29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
| # GENERIC -- Generic kernel configuration file for FreeBSD/i386 # # For more information on this file, please read the handbook section on # Kernel Configuration Files: # # http://www.FreeBSD.org/handbook/kernelconfig-config.html # # The handbook is also available locally in /usr/share/doc/handbook # if you've installed the doc distribution, otherwise always see the # FreeBSD World Wide Web server (http://www.FreeBSD.org/) for the # latest information. # # An exhaustive list of options and more detailed explanations of the # device lines is also present in the ./LINT configuration file. If you are # in doubt as to the purpose or necessity of a line, check first in LINT. # # $FreeBSD: src/sys/i386/conf/GENERIC,v 1.246.2.34 2001/08/12 13:13:46 joerg Exp $ machine i386 cpu I686_CPU ident GENERIC maxusers 10 #makeoptions DEBUG=-g #Build kernel with gdb(1) debug symbols options INET #InterNETworking options INET6 #IPv6 communications protocols options FFS #Berkeley Fast Filesystem options FFS_ROOT #FFS usable as root device [keep this!] options SOFTUPDATES #Enable FFS soft updates support options MFS #Memory Filesystem options MD_ROOT #MD is a potential root device options MSDOSFS #MSDOS Filesystem options CD9660 #ISO 9660 Filesystem options CD9660_ROOT #CD-ROM usable as root, CD9660 required options PROCFS #Process filesystem options COMPAT_43 #Compatible with BSD 4.3 [KEEP THIS!] options UCONSOLE #Allow users to grab the console options USERCONFIG #boot -c editor options VISUAL_USERCONFIG #visual boot -c editor options KTRACE #ktrace(1) support options SYSVSHM #SYSV-style shared memory options SYSVMSG #SYSV-style message queues options SYSVSEM #SYSV-style semaphores options P1003_1B #Posix P1003_1B real-time extensions options _KPOSIX_PRIORITY_SCHEDULING options ICMP_BANDLIM #Rate limit bad replies options KBD_INSTALL_CDEV # install a CDEV entry in /dev # To make an SMP kernel, the next two are needed device isa device pci # Floppy drives device fdc0 at isa? port IO_FD1 irq 6 drq 2 device fd0 at fdc0 drive 0 # # If you have a Toshiba Libretto with its Y-E Data PCMCIA floppy, # don't use the above line for fdc0 but the following one: # ATA and ATAPI devices device ata0 at isa? port IO_WD1 irq 14 device ata1 at isa? port IO_WD2 irq 15 device ata device atadisk # ATA disk drives device atapicd # ATAPI CDROM drives device atapifd # ATAPI floppy drives options ATA_STATIC_ID # SCSI Controllers # atkbdc0 controls both the keyboard and the PS/2 mouse device atkbdc0 at isa? port IO_KBD device atkbd0 at atkbdc? irq 1 flags 0x1 device psm0 at atkbdc? irq 12 device vga0 at isa? # syscons is the default console driver, resembling an SCO console device sc0 at isa? flags 0x100 # Enable this and PCVT_FREEBSD for pcvt vt220 compatible console driver #device vt0 at isa? #options XSERVER # support for X server on a vt console #options FAT_CURSOR # start with block cursor # If you have a ThinkPAD, uncomment this along with the rest of the PCVT lines #options PCVT_SCANSET=2 # IBM keyboards are non-std # Floating point support - do not disable. device npx0 at nexus? port IO_NPX irq 13 # Power management support (see LINT for more options) # PCCARD (PCMCIA) support # Parallel port device ppbus # Parallel port bus (required) device lpt # Printer device ppi # Parallel port interface device # ISA Ethernet NICs. # 'device ed' requires 'device miibus' device ed0 device miibus # Pseudo devices - the number indicates how many units to allocate. pseudo-device loop # Network loopback pseudo-device ether # Ethernet support pseudo-device pty # Pseudo-ttys (telnet etc) pseudo-device md # Memory "disks" pseudo-device gif # IPv6 and IPv4 tunneling pseudo-device faith 1 # IPv6-to-IPv4 relaying (translation) # The `bpf' pseudo-device enables the Berkeley Packet Filter. # Be aware of the administrative consequences of enabling this! pseudo-device bpf #Berkeley packet filter device pcm |
Dit is mijn kernel config file.
Met de standaard kernel van freebsd doet mijn netwerkaart ne2000 comp. pnp het wel.
Maar met mijn eigen kernel doet hij het niet?
Wat is er aan de hand?
Alvast bedankt
