ik heb dit scriptje:
dit scriptje pakt je eigen naam bij msn en al je vrienden + email. maar ik snap de functie isStateOnline niet helemaal, zou ik hiermee ook de precieze status van iemand kunnen pakken?
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
| <script event="onload" for="window" language="javascript">
<!-- Begin
var textlist = "";
var you = "";
var installed = true;
// Check if MSN Messenger is installed
try {
var xObj = new ActiveXObject("Messenger.MsgrObject");
if (xObj == null)
installed = false;
catch (e) {
installed = false;
if (installed) {
if (isStateOnline(MsgrObj.LocalState)) {
// Get contact list
var list = MsgrObj.List(0);
// Get you!
you = MsgrObj.LocalFriendlyName + " (" + MsgrObj.LocalLogonName + ")";
// Get your friends
for (i=0; i<list.Count; i++)
textlist = textlist + list.Item(i).FriendlyName + " (" + list.Item(i).EmailAddress + ")\n";
else {
// You must be offline
you = " - MSN Messenger is not connected. - ";
else {
// MSN not installed
you = " - MSN Messenger is not installed. - ";
// Is user online?
function isStateOnline(state) {
var ret;
switch (state) {
case 2:
//online
case 6:
//invisible
case 10:
//busy
case 14:
//be right back
case 18:
//idle
case 34:
//away
case 50:
//on the phone
case 66:
//out to lunch
ret = true;
break;
default:
ret = false;
break;
return ret;
// Fill in the form
document.forms.details.you.value = you;
document.forms.details.friends.value = textlist;
// End -->
</script> |
2 swim or not 2 swim, that's the question
