In potato-main zit geen Qt, maar in woody en sid wel. En niet zo weinig ook
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
| odysseus@odysseus:~$ apt-cache search qt | grep qt
libguile9 - libraries for Guile1.4 (guile, guilereadline, and qthreads).
libqt-dev - Qt GUI development headers, static libraries
libqt-emb-dev - Qt-Embedded GUI development headers, static libraries
libqt-gl-dev - Qt GUI development libraries for GL version
libqt-mt-dev - Qt GUI development headers, static libraries (Threaded version)
libqt2 - Qt GUI Library (runtime version).
libqt2-emb - Qt-Embedded GUI Library (runtime version).
libqt2-gl - Qt GUI Library (GL version).
libqt2-mt - Qt GUI Library (runtime threaded version).
libqt3 - Qt GUI Library (runtime version).
libqt3-dev - Qt GUI development headers, static libraries
libqt3-emb - Qt-Embedded GUI Library (runtime version).
libqt3-emb-dev - Qt-Embedded GUI development headers, static libraries
libqt3-mt - Qt GUI Library (Threaded runtime version).
libqt3-mt-dev - Qt Threaded static libraries
libqt3-mysql - Mysql database plugin for Qt3
libqt3-odbc - ODBC plugin for Qt3
libqtcups-dev - Qt interface library for CUPS (development files)
libqtcups2 - Qt interface library for CUPS
licq-plugin-qt2 - Graphical front-end plugin for LICQ using Qt2
python-pyqt - Qt bindings for Python
python-pyqt-doc - Qt bindings for Python - Documentation and examples
qt-designer - Qt GUI Designer
qt-designer-doc - Tutorial and reference documentation for Qt Designer
qt-doc - Tutorial and reference documentation and examples for Qt.
qt-emb-doc - Tutorial and reference documentation and examples for Qt-Embedded.
qt3-doc - Tutorial and reference documentation and examples for Qt.
qt3-emb-doc - Tutorial and reference documentation and examples for Qt-Embedded.
qt3-tools - Qt GUI Designer and other Qt3 based tools
qtcups - Qt front-end for CUPS.
qtella - A gnutella client
qtss - streaming multimedia server
vlc-qt - Qt plugin for vlc
wordtrans-qt - Multi Language Word Translator for Linux
libqt3-psql - Postgresql database plugin for Qt3
psi - jabber client using qt
qttudo - A program for ERP (enterprise resource planning) and administrative accounting.
libqt1g - Shared Library used by applications linked with libqt.
libqt1g-dev - Environment for QT GUI development.
qt1g-doc - Comprehensive docs (html), examples, and tutorial for QT.
libqt2.2 - Qt GUI Library (Migration package).
libqt2.2-emb - Qt-Embedded GUI Library (runtime version).
libqt2.2-emb-dev - Qt-Embedded GUI development headers, static libraries
libqt2.2-gl - Qt GUI Library (GL Version - Migration package).
odysseus@odysseus:~$ |
Nieuwe qt-packages komen binnenkort, maar de oude maintainer is ermee gestopt helaas en de nieuwe (Daniel Stone) is nog niet klaar met nieuwe packages omdat hij ze helemaal van de grond af opnieuw aan het opbouwen is. Verwachte opleverdatum is binnen een week, als je het _echt_ nodig hebt dan kun je ook Stone mailen voor een versie die hij al klaar heeft staan maar verwacht dan wel compleet weggeflamed te worden
Leven is het meervoud van lef | In order to make an apple pie from scratch, you must first create the universe.
