[cisco] rip 'breidt zelf' subnetten uit
  • wizl
  • Laatst online: 27-02-2023
op mijn cisco router heb ik rip ge'enabled om zo de routes die hij kent wereldkundig te maken (op mijn lan dan :) )
de 'sh ru' met de routes ziet er zo uit:
29
30
31
32
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 10.10.10.0 255.255.255.0 Dialer23
ip route 10.129.1.204 255.255.255.255 Dialer12
ip route 10.202.1.0 255.255.255.0 Dialer11
ip route 10.204.1.0 255.255.255.0 Dialer12
ip route 10.205.1.0 255.255.255.0 Dialer13
ip route 10.206.1.0 255.255.255.0 Dialer14
ip route 10.207.1.0 255.255.255.0 Dialer15
ip route 10.208.1.0 255.255.255.0 Dialer16
ip route 55.0.0.0 255.0.0.0 Dialer24
ip route 90.0.0.0 255.255.255.0 Dialer38
ip route 128.0.0.197 255.255.255.255 Dialer34
ip route 128.0.0.251 255.255.255.255 Dialer34
ip route 130.0.0.0 255.255.255.0 Dialer33
ip route 130.5.0.0 255.255.0.0 Dialer22
ip route 172.18.71.0 255.255.255.0 Dialer37
ip route 192.168.1.0 255.255.255.0 Dialer20
ip route 192.168.2.0 255.255.255.0 Dialer21
ip route 192.168.2.7 255.255.255.255 Dialer1
ip route 192.168.3.0 255.255.255.0 Dialer7
ip route 192.168.4.0 255.255.255.248 Dialer30
ip route 192.168.6.0 255.255.255.0 Dialer36
ip route 192.168.29.3 255.255.255.255 192.168.0.183
ip route 192.168.100.10 255.255.255.255 Dialer10
ip route 192.168.100.21 255.255.255.255 Dialer10
ip route 192.168.254.51 255.255.255.255 Dialer2
ip route 192.168.254.52 255.255.255.255 Dialer3
ip route 192.168.254.53 255.255.255.255 Dialer4
ip route 192.168.254.55 255.255.255.255 Dialer5
ip route 192.168.254.58 255.255.255.255 Dialer6
ip route 195.1.22.0 255.255.255.0 Dialer35
als ik nu 'debug ip rip' aanzet, dan zie ik dat hij het vgl. doet:
18w3d: RIP: sending v1 update to 255.255.255.255 via FastEthernet0/0 (192.168.0.253)
18w3d: RIP: build update entries
18w3d:  network 10.0.0.0 metric 1
18w3d:  network 55.0.0.0 metric 1
18w3d:  network 90.0.0.0 metric 1
18w3d:  network 128.0.0.0 metric 1
18w3d:  network 130.0.0.0 metric 1
18w3d:  network 130.5.0.0 metric 1
18w3d:  network 172.18.0.0 metric 1
18w3d:  subnet 192.168.0.182 metric 1
18w3d:  network 192.168.1.0 metric 1
18w3d:  network 192.168.2.0 metric 1
18w3d:  network 192.168.3.0 metric 1
18w3d:  network 192.168.4.0 metric 1
18w3d:  network 192.168.6.0 metric 1
18w3d:  network 192.168.29.0 metric 1
18w3d:  network 192.168.100.0 metric 1
18w3d:  network 192.168.254.0 metric 1
18w3d:  network 195.1.22.0 metric 1
Hij bepaalt dus zelf dat bijv. 192.168.254.0 voldoet voor zowel 192.168.254.51 en .52 etc.
Ik wil echter dat hij de routes exact overneemt, dus ook voor de /32 adressen.
Iemand enig idee?
  • kell.nl
  • Laatst online: 27-09-2023
kell.nl
Fizzgig's evil twin
RIP v1 gebruikt geen subnetten.
Tenminste, hij verzint ze zelf, door te kijken welk klasse adres het is.
Je kan beter dan RIP v2 gebruiken.. Daar gaat het wel goed.
  • mavink
  • Laatst online: 05-10 15:27
Yep inderdaad. RIPv1 zuigt behoorlijk. Maar niet ieder apparaat snapt RIPv2 weer niet... Om wat voor LAN gaat het?Waarom moet je die routes doorsturen, en naar wat voor apparaten?
  • wizl
Het is gewoon een klein LAN met ongeveer 20 werkstations.
De werkstations verbinden met internet door een router/firewall op basis van FreeBSD. Daarvoor krijgen ze van de DCHP server een default-gateway naar 192.168.0.1/24 (de router/firewall dus).
Naast deze verbinding(en) met internet heb ik dus nog een Cisco 2620 die dial-on-demand verbindingen opbouwt met ongeveer 30 klanten om zo remote ondersteuning te bieden.
Ik laat de Cisco nu m.b.v. RIPv2 :) de routes leren aan de FreeBSD machine (die draait routed -q). Op die manier kunnen de werkstations helemaal transparant verbinden met internet en klanten.
Ander vraagje daarover:
Als een werkstation verbinding maakt met het subnet van een klant, dan komt automatisch de route naar het geconnecte workstation in de lokate routetabel van de machine. Welk mechanisme verzorgt dit? ICMP_REDIRECT (klok horen luiden :P ) En hoe werkt dat dan . . .
