nieuw report:
FREESCO v0.2.6 System Report. Generated - Sun Feb 17 23:19:56 2002
----- clock -----
Sun Feb 17 23:19:58 2002
----- cat /etc/system.cfg -----
# [System]
ROUTER=ethernet# 0.dialup/leased/ethernet/bridge
HOSTNAME=bitch#711.Router name
DOMAIN=lan#712.(Local) domain name
ENAMSQ=y # 11.Enable NAT and firewall
ENABRG=n # 12.Enable bridging mode? DONT TOUCH!!!
BIGMEM=n # 13.If 16+MB RAM start ppp bsd compression
SAVERS=0,0 # 14.Savers - screen(min),hdd(x5 sec) 0 -off
SWPSIZE=0# 15.Swap size in Kb on boot device. 0 - off
LOGSIZE=30000,3000# 16.System_log,logins_log sizes (bytes)
# [Services] # y - worldwide/s - local/n - disable
ENADNS=s #411.Enable caching DNS server
LOGDNS=n#412.Enable debug info
ENADHCP=s #421.Enable DHCP server
WINSADDR=#422.WINS address (for DHCP server)
LIZTIME=86400,86400#423.default-lease-time,max-lease-time
ENAWWW=s #431.Enable Public HTTP Server
WWWPORT=80 #432.on port
ENAWWA=y #441.Enable Time Server and control via HTTP
WWAPORT=82 #442.on port
TIMADDR=www.clock.org#443.Host timeserver address, empty - disable
TIMZONE=+0100#444.Offset to UTC (-1200 -:- +1200)
ENALPD=n #451.Enable Print Server
LPPORT1=515#452.on port
LPDEV1=lp1#453.on output device
LPPORT2=516#454.Second lp server on port, empty - disable
LPDEV2=lp2#455.on output device
ENATEL=n# 46.Enable telnet server
# [Security]
TRUSTLN=p #211.Trust local nets y/n/p{artual}
TRUSTMD=n#212.Modem links have access to local networks
RINGS=2,7#220.Rings before answer at login,nologin time
MonTIM=""#221.Nologin times for modem users
TueTIM=""#222
WedTIM=""#223
ThuTIM=""#224
FriTIM=""#225
SatTIM=""#226
SunTIM=""#227
# [Modems]
MODEM0= # 51.1st modem
MSPEED0=# 52.port's speed
MINIT0=""# 53.init string
MTU0=#541.Maximum Transmit Unit
MRU0=#542.Maximum Receive Unit
MADDR0=192.168.168.2# 55.ppp link remote addr (for dialin purpose)
MODEM1= # 61
MSPEED1=# 62
MINIT1=""# 63
MTU1=#641
MRU1=#642
MADDR1=192.168.168.3# 65.I said for dialin purpose.
# [leased line router]
ADRTYPE=dynamic #921.if ISP supplies us with dynamic IP, then:
LOCAL=127.0.0.2 #922.fake local side ppp IP addr
REMOTE=127.0.0.3 #923.fake remote addr
# [ethernet/leased/printer/ras router]
GATEWAY=80.56.66.1#911.Default gateway, if exist.
DNSADDR=127.0.0.1#912.Host DNS address for ethernet connection
PROXY=""#913.HTTP proxy addr[:port]
# [Hardware]
IO0=0x310#811.1st ethernet card I/O address
IRQ0=11#812.IRQ line
IO1=0x340#821
IRQ1=9#822
IO2=0#831
IRQ2=0#832
# [Networks]
USEDHCP0=y#720.Use DHCP client to config this interface
INTNAME0=eth0#721.Interface name (eth0|arc0e|arc0)
IPADDR0=80.56.66.102#722.IP adress of this interface
NETMASK0=255.255.255.0 #723.Network mask
NETWORK0=80.56.66.0# Network address
BRDCAST0=80.56.66.255# Broadcast address
#724.IP pool, empty disables DHCP on this interface
IPRANGE0=""
INTNAME1=eth1#731.Interface name (eth1|eth0:1|arc0e|arc0 etc)
IPADDR1=[4~[5~192.168.0.1#732. Second network
NETMASK1=255.255.255.0
NETWORK1=
BRDCAST1=
IPRANGE1="192.168.0.1 192.168.0.200"
INTNAME2=#74x. Third network
IPADDR2=
NETMASK2=
NETWORK2=
BRDCAST2=
IPRANGE2=""
----- cat /etc/live.cfg -----
VER=0.2.6
bootdev=fd0
UPTIME="Sun Feb 17 23:19:34 2002"
NETWORK0=80.56.66.0
GATEWAY=80.56.66.1
DONE="echo Done"
----- cat /etc/forward.cfg -----
#_47x._[Port_forwarding_AKA_export_services]
#_
#_tcp|udp,incoming_port,local_computer_IP_addr/port
#_
#_Example:_t,80,192.168.168.2/80
#_this_will_open_worldwide_web_server_on_local_computer_192.168.168.2
#_
#_Example:_t,21,192.168.168.3/21
#_this_will_open_worldwide_ftp_server_on_local_computer_192.168.168.2
#_
#_Comment_must_be_on_separate_line_start_with_"#_"_and_should_not_have_spaces
----- cat /etc/banlist.cfg -----
#_23._[List_of_banned_hosts/nets_one_record_per_line]
#_
#_local|external,IP_addr[/netmask_or_netbits_if_baning_a_whole_net]
#_
#_Example:_l,123.124.125.0/24_ban_local_net
#_Example:_e,123.124.125.0/255.255.255.0_ban_external_net
#_Example:_l,10.0.0.123_ban_local_host
#_
#_Comment_must_be_on_separat_lines_start_with_"#_"_and_should_not_have_spaces
----- sed -n 1,/AUTH/P /etc/chat.pwd -----
----- lsmod -----
ModulePagesUsed by
/tmp/net/rtl8139.o.C 31
new_tunnel 10
ipip 10
ip_masq_quake 10
ip_masq_vdolive 10
ip_masq_raudio 10
ip_masq_irc 10
ip_masq_icq 10
ip_masq_h3231 10
ip_masq_ftp 10
ip_masq_cuseeme 10
8390 20
----- ifconfig -----
lo Link encap:Local Loopback
inet addr:127.0.0.1 Bcast:127.255.255.255 Mask:255.0.0.0
UP BROADCAST LOOPBACK RUNNING MTU:3584 Metric:1
RX packets:20 errors:0 dropped:0 overruns:0
TX packets:20 errors:0 dropped:0 overruns:0
eth0 Link encap:10Mbps Ethernet HWaddr 00:00:21:DB:23:38
inet addr:80.56.66.102 Bcast:80.56.66.255 Mask:255.255.255.0
UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1
RX packets:129 errors:0 dropped:0 overruns:0
TX packets:3 errors:0 dropped:0 overruns:0
Interrupt:9 Base address:0xec00
----- cat /proc/interrupts -----
0: 4752 timer
1: 36 keyboard
2: 0 cascade
6: 117 + floppy
8: 1 + rtc
9: 132 eth0
13: 0 math error
----- cat /proc/ioports -----
0000-001f : dma1
0020-003f : pic1
0040-005f : timer
0060-006f : keyboard
0070-007f : rtc
0080-009f : dma page reg
00a0-00bf : pic2
00c0-00df : dma2
00f0-00ff : npu
02f8-02ff : serial(auto)
0378-037f : lp
03c0-03df : vga+
03f0-03f5 : floppy
03f7-03f7 : floppy DIR
03f8-03ff : serial(auto)
ec00-ec7f : eth0
----- route -n -----
Kernel routing table
Destination Gateway Genmask Flags MSS Window Use Iface
255.255.255.255 * 255.255.255.255 UH 1500 0 0 eth0
80.56.66.0 * 255.255.255.0 U 1500 0 0 eth0
127.0.0.0 * 255.0.0.0 U 3584 0 1 lo
default 80.56.66.1 * UG 1500 0 0 eth0
----- cat /etc/dhcpd.leases -----
----- free -----
total: used: free: shared: buffers: cached:
Mem: 130859008 8069120 122789888 3715072 2265088 966656
Swap: 0 0 0
MemTotal: 127792 kB
MemFree: 119912 kB
MemShared: 3628 kB
Buffers: 2212 kB
Cached: 944 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Mounted FS:
/dev/root / ext2 rw 0 0
/proc /proc proc rw 0 0
/dev/fd0 /mnt umsdos rw 0 0
Filesystem 1024-blocks Used Available Capacity Mounted on
/dev/ram0 1898 1516 382 80% /
/dev/fd0 1424 1372 51 96% /mnt
----- ps -----
PidStat ParentNameCommand
1 S0initinitauto
2 S1kflushd
3 S1kswapd
4 S1logrotatesh/bin/logrotate
6 S1syslogdsyslogd
8 S1klogdklogd
17 S4daemonsh/bin/daemon-agetty 9600 tty2
19 S17agettyagetty9600tty2
141 S1dhcpcddhcpcd-hbitcheth0
175 S1namednamed
308 S1thttpdthttpd-p82-uroot-d/wwa-l/dev/null
312 S1thttpdthttpd-p80-unobody-d/www-l/dev/null
315 S1daemonsh/bin/daemon-synctimesleep 180002>/dev/null
317 S4daemonsh/bin/daemon-agetty 9600 tty1
319 S317sh-sh
334 S315sleepsleep180002>/dev/null
342 S4sleepsleep10
343 S319reportsh/bin/report
363 R343pssh/bin/ps
----- cat /etc/ppp/opt* -----
----- setserial -bg /dev/cua? -----
/dev/cua0 at 0x03f8 (irq = 4) is a 16550A
/dev/cua1 at 0x02f8 (irq = 3) is a 16550A
ik kan btw LLEEN MAR NAAR ip'S PINGEN EN NIET NAAR
WWW.GOOGLE.COM BIJVOORBEELD
nog steeds geen IP op andere pc's
