ik zal het nogmaals proberen aangezien ik hier al heel lang op zit te klooien en 'm maar niet aan de praat krijg, dus loop ik tegen een concreet probleem aan... Het lukt me niet om de IP wel op te laten slaan maar niet te laten controleren, zodat een IP wel meerdere malen kan stemmen.
'Two varibles are passed into the db
'u_input is the value if the user entered a response to
'the vote/poll question....IP is the address of the user
u_input=request.form("u_input")
u_ip=request.servervariables("remote_addr")
' if the user did not enter anything in the poll on this visit
' then display the poll question and possible choices
if u_input = "" then
<form method="post" action="<%= request.servervariables("script_name") %>">
<p>Wat vond je van het laatste schoolfeest?<br>
<input type="radio" value="1" name="u_input" checked >Super<br>
<input type="radio" value="2" name="u_input">geinig<br>
<input type="radio" value="3" name="u_input">niks<br>
<input type="radio" value="4" name="u_input">niet geweest<br>
<input type="submit" value="Stem" ></p>
</form>
else
' if the user did input a choice on the vote/ballot
' check to see if their ip address is already in the db
' if the directory your .asp page is in does not have user
' write authority the accessdb variable and access db may
' need to be moved to your /cgi-bin/ directory and add that to the code below
accessdb="db/poll"
cn="driver={Microsoft Access Driver (*.mdb)};"
cn=cn & "dbq=" & server.mappath(accessdb)
set rs = server.createobject("ADODB.Recordset")
sql = "select ip from uitslag where ip ='" & u_ip & "'"
rs.Open sql, cn
if rs.eof then
' if the user has not voted previously indicate it
been_here_before="No"
end if
rs.close
if been_here_before = "No" then
' Since the user has not voted previously their input
' their vote will be added to the db
sql = "insert into uitslag (ip, selection" & u_input &") "
sql = sql & "values ('" & u_ip & "',1)"
rs.Open sql, cn
end if
'This will summerize and count the records in the db
sql= "select distinctrow "
sql= sql & "sum(selection1) as sum_selection1, "
sql= sql & "sum(selection2) as sum_selection2, "
sql= sql & "sum(selection3) as sum_selection3, "
sql= sql & "sum(selection4) as sum_selection4, "
sql= sql & "count(
AS total_votes "
sql= sql & "FROM uitslag;"
rs.Open sql, cn
total1=rs ("sum_selection1")
total2=rs ("sum_selection2")
total3=rs ("sum_selection3")
total4=rs ("sum_selection4")
count=rs ("total_votes") %>
jhhjj<br>
[img]"blue.jpg"[/img]">
<%= formatnumber((total1/count)*100,1) %>%<br> super <br>
<%= formatnumber((total2/count)*100,1) %>%<br> geinig <br>
<%= formatnumber((total3/count)*100,1) %>%<br> niks <br>
<%= formatnumber((total4/count)*100,1) %>%<br> niet geweest <br>
Totaal aantal stemmen: <%= formatnumber(count,0,0) %><br> <% end if %>
</form>
else
accessdb="db/poll"
rs.Open sql, cn
if rs.eof then
end if
rs.close
rs.Open sql, cn
end if
sql= sql & "count(
rs.Open sql, cn
jhhjj<br>
Never eat yellow snow...
