Mijn keuze is op deze mobo gevallen voor mijn nieuwe XP1900+ cpu
Support 266MHz(EV6) System Bus for AMD Athlon / XP & Duron Socket A CPU
Support PC1600/PC2100 DDR SDRAM
Jumper-less Design
DIE-HARD BIOS with External Controller (Upgrade optional)
CPU clock ratio from 5.5 to 12.5
Support 1X / 2X / 4X AGP mode
AC'97 2.1 Audio support / Audio Codec onboard
Enlarged Aluminum Heatsink for Better Heat Dissipation
CPU Vcore Adjustment for Overclockers through BIOS Setting (1.1V ~1.85V)
Hardware Monitoring
Supports 6 USB ports
1MHz Stepping Frequency Adjustment
Chassis Intrusion Detector
Support Ultra DMA/100 HDD (Additional UDMA/100 Cable included)
Dr. LED(Upgrade optional)
Wake-On-LAN / Modem
PCI Rev 2.2 Compliant
Resetable Fuse Providing Short Circuit Protection for Keyboard and USB Device
ACPI S3 (Suspend to RAM) and S4 (Suspend to Disk)
AOpen Bonus Pack CD (Norton Anti-Virus included)
Goede keuze?
Jumper-less Design
Hardware Monitoring
Wake-On-LAN / Modem
Goede keuze?
