[GBA] Flash Linker savegames backuppen?
  • ThePriest
  • Laatst online: 30-01-2024
ThePriest
the one, the only
Een vraagje. Weet iemand hoe die software voor de GBA linker werkt voor wat betreft die savegames met banks e.d.? Ik kom er niet uit, dit schermpje:
Afbeeldingslocatie: http://www.euronet.nl/users/tcls/flash.jpg
En de uitleg in die manual is niet echt lekker helder ofzo... Iemand die precies weet wat welke optie voorstelt?
Thanks
  • .GoO
  • Laatst online: 14-10 22:49
Krijg ik ook nooit goed aan de gang :( Zegt altijd verkeerde kaart type, of save bank etc.. :(
  • RvE
  • Laatst online: 27-09 09:14
RvE
Uit de user guide:
Backup ROM files
Through the selection Backup Game a filename can be entered. Once
confirmed, the Flash Linker is carrying out an analysis and will suggest
the estimated file size. A selection box to alter the file size, if necessary,
will appear before saving. Files size can be 8M up to 256M. A saved
game could then be altered on your PC or could be used for research
purpose.
Savegame functions
Through the functions Backup Saver and Write Saver the savegames
can be sent and received from/to the Flash Cards. Once the message
window was opened, two different options are available: Locations
(bank 1 bank 4) on the left, memory sizes (32K, 64K, 128K, and
256K) on the right.
Bank 1 to bank 4 refer to the 4 different 64K banks in the Flash Cards.
Please note the Flash Card Advance 64M only comes with 128K SRAM,
therefore selection of bank 3 and 4 just mirrors bank 1 and 2. The Flash
Card Advance 128M can be used with all four banks!
After entering the file name and clicking OK, the savegame will be
stored on the PC harddrive.
Attention coders: Using the Flash Cards Advance the usually 32K
SRAM size for each game will automatically expand to 64K without any
extra programming or circuit needs. However, if you for example
change an EEPROM game such as Mario to work with the SRAM, you
need to utilize more than 64K and use two banks.
Everywhere you go you always take the weather with you
  • AMD
  • Laatst online: 08:26
AMD
Life is short. Play more
Gebruik Little Writer. Doe ik ook.
Ik gebruik de standaard software om spellen op de flash te zetten en Little Writer om savegames te bewaren en herstellen.
Kijk hier eens
