[MOHAA] Niet fullscreen
Medal of Honor wil niet fullscreen.
Geforce 2 MX 400 met detonator 23.11 en daarna 21.81, geeft beide geen oplossing.
DirectX 8.1 is geinstalleerd.
Iemand een suggestie?
  • WoutF
  • Laatst online: 11:47
WoutF
Hoofdredacteur
Uhm, hij start hem dus windowed op?
Probeer es ALT+Enter
Bedankt!
Zo simpel :+ ....
lol
  • Fuelke
  • Laatst online: 14-10 20:41
Fuelke
Forza Ferrari
Of door ff in je options te gaan kijken >:)
La Ferrari più bella è quella che dobbiamo ancore fare: La Prossima
  • MarcoM
  • Laatst online: 13-08 13:39
Ik heb ook problemen met fullscreen gehad. Onderstaande lost dat op.
- Here is EA's response, and my reply to thier BS answer:
----- Original Message -----
To: <ssg-covert@xxx.net>
Sent: Friday, January 25, 2002 2:19 PM
Subject: RE: EA Tech Support request for Medal of Honor Allied Assault (au to generation)
> Hello,
> Thank you for sending your concerns regarding Medal of Honor.
> To resolve this we will want to tell your dial up service not to >try and automatically connect. Follow these steps to do this:
> 1) Click the "Start" button, then click "Settings", then >click "Control Panel"
> 2) Once the "Control Panel" is loaded, double-click on "Internet
> Options"
> 3) Click the "Connections" tab
> 4) Check "Never dial a connection"
> 5) Click "Apply", then click "OK"
> The auto dialer should not start running now.
> Hopefully this will help resolve your difficulty playing the game.
> Thank you for contacting EA Technical Support.
> Travis A.
