Op zaterdag 09 februari 2002 11:17 schreef X-terior het volgende:
Als je samba volledig hebt geinstalleerd, heb je al op je systeem staan.
find / -name smbclient -print dan moet je hem dan kunnen vinden.
De naam is dan ook smbclient
. Lees vooral ook de door mij eerder gegeven link door.
Als samba nog niet is geinstalleerd is, kun je dat doen met behulp van het rpm commando: rpm -i sambaPackageNaam. Deze staan op de RH Cd.
Gevonden, als ik em start krijg ik:
[root@Server2Linux bin]# smbclient
added interface ip=192.168.0.2 bcast=192.168.0.255 nmask=255.255.255.0
Usage: smbclient service <password> [options]
Version 2.2.1a
-s smb.conf pathname to smb.conf file
-O socket_options socket options to use
-R name resolve order use these name resolution services only
-M host send a winpopup message to the host
-i scope use this NetBIOS scope
-N don't ask for a password
-n netbios name. Use this name as my netbios name
-d debuglevel set the debuglevel
-P connect to service as a printer
-p port connect to the specified port
-l log basename. Basename for log/debug files
-h Print this help message.
-I dest IP use this IP to connect to
-E write messages to stderr instead of stdout
-U username set the network username
-L host get a list of shares available on a host
-t terminal code terminal i/o code {sjis|euc|jis7|jis8|junet|hex}
-m max protocol set the max protocol level
-A filename get the credentials from a file
-W workgroup set the workgroup name
-T<c|x>IXFqgbNan command line tar
-D directory start from directory
-c command string execute semicolon separated commands
-b xmit/send buffer changes the transmit/send buffer (default: 65520)
