suggesties voor sms?
ja:
Line Message
16 The tag: "td" doesn't have an attribute: "background" in currently active versions.
17 The tag: "td" doesn't have an attribute: "background" in currently active versions.
20 The tag: "td" doesn't have an attribute: "background" in currently active versions.
39 The tag: "td" doesn't have an attribute: "background" in currently active versions.
45 The tag: "td" doesn't have an attribute: "background" in currently active versions.
50 The tag: "td" doesn't have an attribute: "background" in currently active versions.
53 The tag: "td" doesn't have an attribute: "background" in currently active versions.
58 The tag: "td" doesn't have an attribute: "background" in currently active versions.
63 The tag: "td" doesn't have an attribute: "background" in currently active versions.
65 The tag: "td" doesn't have an attribute: "background" in currently active versions.
69 The tag: "td" doesn't have an attribute: "background" in currently active versions.
77 The tag: "td" doesn't have an attribute: "background" in currently active versions.
84 The tag:"table" is not allowed within: "p" It is only allowed within: button, del, fieldset, iframe, ins, noframes, noscript, object, td, th.
87 The tag:"td" is not allowed within: "form". No valid contexts are specified for this element in currently active versions.
88 The tag:"td" is not allowed within: "form". No valid contexts are specified for this element in currently active versions.
90 The tag:"tr" is not allowed within: "form" It is only allowed within: table, tbody, tfoot, thead.
93 The tag: "input" doesn't have an attribute: "width" in currently active versions.
93 The tag: "input" doesn't have an attribute: "height" in currently active versions.
93 The tag: " td" allows optional end tag. End tag: "form" closes "td" context. Validation will proceed as if the tag were ended.
93 The tag: " tr" allows optional end tag. End tag: "form" closes "tr" context. Validation will proceed as if the tag were ended.
98 The tag:"td" is not allowed within: "table". No valid contexts are specified for this element in currently active versions.
107 The tag: "td" doesn't have an attribute: "background" in currently active versions.
114 The tag:"table" is not allowed within: "p" It is only allowed within: button, del, fieldset, iframe, ins, noframes, noscript, object, td, th.
117 The tag:"td" is not allowed within: "form". No valid contexts are specified for this element in currently active versions.
118 The tag:"td" is not allowed within: "form". No valid contexts are specified for this element in currently active versions.
120 The tag:"tr" is not allowed within: "form" It is only allowed within: table, tbody, tfoot, thead.
122 "25"</TD is not a valid value for the "size" attribute in HTML20. Valid values for this attribute are: Dynamic expression, positive non zero integer.
122 "25"</TD is not a valid value for the "size" attribute in any of the currently active versions. See the above warnings for more details.
123 The tag: " td" is invalid inside tag: "td". The "td" end tag is optional. Validation will proceed as if the tag were ended.
123 The tag: "input" doesn't have an attribute: "width" in currently active versions.
123 The tag: "input" doesn't have an attribute: "height" in currently active versions.
124 The tag: " td" allows optional end tag. End tag: "form" closes "td" context. Validation will proceed as if the tag were ended.
124 The tag: " tr" allows optional end tag. End tag: "form" closes "tr" context. Validation will proceed as if the tag were ended.
129 The tag:"td" is not allowed within: "table". No valid contexts are specified for this element in currently active versions.
138 The tag: "td" doesn't have an attribute: "background" in currently active versions.
145 The tag:"table" is not allowed within: "p" It is only allowed within: button, del, fieldset, iframe, ins, noframes, noscript, object, td, th.
148 The tag:"td" is not allowed within: "form". No valid contexts are specified for this element in currently active versions.
149 The tag:"td" is not allowed within: "form". No valid contexts are specified for this element in currently active versions.
151 The tag:"tr" is not allowed within: "form" It is only allowed within: table, tbody, tfoot, thead.
154 The tag: "input" doesn't have an attribute: "width" in currently active versions.
154 The tag: "input" doesn't have an attribute: "height" in currently active versions.
181 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using &#copy; instead.
158 The tag: " td" allows optional end tag. End tag: "form" closes "td" context. Validation will proceed as if the tag were ended.
158 The tag: " tr" allows optional end tag. End tag: "form" closes "tr" context. Validation will proceed as if the tag were ended.
162 No starting tag found for: "td", or it was closed too many times
163 The tag:"td" is not allowed within: "table". No valid contexts are specified for this element in currently active versions.
164 No starting tag found for: "tr", or it was closed too many times
168 No starting tag found for: "td", or it was closed too many times
169 The tag:"td" is not allowed within: "table". No valid contexts are specified for this element in currently active versions.
169 The tag: "td" doesn't have an attribute: "background" in currently active versions.
170 No starting tag found for: "tr", or it was closed too many times
174 The tag: "td" doesn't have an attribute: "background" in currently active versions.
178 No starting tag found for: "td", or it was closed too many times
179 No starting tag found for: "tr", or it was closed too many times
13 No closing tag was found for the "div" tag, which must be closed.
