Medal of Honor
  • 39 views sinds 30-01-2008
Heb net het spel geinstalleerd maar krijg de volgende melding van console:
--- Common Initialization ---
Medal of Honor Allied Assault 1.10 win-x86 Jan 22 2002
----- FS_Startup -----
Current search path:
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak5.pk3 (259 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak4.pk3 (593 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak3.pk3 (669 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak2.pk3 (4722 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak1.pk3 (772 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak0.pk3 (11175 files)
C:\PROGRA~1\EAGAME~1\MOHAA/main
18190 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
execing safemode.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 78
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
Heeft iemand hier ook last van gehad?
Ik heb een NVIDIA GeForce2 Mx/MX 400 als videokaart!
Ik hoop dat jullie een antwoord hebben!! ;(
Even de search gebruiken maar je meot ff de nieuwe drivers van nvidia downe
www.nvidia.com
Effe de nieuwste Detonator drivers downloaden en alles is perfect , zoek in de T.net meuktracker of op Nvidia.com
  • Vidra
  • Laatst online: 18-09 19:57
Vidra
Vragen?
Dat is idd de oplossing :P
Trouwens Medal of Honor: Allied Assault is wel een zeer heftig spel....o.a. de beach-landing @ Ohama-beach is cool :9
Executive Director | aan mijn uitspraken kunnen geen rechten worden ontleend! | Build: AMD 7800X3D - 32GB - AMD RX 7900XTX
Bedoelen jullie deze:
NVIDIA Display Driver for Windows 2000/XP version 27.00, 12/19/2001
Deze heb ik geinstalleerd maar nog krijg ik dezelfde melding.
Op zondag 27 januari 2002 00:14 schreef Makaveli187 het volgende:
Pak effe de 21.83 of de 23.11 drivers , en verwijder eerst je oude drivers.
21.83 Nvidia
23.11 Nvidia
  • pica
  • Laatst online: 14-10 22:44
Dan heb je wat fout gedaan :+
Steam
Op zondag 27 januari 2002 00:10 schreef Vidra het volgende:
Alleen het eind he :( >:)
Je land toch niet op het strand . je komt toch aan dobberen?? :D
Hij geeft nog steeds de zelfde melding, heel vreemd want ik heb nog nooit zo'n melding gehad.
Heeft iemand nog meer suggesties? ;(
  • Ferdo
  • Laatst online: 17-01 17:24
Ferdo
Dido Armstrong :9~
Op zondag 27 januari 2002 00:46 schreef Makaveli187 het volgende:
DirectX opnieuw installeren?
Audioscrobbler profile
Begin de dag met een dansje, begin de dag met een lach,
want wie vrolijk kijkt in de morgen, die lacht de hele dag,
jaaa, die lacht de hele dag!
Ook gedaan, maar nog steeds niks.
Ik weet het niet meer. De CD's kopieren lukt mij trouwens ook niet, hij kan de file 0000002.tmp niet kopieren.
Deze is toch ook overbodig, of heb ik dat verkeerd?
  • Skeleton353
  • Laatst online: 11-01-2020
Skeleton353
Ik herken mezelf niet meer ...
Tja, dat heb je met copy'tes :? |:(
Asus Cusl2-c - Intel P3-800 Mhz - 512 Mb Ram - Asus V7700 (Ge-force 2 GTS) - Plextor 40/12/40A CD-writer - SB-audigy - 2x40 Gb HD - Cambridge FPS-1000 Speakers - IIYAMA AS4611UT LCD Monitor - MS Optical Wheel Mouse - Windows XP Professional (Engels)
Hoi,
Dit probleem heb ik dus ook :-(
  • M@NIC
  • Laatst online: 23-09 09:24
Gelukkig kan ik 7september dat ding installen, serialtje invoeren en lekker ragguh....
En dan werkt die gelekte ISO niet meer :P (hoop ik)
  • Flexx
  • Laatst online: 15-10 11:01
Flexx
This side up
Kan het zijn dat je de FLT release hebt en de DEViANCE 1.1 Patch eroverheen gedraait hebt ?
  • paella
  • Laatst online: 19:45
Op zondag 27 januari 2002 00:53 schreef Ferdo het volgende:
Heeft dat zin als de foutmeldng is dat ie OpenGL niet kan vinden?
No production networks were harmed during this posting
  • IceStorm
  • Laatst online: 14-10 22:20
IceStorm
This place is GoT-like!!!
Ja vervelend met zo'n kopie. Dat is het risico he.
