[Linux (icepack)] ECS K7S5A onboard sndcard instal
Hoe krijg ik mijn souncard aan het lopen?
Ik heb een ecs K7S5A mobo met onboard sound (www.ecsusa.com).
What to do?
Kozel
Wat voor chipset is het precies?
Als het op je pci-bus zit kun je dat zien met:
cat /proc/pci
kozel 19:18:18 ~ > cat /proc/pci
PCI devices found:
Bus 0, device 0, function 0:
Host bridge: PCI device 1039:0735 (Silicon Integrated Systems [SiS]) (rev 1).
Master Capable. Latency=32.
Non-prefetchable 32 bit memory at 0xd0000000 [0xd3ffffff].
Bus 0, device 1, function 0:
PCI bridge: Silicon Integrated Systems [SiS] 5591/5592 AGP (rev 0).
Master Capable. Latency=64. Min Gnt=10.
Bus 0, device 2, function 0:
ISA bridge: Silicon Integrated Systems [SiS] 85C503/5513 (rev 0).
Bus 0, device 2, function 3:
USB Controller: Silicon Integrated Systems [SiS] 7001 (#2) (rev 7).
IRQ 11.
Master Capable. Latency=64. Max Lat=80.
Non-prefetchable 32 bit memory at 0xcffff000 [0xcfffffff].
Bus 0, device 2, function 2:
USB Controller: Silicon Integrated Systems [SiS] 7001 (rev 7).
IRQ 11.
Non-prefetchable 32 bit memory at 0xcfffe000 [0xcfffefff].
Bus 0, device 2, function 5:
IDE interface: Silicon Integrated Systems [SiS] 5513 [IDE] (rev 208). Master Capable. Latency=128. I/O at 0xff00 [0xff0f]. Bus 0, device 2, function 7: Multimedia audio controller: PCI device 1039:7012 (Silicon Integrated Systems [SiS]) (rev 160).
IRQ 11.
Master Capable. Latency=64. Min Gnt=52.Max Lat=11.
I/O at 0xdc00 [0xdcff].
I/O at 0xd800 [0xd83f].
Bus 0, device 3, function 0:
Ethernet controller: Silicon Integrated Systems [SiS] SiS900 10/100 Ethernet (rev 144).
IRQ 11.
I/O at 0xd400 [0xd4ff].
Non-prefetchable 32 bit memory at 0xcfffd000 [0xcfffdfff].
Bus 0, device 13, function 0:
Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8029(AS) (rev 0).
IRQ 11.
I/O at 0xd000 [0xd01f].
Bus 1, device 0, function 0:
VGA compatible controller: nVidia Corporation NV11 (rev 178).
IRQ 5.
Master Capable. Latency=64. Min Gnt=5.Max Lat=1.
Non-prefetchable 32 bit memory at 0xce000000 [0xceffffff].
Prefetchable 32 bit memory at 0xc0000000 [0xc7ffffff].
  • rvanlooijen
  • Laatst online: 21-06-2021
Dat is een standaard AC97 onboard kaartje ;) Nu je die naam hebt zullen drivers wel niet al te lastig te vinden zijn denk ik ;) (misschien op meegeleverd cd'tje ;))
  • MBMarduk
MBMarduk
BAR-baar
De SiS7012 wordt in elkaar getimmerd op dit moment...
http://www.uwsg.iu.edu/hypermail/linux/kernel/0112.3/0587.html
Deze link is het laatste wat ik erover heb gelezen.
Doe 'ns een search in LKML voor "SiS 7012" ofzo, misschien dat het al een beetje gevorderd is.
