Ik heb problemen met perl onder Debian.. bijvoorbeeld als ik een user wil adden:
Het enige probleem is dat ik niet weet hoe! En hoe ik eraan kom..
Kan iemand hier wat licht op schijnen?
edit: En als ik screen bijv. wil installeren:
Nu weet ik dat ik dat moet installerenServeR:/home/saviour/perl-5.6.1# adduser bla
Can't locate Debian/AdduserCommon.pm in @INC (@INC contains: /usr/local/lib/perl5/5.6.1/i586-linux /usr/local/lib/perl5/5.6.1 /usr/local/lib/perl5/site_perl/5.6.1/i586-linux /usr/local/lib/perl5/site_perl/5.6.1 /usr/local/lib/perl5/site_perl .) at /usr/sbin/adduser line 67.
BEGIN failed--compilation aborted at /usr/sbin/adduser line 67.
ServeR:/home/saviour/screen-3.9.10# apt-get install screen
Reading Package Lists... Done
Building Dependency Tree... Done
The following NEW packages will be installed:
screen
0 packages upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 packages not fully installed or removed.
Need to get 0B/262kB of archives. After unpacking 545kB will be used.
debconf: Perl may be unconfigured (Can't locate Debconf/Log.pm in @INC (@INC contains: /usr/local/lib/perl5/5.6.1/i586-linux /usr/local/lib/perl5/5.6.1 /usr/local/lib/perl5/site_perl/5.6.1/i586-linux /usr/local/lib/perl5/site_perl/5.6.1 /usr/local/lib/perl5/site_perl .) at (eval 1) line 4.
BEGIN failed--compilation aborted at (eval 1) line 4.
) -- aborting
(Reading database ... 11724 files and directories currently installed.)
Unpacking screen (from .../screen_3.9.10-1_i386.deb) ...
Can't locate Debconf/Db.pm in @INC (@INC contains: /usr/local/lib/perl5/5.6.1/i586-linux /usr/local/lib/perl5/5.6.1 /usr/local/lib/perl5/site_perl/5.6.1/i586-linux /usr/local/lib/perl5/site_perl/5.6.1 /usr/local/lib/perl5/site_perl .) at /usr/share/debconf/frontend line 22.
BEGIN failed--compilation aborted at /usr/share/debconf/frontend line 22.
dpkg: error processing /var/cache/apt/archives/screen_3.9.10-1_i386.deb (--unpack):
subprocess pre-installation script returned error exit status 2
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
