Soltek SL75DRV4
Heeft iemand ervaring met dit mobo??? ik heb hem nl. net besteld, zag er gaaf uit (paars) en had goede overclocking mogelijkheden. Ook op tomshardware kwam hij als "OVERCLOCKING KING" er uit: maar iemand persoonlijk er ervaring mee??
Hier een plaatje:
Afbeeldingslocatie: http://www.soltek.com.tw/moboimage/75drv4.jpg
En hier de specs:
Processor
¡Ü AMD Socket-462 Athlon XP / Athlon / Duron processor
Chipset
¡Ü VIA KT266A (VT8366A + VT8233A)
VT8366A:
- 552 BGA
- Features 266/200MHz Front Side Bus settings
- 266/200MHz Memory Bus
- V-Link Hub Architecture, 266MHz link between the North and South Bridge
- Supports AGP 4X/2X
- PC2100/PC1600 compliant
VT8233A:
- 376 BGA
- Supports Ultra ATA-133/100/66 transfer protocol
- Provides AC'97 Audio
- Support for four USB Ports (max.)
Memory
3 x 184-pin DDR DIMM
Supports 6 banks up to 3GB DRAMs for Unbuffered DDR SDRAM Module
Cache Memory
Built-in to AMD Athlon¢â XP, Athlon¢â and Duron¢â Processor Module
On-Board EIDE
2 x PCI Bus Master UATA 133/100/66 IDE ports (up to 4 ATAPI Devices)
Supports for PIO Mode 3, 4, UATA 133/100/66 IDE & ATAPI CD-ROM
Integrated Super I/O
1 x Floppy Port (supports 360K, 720K, 1.2M, 1.44M and 2.88Mbytes)
2 x serial ports (high-speed 16550A FIFO UART Ports)
1 x Parallel Port with EEP/ECP/SPP Capabilities
1 x PS/2 Mouse, 1 x PS/2 Keyboard connectors
4 x USB Ports (two via optional cable)
1 x Audio/Game Port
Expansion Slots
1 x AGP Pro/4X Slot
5 x 32-bit PCI Bus Master Slots
1 x CNR (Communication and Networking Riser)
Form Factor
ATX Form Factor (225mm x 305mm)
BIOS
AWARD Plug-and-Play BIOS
Supports Advanced Power Management Function
Flash Memory for easy upgrade
Other Features
Multiplier Setting ¡Ü RedStorm Overclocking
BIOS FSB Setting ¡Ü Ultra ATA 66/100/133
BIOS Vcore setting ¡Ü AC'97 Audio Function
AGP Voltage Setting ¡Ü DIMM Voltage Setting
SCR (Smart Card Reader) Interface ¡Ü H/W Monitor
SmartDoc. Anti-burning Shield
[edit: plaatje + specs]
  • Tachyon
  • Laatst online: 16-09 23:59
Tachyon
pop the glock
Misschien vindt je in dit topic nog wat info! ;)
If we do not change our direction, we will likely end up where we are heading.
