASSWORD zou ik een nieuw wachtwoord moeten kunnen ingeven dan..
maar helaas...
Op maandag 18 februari 2002 20:42 schreef Meph het volgende:
Misschien moet je de -p weglaten.. :)
Op maandag 18 februari 2002 20:43 schreef rhand0z het volgende:
hehehe helaas niet:)
Ik heb het hier zelf geprobeerd (weliswaar geen Cobalt, maar als je opnieuw compileerd is dat allemaal hetzelfde), en als ik geen -p aan mysqladmin meegeef gebruikt hij geen password. :)
[root /root]# mysqladmin -uroot -cobalt-mysql password 2m@#a93
mysqladmin: invalid option -- c
mysqladmin: invalid option -- o
mysqladmin: invalid option -- b
mysqladmin: invalid option -- a
mysqladmin: invalid option -- l
Illegal option character ''
mysqladmin Ver 8.18 Distrib 3.23.36, for pc-linux-gnu on i686
Copyright (C) 2000 MySQL AB & MySQL Finland AB & TCX DataKonsult AB
This software comes with ABSOLUTELY NO WARRANTY. This is free software,
and you are welcome to modify and redistribute it under the GPL license
Administration program for the mysqld daemon.
Usage: mysqladmin [OPTIONS] command command....
Ik bedoelde eigenlijk.. :z de hele -p tag.. Dus -cobalt ook weg.. :) zodat er helemaal geen password doorgegeven wordt.. :z..
Succes met je forum.
