Jaja, ik weer..
Ik wil een KDE programma installeren, dat kan niet omdat ik de volgende fout krijg:[quote]
checking for KDE... configure: error:
in the prefix, you've chosen, are no KDE headers installed. This will fail.
So, check this please and use another prefix!
Client1:/home/saviour/incoming/kxicq-03132000#[q]
Goed, dan maar kdelibs-dev installeren, fout.. dan krijg ik dit:
Hoe kan ik dit nou oplossen dan?
Oke, dan maar zelf kdevelop-2.0.2 compileren? Nee..Client1:/home/saviour/incoming/kdevelop-2.0.2# apt-get install kdelibs-dev
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
kdelibs-dev: Depends: libkmid-dev (= 4:2.2.2-11) but it is not going to be installed
E: Sorry, broken packages
Dat zal dus wel niet het juiste pakket zijnchecking for KDE... configure: error:
