• JackBol
JackBol
Security is not an option!
By BBC News Online science editor Dr David Whitehouse
Scientists have seen a pulse of light emerge from a cloud of gas before it even entered.
This astonishing and baffling observation was made by researchers from the NEC Research Institute in Princeton, US.
They conducted an experiment that involved lasers, a chamber containing cold caesium atoms and a super-fast stopwatch.
The end result was a beam of light that moved at 300 times the theoretical limit for the speed of light.
It was Einstein who said nothing physical could break this barrier because, among other things, to do so would also mean travelling back in time.
Dramatic demonstration
But the NEC scientists believe their work does not violate Einstein's theory.
Writing in the journal Nature, Dr Lijun Wang and colleagues say their light beam raced through the atom trap so quickly that the leading edge of the pulse's peak actually exited before it had entered.
If this sounds confusing, then do not worry. Many physicists are uncomfortable with it too despite their explanations that it is a natural consequence of the wave nature of light.
Although the work of Dr Wang's team is remarkable, it is not the first time that this sort of "trick" has been performed - but it is certainly the most dramatic demonstration.
Earlier this year, a team of physicists made a microwave beam travel 7% faster than light speed. Last year, they announced that they had even slowed light down to almost a crawl.
Anomalous refractive index
To achieve their peculiar effect, Dr Wang's group fired laser beams through a trap of caesium atoms.
By adjusting the frequency of the laser beams to match those of the energy levels in the atoms, the researchers were able to achieve an effect called "anomalous refractive index." This boosts the pulses' so-called "group velocity" to a speed faster than what we understand to be the speed of light - just short of 300 million metres per second.
The group velocity of a light pulse depends upon the mixture of frequencies within the pulse and the medium through which it travels. It need not be the speed of the pulse itself.
The important thing, however, is that whilst the group velocity can be manipulated to be faster than the speed of light, it is not possible to use this effect to send information faster than the speed of light.
Because of the fast group velocity, the leading edge of the pulse appears to leave the caesium-filled chamber 62 billionths of a second before it arrives.
Causality principle
And according to Dr Wang, this strange result does not threaten Einstein's theories - in particular, the causality principle, which states that a cause must precede its effect.
Or so almost all physicists think - for now. Privately, some admit that experiments such as Dr Wang's may force a reassessment of some cherished ideas.
According to Dr Guenter Nimtz, of the University of Cologne, who has carried out similar experiments, the NEC work is very exciting.
He told BBC News Online: "The effect cannot be used to go back in time, only to reduce the time between cause and effect a little bit.
"The reason for this," he said, "is because the light pulse has a finite length of time, much longer than any gain obtained by a faster-than-light speed."
  • JackBol
JackBol
  • Nietzman
  • Laatst online: 11-09 16:32
Nietzman
Woei!
ja... stond gister al in stuffis generalis....
jammer voor je joh, net íéts te laat..... :P
  • JJJ
  • Laatst online: 10:30
JJJ
Nou, de laatste tijd heb je wel meer berichten over de lichtsnelheid :)
Als ik me niet vergis hebben Italiaanse wetenschappers een magnetron golf versnelt tot 28% boven lichtsnelheid.
Hoe groter de golf hoe langzamer hij gaat, als je hem dus maar klein genoeg maakt kun je dus zulke snelheden halen.
