Iptables probleempjuh
  • DeVoTioN
  • Laatst online: 07-03-2022
Op me oude bak draai ik nu rh 7.2 en heb daarop een Quake3 server geinstalleerd. Alleen ik zie de server niet intern of extern :( Volgens mij ligt het aan me firewall alleen ik weet nog niet zoveel van iptables.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
#!/bin/sh
IPTABLES="/sbin/iptables"
#Time to clean house
#Clear out any existing firewall rules, and any chains that might have
#been created
$IPTABLES -F
$IPTABLES -F INPUT
$IPTABLES -F OUTPUT
$IPTABLES -F FORWARD
$IPTABLES -F -t mangle
$IPTABLES -F -t nat
$IPTABLES -X
#Setup our policies
$IPTABLES -P INPUT DROP
$IPTABLES -P OUTPUT ACCEPT
$IPTABLES -P FORWARD ACCEPT
#This enables ip forwarding, and thus by extension, NAT
#Turn this on if you're going to be doing NAT or Masquerading
echo 1 > /proc/sys/net/ipv4/ip_forward
#Our actual rules
#Our NAT stuff
#Source NAT everything heading out the eth0 (external) interface to be the
#given IP. If you have a dynamic ip or a DHCP ip that changes
#semi-regularly, comment this and uncomment the second line
#Remember to change the ip address to your static ip
$IPTABLES -t nat -A POSTROUTING -o eth0 -j SNAT --to 213.51.72.9
#$IPTABLES -t nat -A POSTROUTING -o eth0 -j MASQUERADE
#These are port-forwarding examples for several different cases.
#These map the specified ports to the specified ip address.
#This one maps port 80 to 192.168.1.1. Anything incoming over eth0 to
#the server will be redirected invisibly to port 80 on 192.168.1.1
$IPTABLES -t nat -A PREROUTING -i eth0 -p udp --dport 27960 -j DNAT --to 192.168.1.20
#These two redirect a block of ports, in both udp and tcp.
#$IPTABLES -t nat -A PREROUTING -i eth0 -p tcp --dport 2300:2400 -j DNAT --to 192.168.1.1
#$IPTABLES -t nat -A PREROUTING -i eth0 -p udp --dport 2300:2400 -j DNAT --to 192.168.1.1
#Now, our firewall chain
#We use the limit commands to cap the rate at which it alerts to 15
#log messages per minute
$IPTABLES -N firewall
$IPTABLES -A firewall -m limit --limit 15/minute -j LOG --log-prefix Firewall:
$IPTABLES -A firewall -j DROP
#Now, our dropwall chain, for the final catchall filter
$IPTABLES -N dropwall
$IPTABLES -A dropwall -m limit --limit 15/minute -j LOG --log-prefix Dropwall:
$IPTABLES -A dropwall -j DROP
#Our "hey, them's some bad tcp flags!" chain
$IPTABLES -N badflags
$IPTABLES -A badflags -m limit --limit 15/minute -j LOG --log-prefix Badflags:
$IPTABLES -A badflags -j DROP
#And our silent logging chain
$IPTABLES -N silent
$IPTABLES -A silent -j DROP
#Accept ourselves (loopback interface), 'cause we're all warm and friendly
$IPTABLES -A INPUT -i lo -j ACCEPT
#Drop those nasty packets!
#These are all TCP flag combinations that should never, ever occur in the
#wild. All of these are illegal combinations that are used to attack a box
#in various ways, so we just drop them and log them here.
$IPTABLES -A INPUT -p tcp --tcp-flags ALL FIN,URG,PSH -j badflags
$IPTABLES -A INPUT -p tcp --tcp-flags ALL ALL -j badflags
$IPTABLES -A INPUT -p tcp --tcp-flags ALL SYN,RST,ACK,FIN,URG -j badflags
$IPTABLES -A INPUT -p tcp --tcp-flags ALL NONE -j badflags
$IPTABLES -A INPUT -p tcp --tcp-flags SYN,RST SYN,RST -j badflags
$IPTABLES -A INPUT -p tcp --tcp-flags SYN,FIN SYN,FIN -j badflags
#Drop icmp, but only after letting certain types through
$IPTABLES -A INPUT -p icmp --icmp-type 0 -j ACCEPT
$IPTABLES -A INPUT -p icmp --icmp-type 3 -j ACCEPT
$IPTABLES -A INPUT -p icmp --icmp-type 11 -j ACCEPT
$IPTABLES -A INPUT -p icmp --icmp-type 8 -m limit --limit 1/second -j ACCEPT
$IPTABLES -A INPUT -p icmp -j firewall
#Accept SSH connections from everywhere.
#Uncomment this if you're running SSH and want to be able to access it
#from the outside world.
#$IPTABLES -I in_udp -p udp --dport 22 -j ACCEPT
#Accept all from eth1
$IPTABLES -A INPUT -i eth1 -s 192.168.1.0/24 -j ACCEPT
#Lets do some basic state-matching
#This allows us to accept related and established connections, so
#client-side things like ftp work properly, for example.
$IPTABLES -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
#Uncomment to drop port 137 netbios packets silently. We don't like
#that netbios stuff, and it's #way too spammy with windows machines on
#the network.
$IPTABLES -A INPUT -p udp --sport 137 --dport 137 -j silent
#Our final trap. Everything on INPUT goes to the dropwall so we don't get silent drops
$IPTABLES -A INPUT -j dropwall
echo "*** === FIREWALL UP ! === ***"
Ik heb ook logcheck installed die me elk uur mailed en daar staat dit in :
Unusual System Events
Feb  7 23:00:04 cp11582-a kernel: Dropwall:IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:00:c5:0d:fe:c7:08:00 SRC=217.120.121.7 DST=255.255.255.255 LEN=160 TOS=0x00 PREC=0x00 TTL=128 ID=49872 PROTO=UDP SPT=1663 DPT=1900 LEN=140
Feb  7 23:00:04 cp11582-a kernel: Dropwall:IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:00:c5:0d:fe:c7:08:00 SRC=217.120.121.7 DST=255.255.255.255 LEN=161 TOS=0x00 PREC=0x00 TTL=128 ID=50128 PROTO=UDP SPT=1663 DPT=1900 LEN=141
enz....
Weet iemand wat er fout is in mn firewall :? bvd.
  • DeVoTioN
Niemand :?
Weet iemand wat die log errors betekene ?
Lijkt erop dat je firewall een aantal udp packets met als destination port 1900 denied.
iptables -A INPUT -s 217.120.121.7 -p udp --dport 1900 -j ACCEPT
Verder lijkt het mij ook niet zo slim om de default policy van forward op accept te zetten ;)
