MSI™ KT3 Ultra
  • Spice
  • Laatst online: 09-01 14:46
Spice
- Mijn vader is een tovenaar -
Afbeeldingslocatie: http://www.msi.com.tw/newsrelease/6380e.gif
Driven by DDR memory trend, MSI KT3 Ultra is designed based on VIAR® KT333 chipset to support latest DDR333 (PC2700) and DDR266 (PC2100) memory specification. This particular mainboard consists with 3 DDR DIMMs which support up to 3GB maximum memory. In addition to that, KT3 Ultra can support AMD Athlon XP 2000+ processors, AMD Athlon and Duron plus it latest technology feature-Thermal Diode Circuit.
MSI KT3 Ultra not only offers high speed memory data transferring capability, it also provides one of important specification, which is Dual Channel RAID ATA133, as a great feature to enhance the entire system's efficiency. When everyone is using ATA100 Hard Drive as their standard, MSI's KT3 Ultra has alreay offers user an advance tech tool - ATA133 for communication between hard drive and main system. To be more precise, ATA 133 supports RAID 0 (Striping) or RAID 1 (Mirroring) function, which can make PC system into a powerful Performance or Security platform solution.
On the other hand, MSI KT3 Ultra is equipped with 2 USB2.0 ports which provide 480Mbps/sec high data transferring speed as optional feature to maximize its performance and as well as onto external device such as FS Digital Still Camera,USB HDD or PC periphery for high speed on havey data transferring function.
To satisfy users' high sound quality desire, MSI KT3 Ultra offers 6-Channel sound chip which can support home theather sorrounding sound entertaining system for user to enjoy 3D Gaming or watching DVD purpose.
MSI KT3 Ultra is equipped with 1 AGP 4x, 5 standard 32-bit/33MHz PCI slots and 1 CNR slot plus some value-added MSI user-friendly innovated features:
D-Bracket --- D-Bracket is a new innovation combining the D-LED feature 2 USB ports. It helps the user diagnose computer hardware problems outside of the computer chassis, eliminating the trouble of having to open up the chassis every time.The D-Bracket also has a combination of 4 LED light signals that are either green or red, representing 16 different troubleshooting functions during boot up.
Just call me angel of the morning, angel. Just touch my cheek before you leave me, baby. Just call me angel of the morning, angel.
  • Darth Punk
  • Laatst online: 12-09 16:14
Darth Punk
professionalized prutz0r
leuk bordje
i want LART!
  • Spice
Spice
Ai, das wel een vadsig mobo, alleen snap ik dat hele dat hele gedoe van die ddr333 niet, waarom zou je dat willen, de cpu heeft toch maar een bandbreedte van 266 ofzo?
  • Ozzi
  • Laatst online: 20-09 19:19
Ozzi
Op dinsdag 12 februari 2002 16:59 schreef minipolopikoler het volgende:
inversteren in de toekomst :P
geen
  • SmokeyTheBandit
  • Laatst online: 17-06 10:20
SmokeyTheBandit
DOCer met Pensioen
Valt wel op dat MSI altijd als 1e de nieuwste chipsets heeft draaien *D
Turn it off and on again.
Op dinsdag 12 februari 2002 23:22 schreef Smokey_The_Bandit het volgende:
Klopt, vandaar ook de vele stabiliteitsproblemen die ze hebben :r
  • Hoyden
  • Registratie: December 1999
  • Laatst online: 15:28
Op woensdag 13 februari 2002 00:49 schreef TweakGuy het volgende:
:o
http://www.tbreak.com/hard/mobo/msi_kt3ultra/page3.html
voortaan beter de review lezen?
"New chipsets sometimes have the tendency of bringing about new incompatibilities or stability issues, but we're delighted to report that the KT333 isn't one such chipset. It passed all hardware tests gracefully and none of the software we tested caused any instability"
wou eerst een elitegroup k7s5a kopen lekker goedkoop en best snel en stabiel vergeleken met de andere moederborden uit die tijd
heb ik dus net deze benchmarks bekeken
http://www.hardwarepub.com/reviews/motherboards/amdddrmobos/index_10.shtml
ok ok het betreft hier het verschil tussen een epox 8k3a+ en vorige generatie moederborden waaronder de k7s5a
maar wat een verschil
en als je na het lezen van de benchmarks daarna deze review ff doorspit (vergelijking tussen epox 8k3a+, asus a7v33 en de msi kt3 ultra)
tussen die 3 moederborden verslaat de msi kt3 ultra de rest op gebied van games, sisoft cpu multimedia en memory
vind het verschil tussen een elitegroup k7s5a en een msi kt3 ultra zo groot dat ik het helemaal niet erg vind om meer neer te leggen voor een moederbord :)
En uit ervaring...., met MSI geen stabiliteitsproblemen.
vind het alleen terleurstellend dat geen van de reviewers het geheugen stabiel over de 143fsb heeft gekregen
zit dus nu wel te twijfelen of ik niet beter een epox 8k3a+ kan nemen zodat ik die fsb dus wel hoog kan krijgen :?
waarschijnlijk is het gewoon een kwestie van een bios upgrade maar daar wil ik niet op wachten omdat ik bij aanschaf van mn moederbord gelijk mn amd xp1800+ kan oc :P
Bij de epox was de memoryperformance een (bios?)probleem.
Zo is er dus bij ieder moederbord dus wel wat.
