tpc/ip poorten
  • 162 views sinds 30-01-2008
ik zag een poos geleden een link op GOT naar een site met tpc/ip poorten en waarvoor ze gebuikt worden.
Heeft iemand die nog ? of iets anders natuurlijk.
thxs
rtmp 1/ddp #Routing Table Maintenance Protocol
tcpmux 1/tcp #TCP Port Service Multiplexer
tcpmux 1/udp #TCP Port Service Multiplexer
nbp 2/ddp #Name Binding Protocol
compressnet 2/tcp #Management Utility
compressnet 2/udp #Management Utility
compressnet 3/tcp #Compression Process
compressnet 3/udp #Compression Process
echo 4/ddp #AppleTalk Echo Protocol
rje 5/tcp #Remote Job Entry
rje 5/udp #Remote Job Entry
zip 6/ddp #Zone Information Protocol
echo 7/tcp
echo 7/udp
discard 9/tcp sink null
discard 9/udp sink null
systat 11/tcp users #Active Users
systat 11/udp users #Active Users
daytime 13/tcp
daytime 13/udp
qotd 17/tcp quote #Quote of the Day
qotd 17/udp quote #Quote of the Day
msp 18/tcp #Message Send Protocol
msp 18/udp #Message Send Protocol
chargen 19/tcp ttytst source #Character Generator
chargen 19/udp ttytst source #Character Generator
ftp-data 20/tcp #File Transfer [Default Data]
ftp-data 20/udp #File Transfer [Default Data]
ftp 21/tcp #File Transfer [Control]
ftp 21/udp #File Transfer [Control]
ssh 22/tcp #Secure Shell Login
ssh 22/udp #Secure Shell Login
telnet 23/tcp
telnet 23/udp
# 24/tcp any private mail system
# 24/udp any private mail system
smtp 25/tcp mail #Simple Mail Transfer
smtp 25/udp mail #Simple Mail Transfer
nsw-fe 27/tcp #NSW User System FE
nsw-fe 27/udp #NSW User System FE
msg-icp 29/tcp #MSG ICP
msg-icp 29/udp #MSG ICP
msg-auth 31/tcp #MSG Authentication
msg-auth 31/udp #MSG Authentication
dsp 33/tcp #Display Support Protocol
dsp 33/udp #Display Support Protocol
# 35/tcp any private printer server
# 35/udp any private printer server
time 37/tcp timserver
time 37/udp timserver
rap 38/tcp #Route Access Protocol
rap 38/udp #Route Access Protocol
rlp 39/tcp resource #Resource Location Protocol
rlp 39/udp resource #Resource Location Protocol
graphics 41/tcp
graphics 41/udp
nameserver 42/tcp name #Host Name Server
nameserver 42/udp name #Host Name Server
nicname 43/tcp whois
nicname 43/udp whois
mpm-flags 44/tcp #MPM FLAGS Protocol
mpm-flags 44/udp #MPM FLAGS Protocol
mpm 45/tcp #Message Processing Module [recv]
mpm 45/udp #Message Processing Module [recv]
mpm-snd 46/tcp #MPM [default send]
mpm-snd 46/udp #MPM [default send]
ni-ftp 47/tcp #NI FTP
ni-ftp 47/udp #NI FTP
auditd 48/tcp #Digital Audit Daemon
auditd 48/udp #Digital Audit Daemon
tacacs 49/tcp #Login Host Protocol (TACACS)
tacacs 49/udp #Login Host Protocol (TACACS)
re-mail-ck 50/tcp #Remote Mail Checking Protocol
re-mail-ck 50/udp #Remote Mail Checking Protocol
la-maint 51/tcp #IMP Logical Address Maintenance
la-maint 51/udp #IMP Logical Address Maintenance
xns-time 52/tcp #XNS Time Protocol
xns-time 52/udp #XNS Time Protocol
domain 53/tcp #Domain Name Server
domain 53/udp #Domain Name Server
xns-ch 54/tcp #XNS Clearinghouse
xns-ch 54/udp #XNS Clearinghouse
isi-gl 55/tcp #ISI Graphics Language
isi-gl 55/udp #ISI Graphics Language
xns-auth 56/tcp #XNS Authentication
xns-auth 56/udp #XNS Authentication
mtp 57/tcp # deprecated
#PROBLEMS!==============================================================
# 57/tcp any private terminal access
# 57/udp any private terminal access
xns-mail 58/tcp #XNS Mail
xns-mail 58/udp #XNS Mail
# 59/tcp any private file service
# 59/udp any private file service
ni-mail 61/tcp #NI MAIL
ni-mail 61/udp #NI MAIL
acas 62/tcp #ACA Services
acas 62/udp #ACA Services
whois++ 63/tcp
whois++ 63/udp
covia 64/tcp #Communications Integrator (CI)
covia 64/udp #Communications Integrator (CI)
tacacs-ds 65/tcp #TACACS-Database Service
tacacs-ds 65/udp #TACACS-Database Service
sql*net 66/tcp #Oracle SQL*NET
sql*net 66/udp #Oracle SQL*NET
bootps 67/tcp dhcps #Bootstrap Protocol Server
bootps 67/udp dhcps #Bootstrap Protocol Server
bootpc 68/tcp dhcpc #Bootstrap Protocol Client
bootpc 68/udp dhcpc #Bootstrap Protocol Client
tftp 69/tcp #Trivial File Transfer
tftp 69/udp #Trivial File Transfer
gopher 70/tcp
gopher 70/udp
netrjs-1 71/tcp #Remote Job Service
netrjs-1 71/udp #Remote Job Service
netrjs-2 72/tcp #Remote Job Service
netrjs-2 72/udp #Remote Job Service
netrjs-3 73/tcp #Remote Job Service
netrjs-3 73/udp #Remote Job Service
netrjs-4 74/tcp #Remote Job Service
netrjs-4 74/udp #Remote Job Service
# 75/tcp any private dial out service
# 75/udp any private dial out service
deos 76/tcp #Distributed External Object Store
deos 76/udp #Distributed External Object Store
netrjs 77/tcp
# 77/tcp any private RJE service
# 77/udp any private RJE service
vettcp 78/tcp
vettcp 78/udp
finger 79/tcp
finger 79/udp
http 80/tcp www www-http #World Wide Web HTTP
http 80/udp www www-http #World Wide Web HTTP
hosts2-ns 81/tcp #HOSTS2 Name Server
hosts2-ns 81/udp #HOSTS2 Name Server
xfer 82/tcp #XFER Utility
xfer 82/udp #XFER Utility
mit-ml-dev 83/tcp #MIT ML Device
mit-ml-dev 83/udp #MIT ML Device
ctf 84/tcp #Common Trace Facility
ctf 84/udp #Common Trace Facility
mit-ml-dev 85/tcp #MIT ML Device
mit-ml-dev 85/udp #MIT ML Device
mfcobol 86/tcp #Micro Focus Cobol
mfcobol 86/udp #Micro Focus Cobol
ttylink 87/tcp
# 87/tcp any private terminal link
# 87/udp any private terminal link
kerberos-sec 88/tcp kerberos # krb5 # Kerberos (v5)
kerberos-sec 88/udp kerberos # krb5 # Kerberos (v5)
su-mit-tg 89/tcp #SU/MIT Telnet Gateway
su-mit-tg 89/udp #SU/MIT Telnet Gateway
dnsix 90/tcp #DNSIX Securit Attribute Token Map
dnsix 90/udp #DNSIX Securit Attribute Token Map
mit-dov 91/tcp #MIT Dover Spooler
mit-dov 91/udp #MIT Dover Spooler
npp 92/tcp #Network Printing Protocol
npp 92/udp #Network Printing Protocol
dcp 93/tcp #Device Control Protocol
dcp 93/udp #Device Control Protocol
objcall 94/tcp #Tivoli Object Dispatcher
objcall 94/udp #Tivoli Object Dispatcher
supdup 95/tcp
supdup 95/udp
dixie 96/tcp #DIXIE Protocol Specification
dixie 96/udp #DIXIE Protocol Specification
swift-rvf 97/tcp #Swift Remote Virtural File Protocol
swift-rvf 97/udp #Swift Remote Virtural File Protocol
tacnews 98/tcp #TAC News
tacnews 98/udp #TAC News
metagram 99/tcp #Metagram Relay
metagram 99/udp #Metagram Relay
newacct 100/tcp #[unauthorized use]
hostname 101/tcp hostnames #NIC Host Name Server
hostname 101/udp hostnames #NIC Host Name Server
iso-tsap 102/tcp tsap #ISO-TSAP Class 0
iso-tsap 102/udp tsap #ISO-TSAP Class 0
gppitnp 103/tcp #Genesis Point-to-Point Trans Net
gppitnp 103/udp #Genesis Point-to-Point Trans Net
acr-nema 104/tcp #ACR-NEMA Digital Imag. & Comm. 300
acr-nema 104/udp #ACR-NEMA Digital Imag. & Comm. 300
csnet-ns 105/tcp
Op http://advice.networkice.com/advice/exploits/ports / krijg je ze wat overzichtelijker Afbeeldingslocatie: http://tweakers.net/g/forum/g/smilies/wink.gif
