Ik heb dus kernel 2.4.17 hergecompileerd & gepatched, die
hier: http://www.kernel.org/pub/linux/kernel/people/hedrick/
te vinden is.
Nou boot ik ermee, en vindt ie mijn chipset, maar ik zie nergens dat een /dev/* wordt toegekend.
Hier dmesg output:
Linux version 2.4.17 (root@debian) (gcc version 2.95.4 20011006 (Debian prerelease)) #2 Mon Jan 28 00:12:06 CET 2002
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
BIOS-e820: 000000000fff0000 - 000000000fff3000 (ACPI NVS)
BIOS-e820: 000000000fff3000 - 0000000010000000 (ACPI data)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
On node 0 totalpages: 65520
zone(0): 4096 pages.
zone(1): 61424 pages.
zone(2): 0 pages.
Kernel command line: BOOT_IMAGE=high ro root=307
Initializing CPU#0
Detected 1000.070 MHz processor.
Console: colour VGA+ 80x25
Calibrating delay loop... 1992.29 BogoMIPS
Memory: 255016k/262080k available (1581k kernel code, 6676k reserved, 514k data, 228k init, 0k highmem)
Dentry-cache hash table entries: 32768 (order: 6, 262144 bytes)
Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
Buffer-cache hash table entries: 16384 (order: 4, 65536 bytes)
Page-cache hash table entries: 65536 (order: 6, 262144 bytes)
CPU: Before vendor init, caps: 0183f9ff c1c7f9ff 00000000, vendor = 2
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU: After vendor init, caps: 0183f9ff c1c7f9ff 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: After generic, caps: 0183f9ff c1c7f9ff 00000000 00000000
CPU: Common caps: 0183f9ff c1c7f9ff 00000000 00000000
CPU: AMD Athlon(tm) processor stepping 02
Enabling fast FPU save and restore... done.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
PCI: PCI BIOS revision 2.10 entry at 0xfb4e0, last bus=1
PCI: Using configuration type 1
PCI: Probing PCI hardware
Trying to stomp on Athlon bug...
PCI: Using IRQ router VIA [1106/0686] at 00:07.0
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
apm: BIOS version 1.2 Flags 0x07 (Driver version 1.15)
Starting kswapd
NTFS driver v1.1.21 [Flags: R/O]
udf: registering filesystem
pty: 256 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI ISAPNP enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
ttyS01 at 0x02f8 (irq = 3) is a 16550A
block: 128 slots per queue, batch=32
Uniform Multi-Platform E-IDE driver Revision: 6.31
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller on PCI bus 00 dev 39
VP_IDE: detected chipset, but driver not compiled in!
VP_IDE: chipset revision 16
VP_IDE: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xa000-0xa007, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xa008-0xa00f, BIOS settings: hdc:DMA, hdd:pio
HPT370: IDE controller on PCI bus 00 dev 98
PCI: Found IRQ 11 for device 00:13.0
PCI: Sharing IRQ 11 with 00:09.0
HPT370: chipset revision 3
HPT370: not 100% native mode: will probe irqs later
HPT370: using 50MHz internal PLL
ide2: BM-DMA at 0xc400-0xc407, BIOS settings: hde:DMA, hdf:DMA
ide3: BM-DMA at 0xc408-0xc40f, BIOS settings: hdg:pio, hdh:pio
hda: IBM-DTLA-307045, ATA DISK drive
hdb: Pioneer DVD-ROM ATAPIModel DVD-115 0111, ATAPI CD/DVD-ROM drive
hdc: AOPEN CD-RW CRW2040, ATAPI CD/DVD-ROM drive
hde: MAXTOR 6L040J2, ATA DISK drive
hdf: MAXTOR 6L040J2, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide1 at 0x170-0x177,0x376 on irq 15
ide2 at 0xb400-0xb407,0xb802 on irq 11
hda: 90069840 sectors (46116 MB) w/1916KiB Cache, CHS=5606/255/63
hde: 78177792 sectors (40027 MB) w/1819KiB Cache, CHS=77557/16/63, UDMA(100)
hdf: 78177792 sectors (40027 MB) w/1819KiB Cache, CHS=77557/16/63, UDMA(100)
hdb: ATAPI DVD-ROM drive, 512kB Cache
Uniform CD-ROM driver Revision: 3.12
hdc: ATAPI 40X CD-ROM CD-R/RW drive, 2048kB Cache
Partition check:
hda: hda1 hda2 < hda5 hda6 hda7 hda8 hda9 >
hde: [PTBL] [4866/255/63] hde1 hde2 < >
hdf: unknown partition table
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
PCI: Found IRQ 10 for device 00:0b.0
PCI: Sharing IRQ 10 with 00:07.2
PCI: Sharing IRQ 10 with 00:07.3
3c59x: Donald Becker and others. www.scyld.com/network/vortex.html
00:0b.0: 3Com PCI 3c905C Tornado at 0xb000. Vers LK1.1.16
Linux video capture interface: v1.00
Mediavision Pro Movie Studio driver 0.02
PMS type is 0
Board not found.
Linux agpgart interface v0.99 (c) Jeff Hartmann
agpgart: Maximum main memory to use for agp memory: 203M
agpgart: Detected Via Apollo Pro KT133 chipset
agpgart: AGP aperture is 64M @ 0xe8000000
[drm] Initialized tdfx 1.0.0 20010216 on minor 0
[drm] AGP 0.99 on VIA Apollo KT133 @ 0xe8000000 64MB
[drm] Initialized radeon 1.1.1 20010405 on minor 1
SCSI subsystem driver Revision: 1.00
3ware Storage Controller device driver for Linux v1.02.00.010.
3w-xxxx: No cards with valid units found.
request_module[scsi_hostadapter]: Root fs not mounted
es1371: version v0.30 time 23:47:55 Jan 27 2002
Linux Kernel Card Services 3.1.22
options: [pci] [cardbus] [pm]
usb.c: registered new driver hub
uhci.c: USB Universal Host Controller Interface driver v1.1
PCI: Found IRQ 10 for device 00:07.2
PCI: Sharing IRQ 10 with 00:0b.0
uhci.c: USB UHCI at I/O 0xa400, IRQ 10
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 2 ports detected
PCI: Found IRQ 10 for device 00:07.3
uhci.c: USB UHCI at I/O 0xa800, IRQ 10
usb.c: new USB bus registered, assigned bus number 2
usb.c: registered new driver usblp
printer.c: v0.8:USB Printer Device Class driver
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
md: raid0 personality registered as nr 2
md: multipath personality registered as nr 7
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
LVM version 1.0.1-rc4(ish)(03/10/2001)
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 2048 buckets, 16Kbytes
TCP: Hash tables configured (established 16384 bind 16384)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
ds: no socket drivers loaded!
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 228k freed
hub.c: USB new device connect on bus2/1, assigned device number 2
scsi0 : SCSI emulation for USB Mass Storage devices
Adding Swap: 538136k swap-space (priority -1)
te vinden is.
Hier dmesg output:
zone(2): 0 pages.
Initializing CPU#0
Starting kswapd
Partition check:
PMS type is 0
Board not found.
md: autorun ...
